For more information about the plugin:
With the Help button, the plugin can be checked for updates.
It can manage up to 4 different Facebook profiles. Each profile has its own setup (menu button) and can also be protected with a separate PIN. The PIN will be disabled if you set this to 0000 (default setting).
If you want to only use a profile that can be setup in the profile 'single logon checkbox. Then when you start eliminating the profile selection.
The Facebook password is encrypted in the file Enigma / etc/enigma2/settings saved.
With the OK button you can switch to the profile of the sender of the mail or the post.
Using the info button, the contents of the highlighted Facebook mail is displayed.
Otherwise, the respective controls during the plugin is displayed directly.
Version 1.2:rc6
http://speedy.sh/sEPSS/enigma2-plugin-extensions-facebook-1.2rc6-mips32el.ipk.zip
Version 1.4:
Update: Photos, profiles and mails after changes on the Facebook mobile site
Thx kashmir
http://speedy.sh/JknCS/enigma2-plugin-extensions-facebook-1.4-mips32el.zip
[private post]
@Wrestler ah ottimo ora la mettiamo in risalto […]
@mister alfa buonasera prova ad utilizzare s[…]
@Alessandro Mazzei mi fa molto piacere, buon […]
