ed eccovi l'ultimo uscito dalla cina sono stato contattato da un fornitore che mi ha inviato le caratteristiche di questo dec
penso che tra le varie cinesate sia molto buono
1200MHz Dual DMIPS Processor X SOLO mini 3 HD 1080P Satellite Receiver DVB-S2,DVB-T2/C Enigma2 Linux X SOLO mini3
X solo mini3
Ⅰ.General
1.Produce Type Name
Produce Type Number The STB,HD DIGITA DVB-S2 add an extra DVB-S2 or Hybrid C/T2
2.Main Features
STB Type X SOLO MINI3
Main Chipset BCM7362ZZKFEB3G
Func/Interface RCA with CVBS, HDMI,S/PDIF out , ETHERNET, DUAL USB , smart card
3.Special Features
Heatsinking Yes, Main Chip
Encrypt yes,
Video Modulator yes,
TUNER Type Integration in the main control chip
Demodulator Type Integration in the main control chip
Power Supply Input 100V ~ 240V 50/60Hz
Ⅱ.Software Features
1.Software General Features(DVB-S2,DVB-C/T2)
MPEG4 SD&HD-compatible/MPEG-2/MPEG4/H.264
Large memory and fast CPU Memory of 1 GB(512MB RAM & 512MB Flash),The CPU is a Dual 2000 Mipsel BCM processor
OSD Language Auto Languager seletion:English German French Portuguese Spanish Italian and so on
Linux OS Premium Twin HD is based in Linux and has many features that makes it unique.It supports HbbTV,YouTube,DLNA,has an embedded Media Player and a lot more.
Additional tuner Miraclebox Premium mini HD comes with one embedded DVB-S2 tuner.Despite its small size it is possibile to add an extra DVB-S2 or Hybrid C/T2 tuner.Combine it ad you want.
PIP PIP(picture in Picture)at the same transponder
HD 1080P HDMI-connection with Full HD 1080P
EPG Advanced EPG(Program Guide) Supported EPG recording/playback
Channel Search Channel search in automatic, manual and network search
Parental Ctrl Parental control for channels
Easy Menu Plug and Play installation, with an ease to use Menu System
SoftUpgrade Software upgrades through USB or RS232
ETHERNET 10/100Mbit Ethernet connection, Support youtube and network media, ***a*,Wireless Network with connected Miracle WIFI adapter
CAS 1×Smartcard readers
Hard-drive and recording 2× USB 2.0(1×Front and 1×Rear),You can easily connect an USB device,to record,Pause and playback
Ⅲ.Hardware Features
1.Front panel
Size L:225MM W:150MM H:45MM
LED One blue LED and one red LED.
USB USB 2.0 High Speed HOST
Smartcard Smart card slot (Xcrypt and Conax embeded)
IR 38KHz
1.Back panel
Output Interface Tuner A,TunerB, RCA with CVBS, HDMI,S/PDIF, RS232,ETHERNET,USB1(USB 2.0 High Speed HOST)
HDMI HDMI 576p, 720p, 1080i,1080P
3.STB Assembly
Configured according to customer requirements
5.Accessories
Cable1 HDMI Cable
Cable1 RS232 CABLE
power adapter 110-240V AC / 50-60Hz ,12V 2A
Remote 1XRemote control
IV.Electric Performance
1.Main Chip Sets
Flash Memory 4Gb Serial Flash(256MB×16)
DDR3 Memory 1Gb(256MB×4)
CPU 1200MHz Dual DMIPS Processor
Demodulator IC Integration in the main control chip
2.DVB-S2 Tuner
Tuner Type
Input Frequency Range 950MHZ-2150MHZ
Input Impedance 75Ω
RF input Signal LEVEL -80/-20dBM
Active Ant Power 13/18V DC 400mA MAX,Overload Protection
3.DVB-S2 Channel Decoder
Demod standard DVB-S2 Standard
MPEG Profile Level MPEG2 SD, MPEG2 HD, H.264/AVC SD, H.264/AVC HD,MPEG4 AVC/H264
Demodulation QPSK, 8PSK
FFT SIZE 2K,8K
Code Rate 1/2,2/3,3/4,5/6,7/8
Guard Intervals 1/4,1/8,1/16,1/32
4.DVB-T/T2/C Channel Decoder
Demod standard Fully integrated LNA,Tuner,DVB-T2 & DVB-T & DVB-C demodulators
DVB-T2 EN 302 755, Supports all DVB-T2 modes,including:Single and multiple-PLPs;678MHZ,QPSK,16QPSK,64QPSK,256QPSK
DVB-T EN 300 744,6/7/8MHZ,QPSK,16QPSK,64QPSK
DVB-C EM 302 429,8MHZ,16/32/64/128/256QPSK
5.USB Decode
DVR supporting Stereo/MONO/Left/Right
Media Supporting Dual USB2.0 Port, USB media player to playback the media in USB flash disk or USB HDD or USB card reader with memory card.
File system FAT12, FAT16, FAT32, NTFS (only support first partition)
USB2.0 High Speed HOST DVR with USB HDD, Time shifting with USB HDD
6.Video Decode
Video Decoding MPEG-2,MPEG-4 compatible
Input data rate 2-45 Msymb/s
Video Resolution 576p, 720p, 1080i,1080P
7.Audio Decode
Audio Decoding Dolby Digital,MPEG-4(AAC-HE) MPEG-1/2/3
Sound Mode LEFT/RIGHT/STEREO/MONO
Sampling Frequency 32/4.1/48kHz
8.AV Output
Video Bandwidth 5.5MHz(-3dB)
Video Impedance 75Ω
Video Voltage Level 1.0 Vp-p
Audio Freq. Range 20~20KHz
Audio Impedance 600Ω
Audio Voltage Level 2V rms(5.6Vp-p)
9.Environment
Input Voltage AC:110-240V / 50-60Hz ,DC:12V 2A
Consumption 35W Max / 1W Standby (it’s optional by customer’s board)
Temperature 0℃ to +50℃
Humidity <95%
X Mini sono i peggiori. Non ne comprerò mai più uno. Non è in grado di gestire la Digital Key che si impalla, a prescindere dall'immagine :mad:
arriva forse domani x solo mini 3...vorrei sapere di quale decoder è clone.
Per l'amico sopra: X SOLO MINI 2 gestisce senza problemi la digital key e le altre chiavette...basta leggere in giro per trovare la soluzione. Ciao
salve a tutti io ho un sunray mini pro hd con immagine openpli4.0 presa qui ovviamente, nn mi riconosce la mia usb dtt una nilox AF9035A led blu, qualcuno puo aiutarmi? grazie
daniele.giacomini ha scritto:salve a tutti io ho un sunray mini pro hd con immagine openpli4.0 presa qui ovviamente, nn mi riconosce la mia usb dtt una nilox AF9035A led blu, qualcuno puo aiutarmi? grazie
x quella pennetta unica soluzione è che devi mettere l'immagine black hole
daniele.giacomini ha scritto:ok c è un immagine bh con i*tv funzionante? io ho la 2.1.0.1 ma nn va
in questo caso x iptv devi mettere openpli di nemonyz , pero devi trovare una pennetta sky led blu x il digitale terrestre
dovrebbe essere il clone del MiracleBox Premium Mini PLUS
remotekontrol ha scritto:arriva forse domani x solo mini 3...vorrei sapere di quale decoder è clone.
per cortesia mi potresti dare una mano anche in pm per far andare il digitale terrestre su x solo mini 2,perche sto impazzendo ma non trovo la soluzione.grazie
i tratta di un nuovissimo ( e in questo momento introvabile ) decoder che può essere utilizzato per la visione dei canali della TV Terrestre e Satellitare in alta definizione, FTA ( FREE TO AIR ) o a pagamento con la propria tessera tramite slot e ricevere segnale satellitare e Terrestre in quanto ha 2 Tuner indipendenti Samsung.
All'interno è allocato una CPU Dual DMIPS Processor di ben 1200 mhz ( la più potente di tutti i suoi concorrenti di gamma tipo MAGICBOX e ZGEMMA che è da 750Mhz) , Flash Memory 4Gb Serial Flash(256MB16) e DDR3 Memory 1Gb(256MB4) ( ZGEMMA e MAGIC BOX hanno memoria Flash da 256MB e 512MB di Ram DDR3 ) ad altissima velocità e quanto permette anche l'uso del decoder come ricevitore IPTV per vedere i canali TV in streaming, attraverso la sola connessione internet. .
Si possono caricare immagini tipo Openpli o simili, e plug-in (tipo per aggiornare l'elenco dei canali ) per applicazioni software e la visione di film formato mkv, avi, divx, e altri, da hard disk o pendrive collegati alla porta Usb.
L'apparato dispone la presa di rete lan 100 mbs ( e anche di Wi-Fi a 150 Mbs tramite chiavetta NON fornita ) , questo permette il collegamento ad internet e l'installazione ovunque sia presente una rete LAN ( con cavo ) e se non lo fosse lo è possibile con la semplice rete wi-fi di casa utilizzando una chavetta wi-fi dongle .
Caratteristiche:
HDTV Receiver MHEG-2/4 H. 264
3D Ready
CPU 1200MHz Dual DMIPS Processor Linux OS
Later than 3.16xx Lnux kernel
Excellent sound quality in Dolby Digital
TWO DVBS2+T2 Tuner built-in, second tuner Samsung
HDMI Connection
AV Connection
USB PVR Support of external HDD (HDD Optional)
1xCardreader (MultiCAS)
2x USB 2.0
Ethernet access 10/100 Mbit
4Gb Seri
è il clone del miraclebox mini+...venduto con cpu 1200mhz, in realta' ha solo 750mhz...il tuner é marchiato samsung e fa per ora il suo lavoro egregiamente. No ventola, no display, led blu sia acceso che in standby...led rosso su deepstandby. La cartella per flashare deve essere nominata xsolomini3. Il link per scaricare i software è scritto sul decoder, vu-hd.com
oppure immagini per miraclebox mini+,openmb.net dovrebbe digerire anche la egami
  • 1
  • 2
  • 3
  • 4
  • 5
  • 9
AGGIORNAMENTO LISTE CANALI SAT+DTT Enigma2 [ 08 O[…]
Plugin creazione bouquet FTA
@diegomacielsc si certamente guarda il modo più[…]
@maveric2 buonasera, non credo che tu abbia cap[…]
@antonio-73 buonasera, per il decoder del tuo[…]
