Sezione dedicata ai decoder Hitube 4K Combo
Nome: [IMAGE] HITUBE 4K COMBO Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 11-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 HITUBE 4K ( CPU ARM)
https://i.imgur.com/7VBnCmN.png
FEATURES:
iSettingE2 OE2.x - NEW VER - v3.6.3r1 - ( 09 MAGGIO 2025 )
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [11-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-hitube4k-20251111_usb.zip
Dimensione: 167.94 MB
Vedi Download: [IMAGE] HITUBE 4K COMBO Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 11 volte da Nemoxyz 6 anni. Motivazione: Download Aggiornato
@Nemoxyz ho installato questo pkgs ma mi dice "alcuni plugin non sono disponibili: system/softwaremanager(bad magic number in /usr/lib/enigma2/python/plugins/systemplugins/softwaremanager/imagebackup.pyo) e se premo il tasto blu crasha tutto e si riavvia.
Ciao @Nemoxyz ho risolto disinstallando e reinstallando i plugin incriminati, ora è tutto ok. Un problema che ho notato anche sulla openesi è un effetto rallenty al cambio canale non so se mi spiego, si può risolvere?
@fracd sistemato il package ora è ok !! era corrotto il file imagebackup.pyo per cui non lo dava disponibile !! Reinstalla per prova !!
Effetto rallenty ??? hai impostato serviceapp con exteplayer3 ???
Serviceapp lo devo installare io non lo installa in automatico e quando lo scarico e lo imposto non riproduce più i file video. Però ti posso garantire che con il pkgs si installa tutto tranne il serviceapp
@fracd io credo che solo a te non si installi il "serviceapp" se provo con altri decoder e stessa sequenza di algoritmo scritto mi esegue dopo il primo riavvio tutti i comandi così come ti faccio vedere la sequenza immessa nel package settings come istruzioni da eseguire
per cui non so perchè o come mai non lo esegua lì da te e lì sul Hitube 4k onestamente mi rimane mistero. Dovrei avere un esemplare per provare e capire come ma. Fatto franco sempre che tu esegua il package come da istruzioni con il comando "opkg install --force-overwrite /tmp/*.ipk" perchè se non eseguito così non supera alcuni limiti e non si installa per bene. Ma non credo sia questo il problema, credo che tu lo installi così. Dico bene ??
@Nemoxyz Si ti assicuro che lo installo in maniera corretta, tant'è che installa correttamente tutto skin, isetting e gli altri plugin l'unico che manca è il servicepp
Ok proverò. Una volta installato come devo impostare metto tutto vero e selezione exteplayer?
@fracd si emtti exteplayer3 come player ma lascia le opzioni che compaiono non mettere tutto on o vero perchè altrimenti non ti funzionano i vod e/o audio !! lascia le cose come compaiono nel menu plugin. saluti.
Salve ho un piccolo problema ho acquistato un hitube ho installato l immagine 6.3 tutto completato ma quando voglio far riprodurre su jedimarker i canali tramite exTeplayer3 non vanno ma partono solamente con gstplayer...
Invece sul player esterno per la riproduzione tipo jkmulti non mi partono proprio i vod e le serie...
Magari qualcuno di voi puô aiutarmi meglio ..
Perche su h9.2h con le stesse impostazioni funziona tutto...
@SiMpa21 hai installato il package per openATV 6.3 o solo la image ??? prova con openESI 9 eventualmente che ha il vod play integrato.
jedimaker e jk multi sono obosoleti lo abbiamo detto molte volte, devi usare eventualmente XC plugin lite v2.2 , lo trovi in downloads , saluti.
