Backups per decoder VUSOLO SERIES (PRO & MINI & CLOUDIBOXminisolo ) modelli che NON accettano FERRARI PATCH
BASE IMAGE: ( OpenPLi4 special software version mod GST191 + EPGxz ready )
Versione-BACKUP= Ver2 = 19 GENNAIO 2018 ( XCv5.3 )
DESCRIZIONE:
OTTIMIZZATA E SUPER STABILE VERSIONE BACKUP basata su image openPli4 mod con GST191 molto stabile e veloce
BACKUP STRUTTURATO su modelli VuSolo-SERIES
( Cloud Ibox / VuSolo-PRO / VuSolo-MINI / MAX Vu Solo / Sunray MINI solo / Sunray mini PRO etc etc )
VALIDO IN MODO UNIVERSALE SU TUTTI QUESTI MODELLI CHE NON-ACCETTANO LA FERRARI PATCH
SU CUI VA MEGLIO LA VERSIONE CON KERNEL ORIGINALE 3.1.1 pre Time-Bomb
DISPOSITIVO & MODELLO :
Adatto ad un dispositivo Enigma2 VuSOLO SERIES DRIVERS SAT+DTT USB TUNER correttamente installati
GSTREAMER PLAYER & KERNEL:
GST191 + gstreamer default
KERNEL 3.1.1
SKIN BACKUP:
NOME FILE in download:
Nemoxyz-OpenPLi4-GST191[noFER]-(isetE2-341+EPG+Bmon+SysT+XCv52)-VuSoloSERIES-IPTV&DTTready
[ backup by Nemoxyz - 19 GENNAIO 2018 ]
BACKUP FEATURES:
Piccola guida per l'installazione:
Vedi Download: [BCKP] VuSolo-SERIES Nemoxyz OpenPLi4 GST191 [noFER-k311] NightSTALKhd DTTready
RELEASE BACKUP con OFFICIAL SKIN SAT TECHNOLOGY by Nemoxyz DESIGN
VERSIONE SOFTWARE & SORGENTE (MOD & BASE-IMAGE):"the BEST SOLUTION FOR MULTIMEDIAL CONTENTs"
DESCRIZIONE:
KERNEL 3.1.1
SKIN BACKUP:
O p e n P L I 4 ------- SatTEK - NIGHTSTALK-HD
BACKUP FEATURES:
- New --->> Bootlogo --> NEW SAT.TECHNOLOGY NIGHTSTALK-HD ( Nemoxyz design )
- SPINNER NEW -->> SAT.TECHNOLOGY POWER "purple-neon" version NightSTALK-HD
- New Widgets & Labels introdotti ( esclusivi Nemoxyz modding della SKIN !! )[/color]
- DUAL Tuner COMBO SAT+ usb DTT AUTOMATICAMENTE SETTATO ( TUNER A SAT + TUNER B DTT )
- host name = VUSoloSERIES ( nome LAN - samba )
- IMPOSTATO AUTOSTANDBY DA MENU timer stand-by ( standby in 6 ore - 12:00 / 3:00 disaattivato ) !!!
- GSTREAMER ULTIMA VERSIONE disponibile GST191
- Nuovo VODplayer XCplugin v5.3 ( evoluzione del plugin XC mod by Lululla ) PER VISUALIZZAZIONE VOD ALLA MASSIMA VELOCITA' E FLUDITA'( versione multi per lo switch con apposito tasto e tante altre funzioni ) da configurare file xml in etc/enigma2/xc/ il file xml!! Il plugin consente un uso totale del decoder, perchè non disattiva il tuner fino alla partenza del contenuto multimediale ed in uscita tornerà sull'ultimo canale visualizzato!! Inoltre consente la visione offline scaricando il contenuto VOD per visionarlo in tempi diversi anche senza connessione!!
- EPGimporter setup , settato per il download giornaliero EPG new sources xz Rytec
( viewtopic.php?f=89&t=32006 ) - PLUGIN BANDWIDTH MONITOR : controllo della connessione e traffico internet ( LAN/WiFi )
- PLUGIN SWAP-MANAGER installato di base : per la gestione del file di SWAP ( necessita di installazione usb storage )
- PLUGIN MOUNT-MANAGER installato di base : per la gestione del dispositivo di storage
- isettingE2 3.4.1( configurazione auto su ManuTEK thanks to Diamondear !! PROVINCE DTT SELEZIONABILI !! )
- ManuTEK settings 17-01-2018 (NemoxyzSATtv SAT+DTT nazionale) CHANGELOG: blog/setting-e2-manutek/
- SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "vuplus"
- A DECODER SPENTO INSERITE LA PENNA USB NELL'APPOSITA PORTA ED ACCENDETE IL DECODER DAL BOTTONCINO POSTERIORE ( noterete il cambio colore led violaceo indice della condizione di flashing by usb )
- ATTENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA PIU' ED IL LED DEL VOSTRO DECODER CAMBIERA COLORE PER QUALCHE SECONDO (5-10sec) DI NUOVO ROSSO POI DI NUVO VIOLACEO E POI LED BLU LAMPEGGIANTE!!
- A QUESTO PUNTO SPEGNETE IL DECODER DAL BOTTONCINO POSTERIORE RIMUOVETE LA PENNA USB E RIAVVIATE CON LA VOSTRA NUOVA IMMAGINE CARICATA!!
- NON DISPERATE IL PRIMO AVVIO E' PIU' LUNGO E LO SCHERMO RIMANE NERO PER 15-20 SECONDI!!! MA POI PARTE IL WAIT LOGO ED IL BOOT !!
ASTRA 19.2 :XpiconS [220x132] ASTRA 19.2° UPDATE (19 MAGGIO 2026)
- DA MENU - PLUGIN NIGHSTALKHDWeather
- SEGUITE LE ISTRUZIONI A VIDEO ALL'INTERNO DEL PANNELLO DI SETUP DEL PLUGIN!! SALVATE E RIAVVIATE ED AVRETE LA VOSTRA LOCALITà METEO!!
Modificato 11 volte da Nemoxyz 9 anni.
PRODOTTI Hi-Tek MECOOL
GamsGo Accounts DAZN
Marketplace
SPORTsEvents EPGTracker
il CINEtip
