Ultime notizie cloud ibox3 rilasciate su altro forum dal produttore airsatddt
almost of our goods can update the latest bootloader from 29th may, just few pcs from Feb V1 can not, The clients can contact the supplier to replace new board or keep using the old software, do not update the lastest software,
if poeple use the lastest bootloader 29th may, no need update back to the 17th may because 17th bootloader no has display, we update it to 29th may much faster and has display during update, if clients still want to use old version bootloader, they can update back the old one 17th may,
the new image no contain the bootloader r (bootloader-cloud-ibox-3-751mhz-29.05.2014.zip, poeple has to install this bootloader first and then update the software by cloudix
at this moment the boards without his eeprom socket, after august, we will do it on the boards
all clone died after update our software and bootloader, for our receivers, some clients do the wrong maual like take OFF the USB STICK and then power OFF, the receiver will only blue light, in this case, clients can recover it by the braodband studio eeprom,
Thank all clients' patience for this problem, if no have clone in the market, we will not do this software and bootloader only fixed for our receiver. all software with lastest driver and linux, it is good for cloud ibox3. we will keep supporting software for all of clients, after 29th May, all cloud ibox2 plus, cloudibox3 use cloudix to update.
