SALVE, HO UN IBOX 3 PROBLEMATICO IN AVVIO.
Dopo programmato se lo spengo e riaccendo dal bottoncino dietro pare si riavvii (almeno ho provato svariate volte) ma se va via la corrente alla riaccensione si pianta sulla schermata "boot"
Ho fatto anche il reverse con il cypress portandolo di nuovo a 500 Mhz chissà fosse un problema di clock ma il problema è rimasto.
Ho fatto un log da seriale che vi incollo. Qualcuno ha idee?
Al punto "*** Waiting for system reset ***" si pianta.
Grazie in anticipo.
BCM73580001
1 00000001
234#!@
M0
SHMOO
WLCT 0000000001
SHMOO VER MSA 16b 1.12
PKID 16020112 20120406 003B6000 003B0000 001B103F 00001C00
S300001B3
S00001190
RDLY WL 0 0000000004
RDEN WL 0 0000000036
RDQS WL 0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ---------+++++++++++++++++++++++X++++++++++++++++++++++---------
01 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++
02 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
03 ----------+++++++++++++++++++++++X++++++++++++++++++++++--------
04 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------
05 ----------++++++++++++++++++++++++X+++++++++++++++++++++++------
06 ------+++++++++++++++++++++++X++++++++++++++++++++++------------
07 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
08 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
09 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
10 -------+++++++++++++++++++++++X+++++++++++++++++++++++----------
11 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
12 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
13 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------
14 ---------++++++++++++++++++++++++X+++++++++++++++++++++++-------
15 ----------++++++++++++++++++++++X++++++++++++++++++++++---------
P WL 0
00 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
02 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
03 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
04 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++
05 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
06 ------+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
07 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++++
08 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
09 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
10 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
11 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
12 ------+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
13 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++++
14 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
15 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
N WL 0
00 ------++++++++++++++++++++++++X++++++++++++++++++++++++---------
01 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
02 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
03 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
04 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
05 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
06 -----+++++++++++++++++++++++X+++++++++++++++++++++++------------
07 -------+++++++++++++++++++++++++X+++++++++++++++++++++++++------
08 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
10 -----++++++++++++++++++++++++X++++++++++++++++++++++++----------
11 ---------++++++++++++++++++++++++X+++++++++++++++++++++++-------
12 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
13 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
14 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------
15 -------++++++++++++++++++++++++X+++++++++++++++++++++++---------
WRDQ WL 0
00 +++++++++++++++++++++X+++++++++++++++++++++------+++++++++++++++
01 -++++++++++++++++++++++X+++++++++++++++++++++---------++++++++++
02 ++++++++++++++++++++++X++++++++++++++++++++++----+++++++++++++++
03 ++++++++++++++++++++++X+++++++++++++++++++++----++++++++++++++++
04 +++++++++++++++++++++X++++++++++++++++++++------++++++++++++++++
05 ++++++++++++++++++++++X+++++++++++++++++++++----++++++++++++++++
06 +++++++++++++++++++++X+++++++++++++++++++++------+++++++++++++++
07 ++++++++++++++++++++++X++++++++++++++++++++++----+++++++++++++++
08 +++++++++++++++++++++X+++++++++++++++++++++------+++++++++++++++
09 ++++++++++++++++++++++X+++++++++++++++++++++-----+++++++++++++++
10 ++++++++++++++++++++++X+++++++++++++++++++++-----+++++++++++++++
11 ++++++++++++++++++++++X+++++++++++++++++++++-----+++++++++++++++
12 +++++++++++++++++++++X+++++++++++++++++++++------+++++++++++++++
13 ++++++++++++++++++++++X+++++++++++++++++++++-----+++++++++++++++
14 ++++++++++++++++++++++X+++++++++++++++++++++----++++++++++++++++
15 +++++++++++++++++++++X+++++++++++++++++++++-----++++++++++++++++
WRDM WL 0 0000000021
ADDR
00 +++++++++++++++++S+++++++++X+++++++++++++++++++++++++++---------
B03B6054
5 7#!@#@
BCM97358A1 CFE v4.133, CFE core v4.27, Endian Mode: Little
Build Date: śro, 10 lip 2013, 10:17:09 CEST (hdx@unibox)
Copyright (C) Broadcom Corporation.
Enabling NAND flash at CS2.
BCHP_NAND_FLASH_DEVICE_ID =0x2cdc9095, BCHP_NAND_FLASH_DEVICE_ID_EXT = 0x5600000 0
MAC ADDRESS CHECKSUM FAILED.
MAC ADDRESS MUST BE PROGRAMMED!, using macprog command
CPU speed: 500MHz
Total memory(0): 512MB
DDR Freq: 800 MHz
DDR Mode: DDR3
MEMC 0 DEV SIZE: 2GBIT
MEMC 0 DDR Width:16
MEMC 0 DEV Width:8
Boot Device: SPI
Total flash: 4MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Root Hub
CFE initialized.
USB device matching <USB Disk> not found!
[FLASH-TOOL] Searching update files...
[FLASH-TOOL] Could not init file system: Device not found
[FLASH-TOOL] There are not any update files...
Booting...
Starting splash screen.
Found splash image - Width = 720 Height = 576
Non Interlaced Replace list 043e8680 0c800000Interlaced Replace list 043e8c20 0c 8005a0
Loader:elf Filesys:raw Dev:nandflash0.kernel File: Options:ubi.mtd=0 root=ubi0:r ootfs rootfstype=ubifs rw bmem=256M@512M
Loading: 0x80001000/7541016 0x80732118/112728 Entry address is 0x805b0960
Starting program at 0x805b0960
**Exception 32: EPC=805B0960, Cause=00008010, VAddr=8744F7FB
RA=8700AEEC, PRID=00029032
0 ($00) = 00000000 AT ($01) = B0410000
v0 ($02) = 00008000 v1 ($03) = 00000010
a0 ($04) = 87055170 a1 ($05) = 00000000
a2 ($06) = 8700AF60 a3 ($07) = 43464531
t0 ($08) = 805B0960 t1 ($09) = 80007FF0
t2 ($10) = FFFFFFF0 t3 ($11) = 87086948
t4 ($12) = 00000001 t5 ($13) = 8708EABB
t6 ($14) = 8700B3E4 t7 ($15) = 3EDB8C86
s0 ($16) = 8700AEEC s1 ($17) = 87010000
s2 ($18) = 00000000 s3 ($19) = 8700C154
s4 ($20) = 8744F998 s5 ($21) = 87086838
s6 ($22) = 00000000 s7 ($23) = 87032FD0
t8 ($24) = 0000002C t9 ($25) = 87086CB4
k0 ($26) = 87088DD0 k1 ($27) = 00000000
gp ($28) = 87055170 sp ($29) = 8744F7F8
fp ($30) = 870129A0 ra ($31) = 8700AEEC
@divin
come suggerito da @aviosat , questo è il link del forum ufficiale: http://forums.cloud-ibox.net/
Registrati e posta direttamente il log. Potresti anche non ricevere alcuna risposta ma sicuramente lo leggeranno :D
NB. Per curiosità, vai su
Conoscere il valore della Flash e della RAM
e posta qui i risultati. Almeno per avere un idea di quale decoder hai.
