Sezione dedicata ai decoder OCTAGON SF-8008 Combo DVBS2X DVBT2 4K UHD 2160p
OCTAGON SF8008 4K UHD E2 Updates 07.04.2019
- Scansetup fix BSOD remove old code (T2-MI)
- T2MI Scan improved:
- Normal + Blindscan
- FileCommander Plugin Support
- VFD Display Control: some fine tuning to adapt for sf8008
ready in images!
OCTAGON GERMANY SUPPORT
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 08.04.2019
- Sound problem from Stand-by fixed.
- Standby looses audio fixed.
File link >>>> QUI
FTP install:
hi-dvb.ko --> /lib/modules/4.4.35/extra
Telnet & Putty:
a) killall -9 libreader
b) libreader --> /usr/bin (ftp)
c) Box neustarten (restart Box)
Ab morgen Images.
From tomorrow Images.
Yarinki imajlardan itibaren.
OCTAGON SF8008 4K UHD E2 Updates 10.04.2019
- Add Inverto IDLU-UST110-CUO4O-32P (Unicable)
- add missing dat time changes
- [FileCommander] add path to script parameter
- [FileCommander] fix title for translation
- [FileCommander] fix possible bs
- [FileCommander] add setTitle in FileCommanderContextMenu
- eDVBFrontendParameters FEC add.
- scanStatusChanged update
- eDVBTSTools update
- EPGlist update
- Movielist update
- Addons key actions update
- [T2MI] ScanSetup.py: fix selecting wrong T2MI transponder
- Add missing FECs for dvb-c2/t2/s2
- ServiceScan update
- ScanSetup update
- Transponder parameter update
- Fix rewind freeze
in today images!
Ha scritto dopo 1 minuto 45 secondi:
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 11.04.2019
- Media Playback Jump Button issue fixed.
- TimeShift improved
- PowerLED Control Update:
- echo "on" > /proc/stb/fp/standbyled
- echo "off" > /proc/stb/fp/standbyled
- /proc/stb/fp/standbyled for RED
- /proc/stb/fp/poweronled for BLUE
- /proc/stb/fp/mixerled for PURPLE
FTP install:
hi-dvb.ko + vtunerc.ko --> /lib/modules/4.4.35/extra
Telnet & Putty:
Ab morgen in den Images!
From tomorrow in images!
Yarinki imajlardan itibaren!
LINK >>>>> http://ceesty.com/wNNwEE
Ha scritto dopo 6 minuti 25 secondi:
OCTAGON GERMANY News;
COMING Soon
OCTAGON SF8008 4K UHD E2 DVB-S2X Twin
OCTAGON SX888 IP WL H.265
OCTAGON SX88+ SE H.265
OCTAGON SX88+ SE WL H.265
OCTAGON GERMAMY:
https://www.octagon-germany.eu/
E-Mail:
support@octagon-germany.de
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 15.04.2019
- fix a crash problem, a random crash not all time
- try to improve rewind forward
- try to fix wrong PTS
- try to fix Kodi stutter issue
OCTAGON SF8008 4K UHD E2 Updates 23.04.2019
What's new ;
- add fastboot and bootargs to usb image
- need when box no bootup (no need hitool)
- [rt8723bs] disable powermanagement
-Aggiornamenti sono inclusi nelle immagini di oggi. Fastboot e bootarg sono ora disponibili
le immagini. Quindi se l'octagon non dovesse avviarsi per nessuna ragione non lo fa
deve essere riparato con rs232, via USB sarà sufficiente.
German;
-Updates sind in heute Images enthalten. Fastboot und bootargs sind jetzt
in den images dabei. So wenn die box aus irgendwelchen gründen nicht
mehr booten sollte muss es nicht mehr mit rs232 repariert werden,
sondern per USB reicht dann aus.
English;
-Updates are included in today's images. Fastboot and bootargs are now in
the images. So if the box should not boot for any reason it does not
have to be repaired with rs232, via USB will be enough.
Turkish;
-Güncel imajlarda Fastboot ve bootargs yazilima dahil edilmistir
Cihaziniz herhanki bir nedenden acilmazsa rs232 gerek kalmadan USB
bellek ile tamir edebilirsiniz.
OCTAGON SF8008 4K UHD E2 Updates 24.04.2019
What's New ;
- Blindscan Update:
- [blindscan] fix bsod with openatv and dvb-s with wrong config
- Software Manager (Flash Online):
- fix BSOD then get io error open STARTUP files
- about fix startup infos for new multiboot images
- Blindscan Verbesserung: Tuner Konfiguration fix. für einzel Tuner & Twin Tuner Nutzung (SF8008 Single Combo, Twin)
Ab morgen Images!
From tomorrow Images!
OCTAGON SF8008 4K UHD E2 Updates 01.05.2019
whats'new ;
- RDS Info for Radio Ch. fix.
- exteplayer3 fix.
- webkithbbtv update
- python-youtube-dl update
- BlindScan fix BSOF for non legacy images
Ab heute Images!
From today Images!
Bugünki Imajlardan itibaren!
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 05.05.2019
What's New ;
- AGC fix. for DVB-S/S2/S2X (for SF8008 SINGLE/TWIN/COMBO).
FTP install:
a.) hi-dvb.ko --> /lib/modules/4.4.35/extra
b.) Box neustarten (restart Box)
Sieh hier gut aus. Wenn feedback auch gut können wir veröffentlichen.
Here looks good. After get good feedbacks we will realese.
link download FILE drivers tuners
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 06.05.2019
- [sf8008] update ir drivers
- New Online/Local Flash Menu
- New Complete Backup Menu
- Install Full Backup Image from Power Button Standby Menu
- [multiboot] add MessageBox before reboot
- [sf8008] update ir treiber
- Neues Online/Lokal Flash Menü
- Neues Vollständige Menü
- Voll Backup Installation mit Power Taste (Boot Menü) eingebaut
- [multiboot] Info Popup bevor Neustart eingefügt
- [sf8008] ir sürümü güncellendi
- Yeni Cevrimici flas Menüsü eklendi
- Yeni Tam (tüm) Yedekleme Menüsü eklendi
- Tüm Backup Imajinizi Power tusuna basark Imaj gibi yükleme imkani eklendi
- Bilgi: Bu Drivers ile Artık Flash Online Yerine Tüm yazılım ve Backup Dosyalarını Öndeki Düğmeye 30 Sn. Basılı Tutup Açılan Boot Ekranında Recovery Menüsünden Yükleyebilirsiniz.
- [multiboot] cihazi baslatmadan önce Bilgi mesja ekrani eklendi
Ab heute Images!
From today Images!
Bugünki imajlardan itibaren!
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 08.05.2019
What's new ;
- Fixed AGC % percent value
- Fixed a assert error during boot and remove some debug infos
- Remove the debug info for kernel print
Treiber Datei per FTP installieren:
Datei hi-dvb.ko + hisi-ir.ko nach /lib/modules/4.4.35/extra kopieren und Box neustarten.
FTP install:
hi-dvb.ko + hisi-ir.ko copy to --> /lib/modules/4.4.35/extra
Telnet & Putty:
Download link >>> LINK
https://octagon-forum.eu/
OCTAGON SF8008 4K UHD E2 TEST Treiber (Driver) Update 13.05.2019
What's New ;
- DVB-C/T2 Tuner Fixed SNR % & AGC % percent value
--> DVB-C/T2 dB value not yet!
- DVB-C/T2 Tuner SNR % & AGC % Anzeige verbessert
--> DVB-C/T2 dB noch nicht!
Datei hi-dvb.ko nach /lib/modules/4.4.35/extra kopieren und Box neustarten.
FTP install:
hi-dvb.ko copy to --> /lib/modules/4.4.35/extra and restart box.
link; >>> download
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 15.05.2019
What's New ;
- Add GPT usb disk support in fastboot
- Change the default bootargs in fastboot for sf8008
- So it can enter recovery even lost bootargs partition for sf8008.
- Try to fix DVB-T2/C SNR value for ATBM78XX demod.
- Disable the VFD display when go to deepstandy.
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 24.07.2019
- [SF8008] Update Drivers:
- fixed a issue for AC3 passthrough after exit KODI
- Minor Bugs fixed and some issues optimized
Ab heute in den Images!
From today in images!
  • OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 26.07.2019
    - [sf8008] update dB info ATBM782x (DVB-C/T2)
    - [sf8008] add dB info for ATBM782x (DVB-C/T2)
    - [sf8008] calculate Signal Quality int.SNR % dB (frontend)
    Da domani in immagini!
