RELEASE SETTEMBRE 2016 ( V4 )
particolare backup Classic basato su OpenVIX 4.2 [ 005 ] SOFTWARE :
Nemoxyz-OpenVIX4.2-005-GST190-NOVUMslimHDOrangeLight-CLOUD-IBOX-3-series[16-09-2016]
[ backup by Nemoxyz - 16 Settembre 2016 - V4 ]
Versione proposta per decoder CLOUD-IBOX-3 SERIES
(CLOUD IBOX 3 / CLOUD-IBOX-E-se MINI )
https://i.imgur.com/oWiZGKph.jpg
OpenVIX 4.2 [001] NOVUM slim HD ORANGE light MOD - GST 1.9.0
https://i.imgur.com/yvUlhXl.jpg
BACKUP FEATURES ( data backup 16-09-2016 - V4 = aggiornamento a versione 4.2-005 - gst190 complete update ) :
  • Bootlogo OpenVIX 4.2 - NOVUM slim ORANGElightMOD - by Nemoxyz Design
  • SPINNER SAT.technology power
  • SKIN NOVUM SLIM HD orange light mod by Nemoxyz ( piccole correzioni nei colori )
  • host name = CLOUD-IBOX-3series
  • Password accesso FTP / OpenWebIF = cloudibox3
  • Codice PARENTAL CONTROL = 1357
  • GST 190 Gstreamer ultimissima aggiornata versione integrato in OpenVIX
  • POWER TIMER IMPOSTATO CON SPEGNIMENTO "DEEP-STANDBY DOPO 10MINUTI DALLO STAND-BY
  • EMC4.0 media player ehnanced -->> Tasto ROSSO ( telecomando cloud-ibox-3) !!!
  • TASTO giallo configurato con varie funzioni offerte dal software openVIX ( telecomando cloud-ibox-3 ) !!!
  • BWMON plugin BANDWIDTH MONITOR ( monitoraggio banda lan & wifi )
  • Xmltv importer ( EPG guide ) configurato con Rytec italy
  • isettingE2 3.3.8 (NUOVISSIMA VERSIONE DEL FAMOSO plugin!)
    Configurazione auto su ManuTEK+DTT - aggiornamento automatico 2volte al gg !!
  • Mono feed Hotbird 13° + ASTRA 19.2° + DTT italia nazionale ( manutek settings Nemoxyz Releaser )
  • [center-img]https://i.imgur.com/p347PpVh.jpg[/center-img] [center-img]https://i.imgur.com/mXiTAj5h.jpg[/center-img] [center-img]https://i.imgur.com/N8C6mhFh.jpg[/center-img] [center-img]https://i.imgur.com/YK0gkWah.jpg[/center-img] [center-img]https://i.imgur.com/AXGzMqeh.jpg[/center-img] [center-img]https://i.imgur.com/KUOb488h.jpg[/center-img] [center-img]https://i.imgur.com/Y1JLYxgh.jpg[/center-img] [center-img]https://i.imgur.com/Cxhbi0Gh.jpg[/center-img] [center-img]https://i.imgur.com/vfhyO8oh.jpg[/center-img] [center-img]https://i.imgur.com/vJwhjhsh.jpg[/center-img] [center-img]https://i.imgur.com/FT06sxKh.jpg[/center-img] [center-img]https://i.imgur.com/a0zm81Zh.jpg[/center-img] [center-img]https://i.imgur.com/XIasgrph.jpg[/center-img] [center-img]https://i.imgur.com/5VflSKfh.jpg[/center-img] [center-img]https://i.imgur.com/2CHWeA8h.jpg[/center-img] [center-img]https://i.imgur.com/1Sznmnxh.jpg[/center-img] [center-img]https://i.imgur.com/i0FigeFh.jpg[/center-img] [center-img]https://i.imgur.com/UrIdCRhh.png[/center-img] Qui sotto in download potrete scaricare il file compresso in RAR al cui interno troverete l'immagine backup in versione Flash by USB che potrete installare comodamente tramite il flashing via USB.[/b] [b][color=#FF0000][u]piccola guida per installazione:[/u][/color][/b] [b][i][list]
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "cloudix"
  • A DECODER SPENTO INSERITE LA PENNA USB NELL'APPOSITA PORTA ( suggerisco porta usb posteriore!!) ED ACCENDETE IL DECODER DAL BOTTONCINO POSTERIORE
  • ATTENDENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' PIU' E SUL VISORE DEL DECODER NON SARA' COMPARSA LA SCRITTA A LED "DONE"
  • A QUESTO PUNTO SPEGNETE IL DECODER DAL BOTTONCINO POSTERIORE RIMUOVETE LA PENNA USB E RIAVVIATE CON LA VOSTRA NUOVA IMMAGINE CARICATA!!
[/i][/b]
[/list][/b]
Versione: SET-2016-v4-GST190
Dimensione: 57.43 MB
Vedi Download: [BCKP] CLOUD-IBOX-3ser Nemoxyz OpenVIX-4.2 NOVUMslimHD orangeMOD
Modificato 7 volte da Nemoxyz 10 anni. Motivazione: Le informazioni sono state aggiornate
scusate, *************... eppure ho caricato tramite dcc nella cartella ETC il file epg. ************ pensavo fosse quedto il problema
[war=]@Perots
Lo vogliamo leggere il regolamento ???? :-o Argomento -->> **** borderline !! pleaseee !!![/war]
Per altro fai commistione con EPG = guida elettronica dei programmi con altro...forse non hai ben chiaro il tutto credo...
Per EPG e solo esclusivamente per quello ( attenendoci alle regole ) posso dirti che devi andare su pannello verde ( tasto verde / oppure menu-> plugins , e scaricare manualmente EPG tramite Xmltv EPG importer plugin -->> tasto giallo "manuale" )
ragazzi ho installato openvix bellissima !!! come mai quando spengo il dec dal telecomando poi lo riaccendo si riavvia sempre? non va in standby?
unaltra cosa quando effettuo l'aggiornamento della lista canli con isetting 3.3.8 mi rimane sempre quella di settembre? cosa sbaglio grazie
Che il decoder dopo averlo spento tu lo possa riaccendere @B3pPe è un bene!! :-D
A parte gli scherzi le impostazioni di questo backup sono che se premi il bottone va in standby semplice se vai da menu e metti menu standby -> deep standby si spegne totalmente. Per isettingE2 cosa ti dice messaggio errore ?? come effettui l'aggiornamento ??
Stamattina openvix non e' vuole proprio sapere di avviarsi il dec si blocca sul LOAD lo ravviato gia tre quattro volte ma niente
Forse e meglio ritornare a quello che avevo prima del 2011 andava perfetto
@B3pPe non dipende dal software credo ma da instabilità del tuo esemplare cloudibox3 ( non sarebbe il primo che si blocca in boot !!! ) prova con un backup diverso !!! openpli oppure openATV
Tornare al 2011 non credo sia "producente" :-o !! Saluti.
ma con quello non si e' bloccato mai
Messaggio aggiunto 3 minuti 29 secondi:
Nemoxyz ha scritto:@B3pPe non dipende dal software credo ma da instabilità del tuo esemplare cloudibox3 ( non sarebbe il primo che si blocca in boot !!! ) prova con un backup diverso !!! openpli oppure openATV
Che ne pensi di questo : [BCKP] CLOUD-IBOX-3 Series Nemoxyz BH2.1.7 METAL-IS-RedZ-v4-[B751]
NovembreV1
E' troppo old !!! :-o inoltre BH per cloudibox3 è un porting....ha molti bug insiti.
attualmente se dovessi consigliare una versione molto stabile senza dubbio ci sono qst tre di seguito sono le migliori a cui si possa aspirare :
il più veloce in assoluto ed anche molto stabile :
[BCKP] CLOUD-IBOX-3series Nemoxyz OpenPLi6.0 STABLERelease GST1.12 exteP3 NightSTALK-HD
i piu completi e molto stabili :
[BCKP] CLOUD-IBOX-3ser Nemoxyz OpenESI 7.0 GST1.15 GCSteel-StyleV3all
[PKCGsettings+BASEimg] CLOUD-IBOX-3series Nemoxyz OpenATV 6.3 GST1.17 exteP3 CBCgold Interstellar
Salve, ho appena caricato questa immagine, devo dire niente male proprio.
C'è un solo "piccolo" problema. In famiglia ho persone "ipovedenti" :D C'è modo di aumentare la dimensione del testo e del contrasto dello stesso? O in alternativa, c'è una skin per anziani? :D
Salve @PaoloPedro , se posso consigliarti la openpli NightstalkHD è migliore come backup ( perchè di backup si tratta e non di immagine !!! c'è differenza...) !! Sebbene questa openVIX se la cava egregiamente come hai avuto modo di notare tu stesso !!! Per il fattore aumento carattere è complicato se non quasi impossibile ( si dovrebbe mettere mano all'intera skin ) e sicuramente non si può operare tramite telecomando.
Negli addons cmq ( tasto verde downloads ) esiste la sezione skins , nella quale potrai trovare altre skin !! ma ti consiglio di valutare prima tramite nome e facendo una ricerca sulla tipologia di skin quale possa essere la migliore in qst caso particolare di "ipo-vedenti"
