Sezione dedicata ai decoder dm900 UHD 4K ( single & combo tuner: sat e dtt )
Nome: [IMAGE] dm900 UHD 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 08-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 DM900 ( CPU ARM )
https://i.imgur.com/5TO59hj.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [08-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-dm900-20251108_mmc.zip
Dimensione: 135.9 MB
Vedi Download: [IMAGE] dm900 UHD 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 13 volte da Nemoxyz 9 anni. Motivazione: Download Aggiornato
Ciao a tutti
Ho scaricato questa versione come da titolo e come da immagine alleagta ho la visione molto sfarfallata e i canali qualunque pigio non si vedono
avete quale coluzione oppure mi fareste avere il comando per disinstallarlo??
Attendo notizie Grazie
@annibal per prima cosa per allegare images devi seguire queste istruzioni non usare allegato normale quello serve per file zip o rar ! per immagini si usa shell "invia immagine"
L'invio dei files immagini è preferibile farlo tramite servizio "IMGur"in questo modo
Spoiler
Dal quick reply
Oppure da Editor completo
La prossima volta posta sotto il topic dedicato alla image package settings di cui parli non serve scrivere esternamente, ti ho spostato io ma facciamo attenzione,please!
Per quanto riguarda il tuo problema cambia risoluzione imposta 1080i 50Hz !! metti hdmi 1080p multi e vedi se ti va bene o risoluzione migliore per il tuo decoder 2180p !! il tutto da menu impostazioni video.
Per disinstallare devi reinstallare la image completamente.
