salva una cortesia vorrei installare questo plugin nel dm800 italysat7 nella configurazione mi va in crash enigma2 con questo log che allego......se qualcuno mi spiega perché va in crash lo ringrazio...
[Skin] SKIN ERROR in screen 'PluginBrowser' widget 'widget': {MetrixHD/skin.xml}: source 'title' was not found in screen 'PluginBrowser'!. Please contact the skin's author!
[SCREENNAME]  PluginBrowserSummary
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:00:51.198568
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:00:59.539136
action ->  SetupActions cancel
unknown action SetupActions/cancel! typo in keymap?
action ->  WizardActions back
[SCREENNAME]  MenuSummary
[SCREENNAME]  ['menu_mainmenu', 'Menu']
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:00:59.830075
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:01:01.402154
action ->  OkCancelActions cancel
[SCREENNAME]  InfoBarSummary
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:01:01.749432
1 8b 1
KEY: 139 0 KEY_MENU MENU 2015-11-27 21:01:07.883465
action ->  InfobarMenuActions mainMenu
0 8b 1
KEY: 139 1 KEY_MENU MENU 2015-11-27 21:01:09.286374
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:01:10.537733
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:01:10.833547
1 67 1
KEY: 103 0 KEY_UP UP 2015-11-27 21:01:11.457286
0 67 1
KEY: 103 1 KEY_UP UP 2015-11-27 21:01:11.745259
1 160 1
KEY: 352 0 KEY_OK OK 2015-11-27 21:01:12.331082
action ->  OkCancelActions ok
[SCREENNAME]  ['menu_setup', 'Menu']
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:01:13.392948
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:01:14.601073
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:01:14.895917
1 69 1
KEY: 105 0 KEY_LEFT LEFT 2015-11-27 21:01:15.747419
0 69 1
KEY: 105 1 KEY_LEFT LEFT 2015-11-27 21:01:15.923425
1 160 1
KEY: 352 0 KEY_OK OK 2015-11-27 21:01:16.617207
[SCREENNAME]  ['menu_system', 'Menu']
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:01:17.572717
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:01:18.705231
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:01:18.875591
1 67 1
KEY: 103 0 KEY_UP UP 2015-11-27 21:01:19.631876
0 67 1
KEY: 103 1 KEY_UP UP 2015-11-27 21:01:19.935411
1 67 1
KEY: 103 0 KEY_UP UP 2015-11-27 21:01:20.806435
0 67 1
KEY: 103 1 KEY_UP UP 2015-11-27 21:01:21.093612
1 67 1
KEY: 103 0 KEY_UP UP 2015-11-27 21:01:22.616196
0 67 1
KEY: 103 1 KEY_UP UP 2015-11-27 21:01:22.900131
1 67 1
KEY: 103 0 KEY_UP UP 2015-11-27 21:01:23.059992
0 67 1
KEY: 103 1 KEY_UP UP 2015-11-27 21:01:23.227657
1 67 1
KEY: 103 0 KEY_UP UP 2015-11-27 21:01:23.475214
0 67 1
KEY: 103 1 KEY_UP UP 2015-11-27 21:01:23.643689
1 160 1
KEY: 352 0 KEY_OK OK 2015-11-27 21:01:24.634612
warning, skin is missing element HelpWindow in <class 'Screens.Setup.Setup'>
warning, skin is missing element footnote in <class 'Screens.Setup.Setup'>
[SCREENNAME]  SetupSummary
[SCREENNAME]  ['setup_usage', 'Setup']
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:01:25.612168
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:01:26.875157
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:01:27.160652
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:28.276509
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:28.446395
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:28.771955
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:28.938027
1 160 1
KEY: 352 0 KEY_OK OK 2015-11-27 21:01:29.356731
[SCREENNAME]  ['menu_extended', 'Menu']
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:01:30.266834
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:01:32.709261
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:01:32.880035
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:33.878723
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:34.051287
1 160 1
KEY: 352 0 KEY_OK OK 2015-11-27 21:01:34.547515
[SCREENNAME]  ['menu_epg', 'Menu']
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:01:35.578211
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:01:38.517723
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:01:38.692599
1 160 1
KEY: 352 0 KEY_OK OK 2015-11-27 21:01:39.448314
[Skin] Attribute not implemented: title value: XMLTV Import Configuration
warning, skin is missing element key_blue in <class 'Plugins.Extensions.XMLTVImport.plugin.EPGMainSetup'>
warning, skin is missing element key_yellow in <class 'Plugins.Extensions.XMLTVImport.plugin.EPGMainSetup'>
warning, skin is missing element key_green in <class 'Plugins.Extensions.XMLTVImport.plugin.EPGMainSetup'>
warning, skin is missing element key_red in <class 'Plugins.Extensions.XMLTVImport.plugin.EPGMainSetup'>
[SCREENNAME]  EPGMainSetup
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:01:40.398827
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:01:42.835959
action ->  SetupActions right
unknown action SetupActions/right! typo in keymap?
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:01:43.012030
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:43.857668
action ->  SetupActions down
unknown action SetupActions/down! typo in keymap?
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:44.026893
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:45.561255
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:45.733280
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:47.049588
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:47.217462
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:49.347846
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:49.635177
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:01:52.031579
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:01:52.185643
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2015-11-27 21:01:53.553349
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2015-11-27 21:01:53.720909
1 18f 1
KEY: 399 0 KEY_GREEN GREEN 2015-11-27 21:01:57.201645
action ->  ColorActions green
Plugin  Extensions/WebInterface failed to load: No module named plugin
0 18f 1
KEY: 399 1 KEY_GREEN GREEN 2015-11-27 21:01:58.235215
[XMLTVImport] WakeUpTime now set to 1448688840 (now=1448654518)
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:02:03.555077
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:02:03.849240
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:02:04.853964
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:02:05.144638
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:02:05.820593
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:02:06.235100
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:02:07.336434
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:02:07.781132
1 ae 1
KEY: 174 0 KEY_EXIT EXIT 2015-11-27 21:02:08.702312
0 ae 1
KEY: 174 1 KEY_EXIT EXIT 2015-11-27 21:02:09.050172
1 18f 1
KEY: 399 0 KEY_GREEN GREEN 2015-11-27 21:02:10.124101
0 18f 1
KEY: 399 1 KEY_GREEN GREEN 2015-11-27 21:02:10.277994
action ->  InfobarSubserviceSelectionActions GreenPressed
[Skin] SKIN ERROR in screen 'ItalyGreen' widget 'widget': {MetrixHD/skin.xml}: source 'title' was not found in screen 'ItalyGreen'!. Please contact the skin's author!
warning, skin is missing element key_blue in <class '**not-mention**.ItalysatGreen.ItalyGreen'>
warning, skin is missing element key_yellow in <class '**not-mention**.ItalysatGreen.ItalyGreen'>
warning, skin is missing element key_green in <class '**not-mention**.ItalysatGreen.ItalyGreen'>
warning, skin is missing element key_red in <class '**not-mention**.ItalysatGreen.ItalyGreen'>
warning, skin is missing element conn in <class '**not-mention**.ItalysatGreen.ItalyGreen'>
[SCREENNAME]  ['ItalyGreen_summary', 'SimpleSummary']
[SCREENNAME]  ItalyGreen
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2015-11-27 21:02:13.430469
action ->  WizardActions right
unknown action WizardActions/right! typo in keymap?
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2015-11-27 21:02:13.720365
1 160 1
KEY: 352 0 KEY_OK OK 2015-11-27 21:02:15.059273
action ->  WizardActions ok
0 160 1
KEY: 352 1 KEY_OK OK 2015-11-27 21:02:15.980165
1 166 1
KEY: 358 0 KEY_INFO INFO 2015-11-27 21:02:32.294436
action ->  SetupActions info
unknown action SetupActions/info! typo in keymap?
action ->  TimerEditActions log
warning, skin is missing element key_blue in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportLog'>
warning, skin is missing element key_yellow in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportLog'>
warning, skin is missing element key_green in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportLog'>
warning, skin is missing element key_red in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportLog'>
[SCREENNAME]  ['XMLTVImportLog_summary', 'SimpleSummary']
[SCREENNAME]  XMLTVImportLog
0 166 1
KEY: 358 1 KEY_INFO INFO 2015-11-27 21:02:32.952648
1 191 1
KEY: 401 0 KEY_BLUE BLUE 2015-11-27 21:02:47.802250
action ->  ColorActions blue
0 191 1
KEY: 401 1 KEY_BLUE BLUE 2015-11-27 21:02:48.057014
1 8a 1
KEY: 138 0 KEY_HELP 2015-11-27 21:02:51.474042
0 8a 1
KEY: 138 1 KEY_HELP 2015-11-27 21:02:51.640757
[SCREENNAME]  UnhandledKey
1 166 1
KEY: 358 0 KEY_INFO INFO 2015-11-27 21:02:54.106931
0 166 1
KEY: 358 1 KEY_INFO INFO 2015-11-27 21:02:54.712490
1 191 1
KEY: 401 0 KEY_BLUE BLUE 2015-11-27 21:02:58.841231
0 191 1
KEY: 401 1 KEY_BLUE BLUE 2015-11-27 21:02:59.137664
1 191 1
KEY: 401 0 KEY_BLUE BLUE 2015-11-27 21:03:00.462910
[XMLTVImport] failed to list /etc/xmltvimport Error: [Errno 2] No such file or directory: '/etc/xmltvimport'
warning, skin is missing element key_blue in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportSources'>
warning, skin is missing element key_yellow in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportSources'>
warning, skin is missing element key_green in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportSources'>
warning, skin is missing element key_red in <class 'Plugins.Extensions.XMLTVImport.plugin.XMLTVImportSources'>
Traceback (most recent call last):
  File "/usr/lib/enigma2/python/Components/ActionMap.py", line 48, in action
  File "/usr/lib/enigma2/python/Plugins/Extensions/XMLTVImport/plugin.py", line 248, in dosources
  File "/usr/lib/enigma2/python/mytest.py", line 353, in openWithCallback
    dlg = self.open(screen, *arguments, **kwargs)
  File "/usr/lib/enigma2/python/mytest.py", line 366, in open
    self.execBegin()
  File "/usr/lib/enigma2/python/mytest.py", line 250, in execBegin
    self.instantiateSummaryDialog(c)
  File "/usr/lib/enigma2/python/mytest.py", line 303, in instantiateSummaryDialog
    self.summary.show()
  File "/usr/lib/enigma2/python/Screens/Screen.py", line 157, in show
  File "/usr/lib/enigma2/python/Plugins/Extensions/XMLTVImport/plugin.py", line 614, in addWatcher
  File "/usr/lib/enigma2/python/Plugins/Extensions/XMLTVImport/plugin.py", line 621, in selectionChanged
  File "/usr/lib/enigma2/python/Plugins/Extensions/XMLTVImport/plugin.py", line 316, in getCurrentEntry
TypeError: 'NoneType' object has no attribute '__getitem__'
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0xa8bf08>>,('ColorActions', 'blue')) failed)
		</enigma2crashlog>
	</crashlogs>
</**not-mention**>
scusa....... comunque la special edition per i cloni e specificamente ferrari non va si blocca a metà del booting
Ben ti sta..mettiti un immagine diversa visto che ci dai pure dei ladri ma intanto vuoi l immagine.. Ancora non capisco come nel forum si dia supporto alla Italy sui box non zgemma. @nemoxyz
Inviato dal mio OnePlus One
Qui non diamo supporto alla **not-mention** non zgemma !! Lo sai bene !!! E' chiaro da sempre!!
Un risposta tecnica può capitare ma non è direttamente indirizzata ad un uso di una image impropria perchè difficile poter discernere.
Xmltv import non credo sia appannaggio unico della Italysat7 !???!!! Che poi l'utente abbia chiesto per quella specifica image è altro conto ed ok bene, lo hai fatto presente.
Ma come dicevamo nn c'è bisogno di discutere inutilmente @bobsilvio !!
Se avessi la pazienza di leggere i vari post disseminati nel sito è sempre consigliato sia da me che da @manutek che dai nostri collaboratori (@Moderatori @Moderatori globali ) di procedere verso il vostro sito per i dettagli e per il download "ufficiale" della image vostra senza sotterfugi !!
SEVERAMENTE !! IN RISPETTO DEL REGOLAMENTO NOSTRO E QUELLO DEL SITO OMONIMO **not-mention** ESPONGO PUBBLICAMENTE IL DINIEGO A QUALSIASI SUPPORTO VERSO IMAGE e/o backup **not-mention** NON-AUTORIZZATI !!!
Onde per cui @train ti invito a recarti presso il sito **not-mention**.eu per i dettagli e le delucidazioni del caso ed in completo rispetto delle regole.
Questo è detto per train ma è valevole per chiunque.
Cordialità , Nemoxyz.
Comunque io ho chiesto aiuto solo per il plugin (credo che si possa fare) poi mi è stato consigliato di installare la **not-mention** ( che è più preziosa di un diamante) ed ho scritto semplicemente che non andava tutto qui senza chiedere aiuto......... poi ogni volta devo essere cazziato per partito preso ok fatelo non problem
@train tu al momento che immagine hai? Hai usato un backup già precompilato o hai fatto il flash di un immagine pura e poi fatto il flash del SSL? In rete si trovano tante schifezze, converrebbe prendere l'immagine pura e poi farci il flash del SSL (per sim ferrari) e l'eventuale sostituzione dei driver pena la mancata riconoscenza del tuner.
Alternative sono:
1) Usare la **not-mention** -->>> VAI SU SITO OMONIMO -->> http://www.**not-mention**.eu ( per il completo supporto !!! ) ( *** mod by Nemoxyz )
2) L'alternativa a XMLTV è CrossEPG
3) Optare verso questo backup [dm800-sim2] openpli-4.0-dm800-20151101-sim2-ssl84d-digital-key-dtt-mod-by-CloudItaly
[war=]@train non mi pare di aver fatto "cazziatoni" !!! Ci manchebbe!!
( credo che tu abbia letto il mio posto giusto ??? ) Abbiamo risposto sul plugin in modo generico ed ok, per il resto ho scritto in merito alla condizione e come è giusto secondo regole comportarsi.Bobsilvio ha giustamente espresso un suo parere ( opinabile o meno non è questa la sede nè tantomeno abbiamo volontà di esprimerci) , essendo di sua proprietà ci atteniamo alle volontà senza discutere !! perchè a me le polemiche e le discussioni a distanza poco mi sconfinferano e non sono nè eleganti nè da persone mature, ed ad una certa età conveniamo tutti in completa amicizia che sarebbe davvero inutile.
Quindi atteniamoci alle cose giuste e corrette, prego!! Provvederò presto su tutto il nostro sito a d operare un controllo ed alcune scelte opportune al fine di non creare problemi.
Detto questo considero chiuso l'argomento.
PS: @clouditaly attieniamoci tutti !! Se si devi discutere di images non "free" **not-mention** rimanda l'utente in generale sul forum omonimo. Grazie per l'attenzione.
Saluti.[/war]
A parte tutto chiudiamola qua ..... E comunque non mi riferivo a te nemoxyz ma ad altri che ė meglio non nominare altrimenti succede un casino :-o :-o ma scrivere ben ti sta mi sa da bambino di cinque anni e senza e lo sottolineo e senza aver chiesto aiuto su quella immagine ( non nominiamola altrimenti la sciupiamo) era piu elegante non scrivere proprio secondo me poi ogniuno ė libero di fare e dire quello che vuole personalmente mangio dormo e vivo lo stesso :-) ps grazie cloudtaly provero il backup .......ps2 se ritenete opportuno lo potete proprio cancellare tutto il post o chiuderlo
Train ho letto il tuo messaggio anche sull' altro sito quindi c'è poco da parlare. Non fare il finto tonto. Ciao
