Cari amici,
se mi posso permettere, vi chiedo:
che ne pensate di questa nuova versione? ;)
(fonte airsatddt.com)
CLOUD IBOX4
Main Features
1.3GHz Dual Core CPU Processor
Plug & play DVB-S/-S2/-C/-T/-T2 Triple Tuners or Twin Tuner ( 2 DVBS2. 2 DVBC. 2 DVBT2/C. S2+C. S2+T2/C)
Full HD
HDMI
Linux Operating system.Latter than Kernel / Ver. 3.1 x
Media Player
Downloadable Plug-ins supported
1 x Smartcard Reader
1 x CI Plus
MPEG2/H 264 Hardware Decoding
LED
512MB NAND Flash / 1GB DDR Memory
External SATA supported
Internal HDD (optional)
Gigabit Ethernet Interface
2 x USB2.0
YPbPr
Composite video(RGB)
SCART(TV)
S / PDIF for digital bit stream out (optical )
EPG support
Automatic & Manual Service Scan support
Multiple LNB control (DiSEqC) support
Skin change support
PVR Ready
Support Blackhole OpenPLi OpenVIX **not-mention** Enigma2 0 SkyUK
Support HBBTV CI Plus Web Browser Android IPhone / iPad Airplay
Basta che sia affidabile... col 3 è un terno al lotto...
Mi sembra che abbiamo aggiunto la possibilità  di infilare un hdd interno... BENE!
CLOUD IBOX5 Digital Satellite Receiver with Twin Tuner
Main Features:
1. HD Twin Tuner PVR
2. 1300 MHz CPU BCM7356 dual core
3. 256MB Flash / 1GB DDR3 DRAM
4.Hbb-tv: Hbb-TV supported
Description
1. Hbb-tv: Hbb-TV supported
4. Option to fit Internal SATA HDD 2.5"
5. Dual Card readers
6. Front Display 12 digit VFD display
7. GigaBit Ethernet
8. HDMI 1.4
9. Dolby Digital Plus & DTS 2.0 supported
10. Dual MPEG2/H.264 Hardware Decoding (HD PiP possible)
11. On-the-fly transcoding of content into a variety of formats
12. 1300 MHz CPU BCM7356 dual core
13. 256MB Flash / 1GB DDR3 DRAM
14. Option to fit Internal SATA HDD 2.5"
15. Dual Card readers
16. Front Display 12 digit VFD display
17. GigaBit Ethernet
18. HDMI 1.4
19. Dolby Digital Plus & DTS 2.0 supported
20. Dual MPEG2/H.264 Hardware Decoding (HD PiP possible)
21. On-the-fly transcoding of content into a variety of formats
Size (W x D x H): 195 mm x 140 mm x 40 mm
- Power consumption: < 15W at 12V
- External PSU Input:
- 110-240V AC / 50-60Hz / 0,6A Output:
- 12V = / 3,0A
- Weight:1.7kg
package include:
1*Cloud ibox 5 receiver
1*power adapter & cable
1*RS232 cable
1*Remote control
1*HDMI cable
Mi piace tanto. Chissà  se risolvono 3 problemi fondamentali:
1) Cambiano il telecomando e mettono qualcosa adatta alla situazione (se facessero il telecomando come quello del dm 800) sarebbe fantastico ragazzi.
2) Problema surriscaldamento magari con qualche ventola interna
3) Il deep standby.
Se sistemassero queste 3 cose lo prenderei subito (certo prima attenderei un po' lo sviluppo) ma non credo che ci vorrà  molto tempo per dedicarsi a questo gioiellino.
Voi che ne dite?
*** Messaggio aggiunto il 10-08-2014 7:38 ***
Questo uno screenshot del IBOX4 fatta da un sito by CHINA.
Telecomando sostituito con quello del vecchio ibox (MIGLIORIA)
Ventola interna (MIGLIORIA)
Nessuna posizione per HD (Nessuna MIGLIORIA)
Processore 500mhz (PEGGIORAMENTO)
Fate voi le opportune considerazioni.
Se vedi bene trovi anche un´altra versione del cloud ibox 4 che è quello le cui caratteristiche sono quelle del primo post ed è AIRDIGITAL ...
Vedremo cosa ne uscità¡ fuori ... visto che del cloud IBOX 3 sembra ci sia ora anche il clone del clone.
derekct81 ha scritto:Mi piace tanto. Chissà  se risolvono 3 problemi fondamentali:
3) Il deep standby.
Voi che ne dite?
attenzione che questo non ha niente a che vedere con l'ibox 4 quadri tuner che non è ancora uscito , questo di cui parli è una versione chiamata cosi , ma in pratica è un mini vuduo........
