In attesa della versione per il cloudibox, ecco il changelog della versione
New Black Hole Image released!
BLACK HOLE Vu+ 2.1.2
What'snew:
- New skin MX Black Speed P
- Update languages: es, no
- Updated MediaTree (all dvb usb drivers)
- Updated OpenWebIf
- [hbbtv] Update and fix crash
- [ScanSetup] Support TT3L10 automatic scan.
- [TransCodingSetup] fix set config bug and wrong description.
- [ScanSetup] dvb-t2 channel should be searched using scan app. & fix typo.
- fix vuplus-blindscan-utils
- Support dual DVB-T2/C Tuner automatic scan
- Adjust bmem in duo/solo
- - To support 1080 FB
- Update drivers 20141021
- - Support 1080 Framebuffer(duo/solo need kernel update)
- - Support Dual DVB-T2/C Tuner(uno, ultimo, duo2)
- - Support 4 vtuners(solose, vtuner is mutually exclusive with transcoding)
- Added rtl8812au driver to the image (DWA.182 Rev A1 dongle works GREAT!)
- Added isofs module in images with kernel 3.9.x are always compiled as a module (M)
- [rt3070] added support for DWA-140 rev D1
- Fix WOL problem in duo2
- Update drivers 20140925 (duo2, solo2, solose)
- - Fix HDMI problem in some AV receivers
- - Fix WOL problem(duo2)
- - Fix AGC/SNR display(SSH108)
- - Fix misc bugs.
- [rtl8812au] changed drivers from Edimax to GitHub
- [rtl8188eu] Updated driver to the last commit available
- Update driver 20140829 (solo2, solose)
- - Fix transcoding problem(solo2, solose)
- - Optimize memory usage(solo2)
- [vuplus-webmanual] fix incorrect output for solose.
- Update drivers 20140808 (duo2, solose, uno, ultimo)
- - Improve DVB-C/T(CXD1978) tuning performance
- fix uno/ultimo harddisk detection
- fix slow network
BlackHole-2.1.2-cloudibox 3 appena uscita
update media tree (all dvb usb drivers) vuol dire che vengono riconosciuti in automatico tutti dvb-t usb?
ghenti ha scritto:update media tree (all dvb usb drivers) vuol dire che vengono riconosciuti in automatico tutti dvb-t usb?
E' così fresca questa immagine che bisognerebbe provarla :)
