salve , da oggi non riesco piu ad accedere al plugin iSettings , dato che alcuni canali hanno perso sintonizzazione , mi da crash , come posso risolvere ?
OpenVIX immagine . grazie
Messaggio aggiunto 1 ora 48 minuti 2 secondi:
OpenViX Enigma2 Crashlog
Crashdate = Mer Dic 21 17:47:08 2016
Creator = OpenViX
Version = 4.1
Build = 001
Type = release
Machine = mbmini
URL = http://www.world-of-satellite.com
Compiled = Apr 11 2016
Skin = NOVUM_HD_Slim/skin.xml
Component = Enigma2
Kernel CMDline = ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw bmem=256M@512M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs bmem=256M@512M bmem=16M console=ttyS0,115200n8
Nim Sockets = NIM Socket 0:
	Type: DVB-S2
	Frontend_Device: 0
	I2C_Device: 0
NIM Socket 1:
	Type: DVB-T2
	Mode 0: DVB-T2
	Mode 2: DVB-C
	Frontend_Device: 1
	I2C_Device: 1
ux0
<  5561.594> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.595> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.596> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.596> [eEPGCache] next update in 2 sec
<  5561.596> [eDVBResourceManager] stop release channel timer
<  5561.597> [eDVBChannel] getDemux cap=00
<  5561.597> [eDVBServicePMTHandler] ok ... now we start!!
<  5561.597> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.597> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  5561.600> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.601> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5561.615> [Notifications] RemovePopup, id = ZapError
<  5561.616> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.617> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  5561.655> [eDVBServicePMTHandler] PATready
<  5561.655> [eDVBServicePMTHandler] use pmtpid 0450 for service_id 0d49
<  5561.655> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.655> [eDVBSectionReader] DMX_SET_FILTER pid=1104
<  5561.657> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.658> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  5561.665> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.665> [eDVBSectionReader] DMX_SET_FILTER pid=268
<  5561.668> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.668> [eDVBSectionReader] DMX_SET_FILTER pid=17
<  5561.674> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
<  5561.678> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.679> [eDVBSectionReader] DMX_SET_FILTER pid=6008
<  5561.685> [eDVBServicePlay] have 1 video stream(s) (0200), and 2 audio stream(s) (028b, 0292), and the pcr pid is 0200, and the text pid is ffffffff
<  5561.685> [eDVBChannel] getDemux cap=01
<  5561.685> [eDVBResourceManager] allocate demux cap=01
<  5561.685> [eDVBResourceManager] allocating shared demux adapter=0, demux=0, source=0
<  5561.724> [eTSMPEGDecoder] decoder state: play, vpid=0200, apid=028b
<  5561.725> [eDVBPCR0] DMX_SET_PES_FILTER pid=0x0200 ok
<  5561.725> [eDVBPCR0] DEMUX_START ok
<  5561.726> [eDVBAudio0] DMX_SET_PES_FILTER pid=0x028b ok
<  5561.726> [eDVBAudio0] DEMUX_START ok
<  5561.726> [eDVBAudio0] AUDIO_SET_BYPASS bypass=0 ok
<  5561.727> [eDVBAudio0] AUDIO_PAUSE ok
<  5561.727> [eDVBAudio0] AUDIO_PLAY ok
<  5561.734> [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
<  5561.735> [eDVBVideo] demux device: /dev/dvb/adapter0/demux0
<  5561.735> [eDVBVideo0] VIDEO_SET_STREAMTYPE 1 - ok
<  5561.735> [eDVBVideo0] DMX_SET_PES_FILTER pid=0x0200 ok
<  5561.735> [eDVBVideo0] DEMUX_START ok
<  5561.736> [eDVBVideo0] VIDEO_FREEZE ok
<  5561.736> [eDVBVideo0] VIDEO_PLAY ok
<  5561.743> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
<  5561.743> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
<  5561.743> [eDVBVideo0] VIDEO_CONTINUE ok
<  5561.743> [eDVBAudio0] AUDIO_CONTINUE ok
<  5561.743> [eDVBAudio0] AUDIO_CHANNEL_SELECT 0 ok
<  5561.748> [eDVBTeletextParser] Starting!
<  5561.748> [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
<  5561.748> [eDVBPESReader] Created. Opening demux
<  5561.748> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.749> [eDVBTeletextParser] created teletext subtitle PES reader!
<  5561.750> [eDVBPESReader] Created. Opening demux
<  5561.751> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.751> [eDVBTeletextParser] starting PES reader on pid=ffffffff
<  5561.754> [eDVBServicePlay] timeshift
<  5561.755> [eDVBServicePlay] timeshift not enough diskspace for timeshift! (less than 1GB)
<  5561.759> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5561.765> [eDVBServicePlay] timeshift
<  5561.767> [eDVBServicePlay] timeshift not enough diskspace for timeshift! (less than 1GB)
<  5561.768> [eDVBServicePlay] timeshift
<  5561.769> [eDVBServicePlay] timeshift not enough diskspace for timeshift! (less than 1GB)
<  5561.772> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5561.788> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.789> [eDVBSectionReader] DMX_SET_FILTER pid=6008
<  5561.874> [eDVBCAService] new service 1:0:19:D49:1450:13E:820000:0:0:0:
<  5561.874> [eDVBCAService] add demux 0 to slot 0 service 1:0:19:D49:1450:13E:820000:0:0:0:
<  5561.874> [eDVBCIInterfaces] gotPMT
<  5561.882> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.882> [eDVBSectionReader] DMX_SET_FILTER pid=1104
<  5561.917> [eDVBLocalTimerHandler] diff is -1
<  5561.917> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
<  5561.917> [eDVBLocalTimerHandler] set RTC Time
<  5561.921> [eDVBLocalTimerHandler] update RTC
<  5561.922> [eDVBLocalTimerHandler] time update to 16:57:06
<  5561.922> [eDVBLocalTimerHandler] m_time_difference is -1
<  5561.922> [eDVBLocalTimerHandler] set Linux Time
<  5561.924> [eDVBChannel] getDemux cap=00
<  5561.927> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5561.927> [eDVBSectionReader] DMX_SET_FILTER pid=1104
<  5561.930> [eDVBVideo0] VIDEO_GET_EVENT SIZE_CHANGED 65535x65535 aspect 3
<  5561.989> [eDVBVideo0] VIDEO_GET_EVENT FRAME_RATE_CHANGED 65535 fps
<  5561.991> [eDVBVideo0] VIDEO_GET_EVENT PROGRESSIVE_CHANGED 1
<  5561.996> [eDVBFrontend] set dynamic current limiting
<  5562.002> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5562.002> [eDVBSectionReader] DMX_SET_FILTER pid=1106
<  5562.010> [eDVBServicePMTHandler] sdt update done!
<  5562.115> [Dish] tuning failed
<  5562.163> [eInputDeviceInit] 1 191 1
<  5562.166> [InfoBarGenerics] KEY: 401 BLUE
<  5562.169> [ActionMap] ChannelSelectBaseActions showFavourites
<  5562.211> [eDVBVideo0] VIDEO_GET_EVENT PROGRESSIVE_CHANGED 0
<  5562.461> [eInputDeviceInit] 0 191 1
<  5562.464> [InfoBarGenerics] KEY: 401 BLUE
<  5562.729> [VideoHardware] setting aspect: 16:9
<  5562.731> [VideoHardware] setting wss: auto
<  5562.734> [VideoHardware] setting policy: bestfit
<  5562.737> [VideoHardware] setting policy2: letterbox
<  5562.834> [OnlineVersionCheck] PASSED: stable
<  5562.836> [OnlineVersionCheck] Stable
<  5562.837> [OnlineVersionCheck] Starting background check.
<  5562.841> [IPKG] executing opkg  --add-dest /:/ update
<  5562.842> [eConsoleAppContainer] Starting /bin/sh
<  5562.868> [Task] job Components.Task.Job name=OnlineVersionCheck #tasks=1 completed with [] in None
<  5562.913> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  5563.029> [IPKG] executing opkg  --add-dest /:/ list-upgradable
<  5563.030> [eConsoleAppContainer] Starting /bin/sh
<  5563.032> [eMainloop::processOneEvent] unhandled POLLERR/HUP/NVAL for fd 79(17)
<  5563.204> [OnlineVersionCheck] 1 Updates available
<  5563.205> [eMainloop::processOneEvent] unhandled POLLERR/HUP/NVAL for fd 79(17)
<  5563.604> [eEPGCache] start caching events(1482335828)
<  5563.604> [eDVBSectionReader] DMX_SET_FILTER pid=3842
<  5563.606> [eDVBSectionReader] DMX_SET_FILTER pid=3003
<  5563.615> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5563.618> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5563.622> [eDVBServicePlay] timeshift
<  5563.623> [eDVBServicePlay] timeshift not enough diskspace for timeshift! (less than 1GB)
<  5563.624> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5563.625> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5563.629> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5563.639> [eDVBSectionReader] DMX_SET_FILTER pid=700
<  5563.647> [eDVBSectionReader] DMX_SET_FILTER pid=700
<  5563.652> [eDVBVideo0] VIDEO_GET_EVENT <  5563.652> [eDVBSectionReader] DMX_SET_FILTER pid=5000
SIZE_CHANGED 1920x1080 aspect 3
<  5563.659> [eDVBSectionReader] DMX_SET_FILTER pid=5000
<  5563.668> [eDVBSectionReader] DMX_SET_FILTER pid=57
<  5563.740> [eDVBVideo0] VIDEO_GET_EVENT FRAME_RATE_CHANGED 25000 fps
<  5564.258> [VideoHardware] setting aspect: 16:9
<  5564.260> [VideoHardware] setting wss: auto
<  5564.262> [VideoHardware] setting policy: bestfit
<  5564.265> [VideoHardware] setting policy2: letterbox
<  5564.625> [eDVBServicePlay] timeshift
<  5564.627> [eDVBServicePlay] timeshift not enough diskspace for timeshift! (less than 1GB)
<  5570.681> [eEPGCache] abort non avail virgin nownext reading
<  5570.685> [eEPGCache] abort non avail virgin schedule reading
<  5570.687> [eEPGCache] abort non avail netmed schedule reading
<  5570.690> [eEPGCache] abort non avail netmed schedule other reading
<  5570.692> [eEPGCache] abort non avail FreeSat schedule_other reading
<  5570.695> [eEPGCache] abort non avail viasat reading
<  5573.797> [eDVBServicePMTHandler] AITready
<  5579.164> [eEPGCache] nownext finished(1482335843)
<  5580.604> [eEPGCache] schedule finished(1482335845)
<  5612.868> [eEPGCache] schedule other finished(1482335877)
<  5612.873> [eEPGCache] stop caching events(1482335877)
<  5612.874> [eEPGCache] next update in 60 min
<  5673.467> [eInputDeviceInit] 1 ae 1
<  5673.480> [InfoBarGenerics] KEY: 174 EXIT
<  5673.484> [ActionMap] OkCancelActions cancel
<  5673.720> [eInputDeviceInit] 0 ae 1
<  5673.727> [InfoBarGenerics] KEY: 174 EXIT
<  5719.827> [AutoTimer] Auto Poll
<  5719.830> [AutoTimer] Auto Poll Started
<  5719.870> [Task] job Components.Task.Job name=AutoTimer #tasks=0 completed with [] in None
<  5919.097> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  6279.158> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  6461.925> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  6461.925> [eDVBSectionReader] DMX_SET_FILTER pid=20
<  6462.761> [eDVBLocalTimerHandler] diff is 0
<  6462.761> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
<  6462.762> [eDVBLocalTimerHandler] not changed
<  6462.764> [eDVBChannel] getDemux cap=00
<  6639.213> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  6999.263> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  7357.677> [NetworkTime] setting E2 time: 1482337622.08
<  7357.681> set RTC to 2016/12/21 17:27 (rtc_offset = 3600 sec.)
<  7359.375> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  7362.764> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  7362.765> [eDVBSectionReader] DMX_SET_FILTER pid=20
<  7363.696> [eDVBLocalTimerHandler] diff is 0
<  7363.697> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
<  7363.697> [eDVBLocalTimerHandler] not changed
<  7363.699> [eDVBChannel] getDemux cap=00
<  7519.874> [AutoTimer] Auto Poll
<  7519.876> [AutoTimer] Auto Poll Started
<  7519.881> [AutoTimer] No changes in configuration, won't parse
<  7519.902> [Task] job Components.Task.Job name=AutoTimer #tasks=0 completed with [] in None
<  7719.432> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  8079.471> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  8263.699> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  8263.700> [eDVBSectionReader] DMX_SET_FILTER pid=20
<  8264.630> [eDVBLocalTimerHandler] diff is 0
<  8264.630> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
<  8264.630> [eDVBLocalTimerHandler] not changed
<  8264.632> [eDVBChannel] getDemux cap=00
<  8439.530> [Task] job Components.Task.Job name=Controllo so***m #tasks=1 completed with [] in None
<  8537.125> [eInputDeviceInit] 1 8b 1
<  8537.129> [InfoBarGenerics] KEY: 139 MENU
<  8537.131> [ActionMap] InfobarMenuActions mainMenu
<  8537.213> [Skin] processing screen Menu:
<  8537.556> [Skin] processing screen MenuSummary:
<  8537.603> [eInputDeviceInit] 0 8b 1
<  8537.606> [InfoBarGenerics] KEY: 139 MENU
<  8537.817> [eTextPara] FONT 'RobotoCond' MISSING!
<  8540.146> [eInputDeviceInit] 1 6c 1
<  8540.149> [InfoBarGenerics] KEY: 108 DOWN
<  8540.444> [eInputDeviceInit] 0 6c 1
<  8540.447> [InfoBarGenerics] KEY: 108 DOWN
<  8540.596> [eInputDeviceInit] 1 6c 1
<  8540.599> [InfoBarGenerics] KEY: 108 DOWN
<  8540.781> [eInputDeviceInit] 0 6c 1
<  8540.783> [InfoBarGenerics] KEY: 108 DOWN
<  8540.962> [eInputDeviceInit] 1 6c 1
<  8540.965> [InfoBarGenerics] KEY: 108 DOWN
<  8541.156> [eInputDeviceInit] 0 6c 1
<  8541.165> [InfoBarGenerics] KEY: 108 DOWN
<  8541.533> [eInputDeviceInit] 1 160 1
<  8541.537> [InfoBarGenerics] KEY: 352 OK
<  8541.539> [ActionMap] OkCancelActions ok
<  8541.566> [Skin] processing screen PluginBrowser:
<  8541.831> [Skin] processing screen PluginBrowserSummary:
<  8541.970> [eInputDeviceInit] 0 160 1
<  8541.977> [InfoBarGenerics] KEY: 352 OK
<  8544.363> [eInputDeviceInit] 1 6c 1
<  8544.375> [InfoBarGenerics] KEY: 108 DOWN
<  8544.555> [eInputDeviceInit] 0 6c 1
<  8544.563> [InfoBarGenerics] KEY: 108 DOWN
<  8545.576> [eInputDeviceInit] 1 67 1
<  8545.580> [InfoBarGenerics] KEY: 103 UP
<  8545.873> [eInputDeviceInit] 0 67 1
<  8545.876> [InfoBarGenerics] KEY: 103 UP
<  8549.051> [eInputDeviceInit] 1 18f 1
<  8549.055> [InfoBarGenerics] KEY: 399 GREEN
<  8549.348> [eInputDeviceInit] 0 18f 1
<  8549.350> [InfoBarGenerics] KEY: 399 GREEN
<  8549.363> [ActionMap] ColorActions green
<  8549.384> [Skin] processing screen PluginDownloadBrowser:
<  8549.530> [OnlineVersionCheck] Checking feeds state
<  8549.891> [OnlineVersionCheck] PASSED: stable
<  8549.893> [OnlineVersionCheck] Check already in progress
<  8549.898> [OnlineVersionCheck] Checking feeds state
<  8550.145> [OnlineVersionCheck] PASSED: stable
<  8550.146> [OnlineVersionCheck] Check already in progress
<  8550.164> [Skin] processing screen SimpleSummary:
<  8557.732> [eInputDeviceInit] 1 ae 1
<  8557.734> [InfoBarGenerics] KEY: 174 EXIT
<  8557.738> [ActionMap] WizardActions back
<  8558.047> [PluginComponent] Plugin  Extensions/WebInterface failed to load: No module named plugin
<  8559.244> [eInputDeviceInit] 0 ae 1
<  8559.247> [InfoBarGenerics] KEY: 174 EXIT
<  8560.973> [eInputDeviceInit] 1 6c 1
<  8560.976> [InfoBarGenerics] KEY: 108 DOWN
<  8561.271> [eInputDeviceInit] 0 6c 1
<  8561.275> [InfoBarGenerics] KEY: 108 DOWN
<  8562.224> [eInputDeviceInit] 1 67 1
<  8562.230> [InfoBarGenerics] KEY: 103 UP
<  8562.521> [eInputDeviceInit] 0 67 1
<  8562.524> [InfoBarGenerics] KEY: 103 UP
<  8563.243> [eInputDeviceInit] 1 160 1
<  8563.247> [InfoBarGenerics] KEY: 352 OK
<  8563.248> [ActionMap] WizardActions ok
<  8563.432> [Skin] Parsing embedded skin <embedded-in-'iSettingE2Main'>
<  8563.448> [Skin] processing screen <embedded-in-'iSettingE2Main'>:
<  8563.850> [Skin] processing screen SimpleSummary:
<  8564.427> Traceback (most recent call last):
<  8564.428>   File "/usr/lib/enigma2/python/Components/ActionMap.py", line 48, in action
<  8564.430>   File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 143, in save
<  8564.431>   File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 147, in run
<  8564.432>   File "/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/plugin.py", line 3097, in PluginMain
<  8564.433>   File "/usr/lib/enigma2/python/mytest.py", line 320, in open
<  8564.435>     self.execBegin()
<  8564.435>   File "/usr/lib/enigma2/python/mytest.py", line 235, in execBegin
<  8564.438>     c.execBegin()
<  8564.441>   File "/usr/lib/enigma2/python/Screens/Screen.py", line 98, in execBegin
<  8564.443>   File "/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/plugin.py", line 1768, in Start
<  8564.444>   File "/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_StartMenu.py", line 317, in MainSetup
<  8564.445>   File "/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Librerie.py", line 1190, in save
<  8564.447> IOError: [Errno 30] Read-only file system: '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Conf/iSettingE2.config'
<  8564.448> [ePyObject] (CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x704dc990>>,('WizardActions', 'ok')) failed)
@LABATI esiste il BBcode ( codice ) se non scrivi certi papelli illegibili !!!
guarda come ho fatto io !!
Se hai problemi con isettingE2 forse l'agg alla versione 3.3.9 non è andato in porto bene se non lo riesci ad usare completamente !!
Se invece è solo crash risolvi reimpostando il settingman ( tipo manutek + DTT e scegli località tua e dai ok !! ) e poi impostando gli orologi !!
La versione 339 ha comportato grandi modifiche strutturali e necessita di essere reimpostato il plugin.
Grazie Nemo il problema è che non riesco ad entrarci nel plugin xche crasha .. forse togliendo il cavo di rete riesco ?
Di nulla siamo qui per aiutare! rimuovi il plugin , reinstallalo ed aggiornalo!! fai la cosa migliore !!
Se anche così nn va consiglio reflash del decoder !!
installato nuova immagine OpenVIX 4.2 , plugin 3.38 iSettings , probabilmente la 3.39 aveva qualche difetto (o meglio il dec non la digeriva bene)
Grazie ancora
@LABATI ti ricordo come già detto che l'aggiornamento alla 339 determina un blocco di sistema isettingE2 non riesce ad accedere al download degli aggiornamenti, in molti casi e con diversi decoders.
L'unica via è quella di reimpostare orologi di isettingE2 e reimpostare il settingman ( tipo clouditaly o manutek + dtt scegliendo la località ).
E tutto torna perfettamente funzionante, questo perchè il 339 è stato un agg sostanziale e strutturale per cui necessità di una reimpostazione il plugin. Saluti.
