Canali da tutto il mondo e Hard in Italiano
This text is also in plugin /KodiDirect/How-to.txt
Please translate with google translate - if needed.
Dieser Text ist auch in - Plugin-/KodiDirect/How to.txt
Bitte übersetzen Sie mit Google Translate - wenn nötig.
Ce texte est également dans le plugin /KodiDirect/How-to.txt
S'il vous plaît traduire avec google translate - si nécessaire.
DEBUG
With any error report - the error log (e.log) must be posted
as described here :-
(1) Do these 3 telnet commands (work for most images) :-
init 4
killall -9 enigma2
enigma2 > /tmp/e.log 2>&1 &
Note: In some images (with for example OE2.2)
the enigma log commands will be different.
Please check if you have problem with
the 3 commands above.
(2) Run KodiDirect until the error occurs.
(3) Copy file /tmp/e.log
(4) zip or rar e.log ->
USER PLUGINS
KodiDirect already provides a number of addon links.
Any other xbmc plugins you wish to test - please
put in folder /KodiDirect/plugins.
SOFTWARE
On first run of the plugin KodiDirect - in the Addons
list screen - select Software and install all the
items listed for your image type.
PLEASE NOTE
The developers of this plugin cannot test it in satellite receivers other than Xtrend models. The users of other makes are welcome to discuss any errors/problems - but please try to help each other if possible.
FINALLY.....
Please help us by reporting any non-working addon. Also suggest new addons you like.
Thank you for using this plugin !
http://www.mediafire.com/download/rkiec16inprt781/enigma2-plugin-extensions-kodidirect_2.0_r0_all.ipk
ciao ragazzi
ho installato kodidirects sul mio snudai sr4 v2 con openpli 4 beta... ho installato tutto il software relativo ed il plugin qui allegato
mi aspettavo di vedere gli adone caricai ma se avvio kdidirects non c'è niente il lista
come si fa a caricare gli addons e dove li trovo? sto imparando scusatemi se la domanda è per voi banale grazie
aggiornamento
nel digitare i comandi con telnet si è riavviato ed i plug in modi sono andati in errore e spariti dall'elenco
non sono più scaricabili
che faccio?
grazie per aiuto
