Notepad++ 6.6.2
Notepad++ v6.6.2 bug fixes:
Quote:
1. Fix session snapshot enabled issue even "remember current session" option is disabled.
Notepad++ v6.6.1 bug fixes:
Quote:
1. Fix Notepad++ hanging issue while saving a large file if session snapshot feature is on.
Notepad++ v6.6 new features and bug fixes:
Quote:
1. Add session snapshot and periodic backup feature.
2. Fix RTL/LTR command making mirrored text bug.
3. Make auto-detect character encoding optional.
4. Apply DPI-aware on find & replace dialog tab and User define language dialog tab.
5. Add shell script parser for the function list.
6. Make backslash as an escape character optional in SQL.
Iscriviti su Telegram
