Sezione dedicata ai decoder AMIKO VIPER COMBO ( combo tuner: sat e dtt )
Nome: [IMAGE] AMIKO Viper COMBO Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 03-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 AMIKO VIPER COMBO ( CPU MIPS )
https://i.imgur.com/TX8lApj.jpg
FEATURES:
iSettingE2 OE2.x - NEW VER - v3.6.3r1 - ( 09 MAGGIO 2025 )
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [03-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-vipercombo-20251103_usb.zip
Dimensione: 145.77 MB
Vedi Download: [IMAGE] AMIKO Viper COMBO Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 16 volte da Nemoxyz 8 anni. Motivazione: Download Aggiornato
Salve, la procedura che seguo per installare il firmware non parte, cioè viene indicato di inserire la pendrive con il firmware nella porta usb del dec e accenderlo tenendo premuto il pulsante ma tenendolo premuto il dec si avvia normalmente senza che succede nulla... cosa sto sbagliando? Grazie
@Zalvo82 leggi meglio la descrizione !! non hai capito molto bene !! devi installare la image base e poi il file IPK di configurazione pacakge settings !! Questo non è un backup è un package!! Saluti.
Perdonami , il problema è non mi si installa appunto la image base 6.2. Seguendo la procedura descritta cioè inserisco la pendrive e accendo il decoder tenendo premuto il pulsante di accensione non succede nulla, il decoder si accende è comincia a funzionare normalmente con la 6.0
provato... :-( niente. Hai una guida completa per reinstallare il firmware del Amiko Viper Combo?
Non esiste una guida completa!!! quello che fai è quello corretto !! devi considerare il fatto che la tua penna usb potrebbe essersi corrotta e non venire considerata come usb !! per cui la devi formattare in FAT32 in modo completo e riprovare !! Saluti.
Ciao ragazzi, dopo aver seguito passo-passo la guida e quindi installato correttamente la rom e configurato allo stesso modo il******sto riscontrando *******, difetto che con il vecchio decoder non accadeva.
Probabilmente sbaglio qualcosa? Consigli per favore?
Salve buonasera ci sono dei problemi con questi setting con la software quando si accende dopo un deep standbye putroppo. :cr1:
@TheMask ma che vuol dire ?? non si capisce...." dei problemi" è molto generico....se spieghi meglio forse riesco ad aiutarti o capire cosa accade!! ma così davvero è complicato !! Attendo tue info !! saluti.
Nemoxyz ha scritto: 7 anni @TheMask ma che vuol dire ?? non si capisce...." dei problemi" è molto generico....se spieghi meglio forse riesco ad aiutarti o capire cosa accade!! ma così davvero è complicato !! Attendo tue info !! saluti.
Purtroppo non posso spiegartelo meglio di così basta che vedi perché ho usato quell'articolo "la" piuttosto che "il" e capisci. Capita sia con la openpli che con ATV va a scatti dopo un deepstandbye mentre se riavvio di nuovo è tutto ok. Qualsiasi permessi inserisco nel file. Se puoi mi scrivi in pvt e ti ringrazio di cuore. Se è un problema comune ed irrisolvibile questo decoder non deve essere più consigliato.
@TheMask non è un fatto di "articolo" è che tu hai scritto da problemi !! Ed allora mi sono chiesto quali problemi ??? ora hai spiegato in dettaglio " va a scatti dopo un deepstandbye " qst già è più preciso !!! Non capisco cosa va a scatti ?? la fruzione del decoder ?? i canali che vedi ?? o cos'altro ?? non ho capito...
Ad ogni modo è un problema che stai vivendo tu personalmente molti altri utenti che usano il decoder gli va perfetto !!!
Come leggi nella mia firma e come da regolamento non facciamo customare-care in pvt !! Esiste però la sezione dedicata agli utenti deluxe ( essendo tu un deluxe la puoi eventualmente usare !! ) Ad ogni modo ci tengo a precisare che un "deepstandby" è una chiusura totale del decoder ed equivale poi a riavviarlo totalmente quando lo riaccendi, per cui le due cose che dici " dopo deepstandby" e "dopo riavvio" sono la stessa cosa in termini di booting del device.
Potrebbe dipendere da qualcosa di esterno...se dopo un riavvio va ttt ok !! Se fosse interno il problema si ripresenterebbe dopo il riavvio a mio avviso...ma cmq continuo a non cogliere esattamente il problema e me ne dispiaccio perchè non posso essere maggiormente di aiuto !! dovrei vedere il sintomo per capire.. Saluti.
@silvio1963 buongiorno la procedura te l'avevo i[…]
