Moderatore: Content Writers
Main Features:
1, 1080P FULL HD DVB S2&T2
2, CAS,USB,PVR Ready
3, SCAM Sharing open channels from Astra, Nilesat, Hotbird(one month testing account inside)
4, Support Network Sharing,Twin Protocol
5, Support USB Wifi,Youtube,Youporn,Weather forecast,Google map,IPTV,3G
Specifications:
Standard HD DVB-S2 ; HD DVB-T2 Complian
Encrypt yes
RF Video Modulator Option
GPRS Module Option
Power Supply Input 220V ~240V, 50/60Hz
Video Decode MPEG-2 MP& HL;MPEG4/H.264 BP MP&HP L4.1;AVS profile L6.1/4.0/2.0
PAL/NTSC Automatic PAL/NTSC conversion
Channels Number 10000 channels TV and Radio programmable
Favorites 8 different favorite groups selection
OSD Language English German French Portuguese Spanish Italian Russian Turkish Polish Arabic Farsi
EPG Fully support to 7 days Electronic Program Guide(EPG)
Picture JPEG,BMP,PNG,GIF Supported
OSD Color 16-bit OSD with anti-flickering
Channel Search Channel search in automatic, manual and network search
Channel Edit Various channel editing function(favorite,move,lock,skip,delete,rename,fin d,sort)
Parental Ctrl Parental control for channels
Easy Menu Plug and Play installation, with an easy to use Menu System
SoftUpgrade Software upgrade through USB
Time Set Time set by GMT offset automatic and manual,Summer Time support
Timer 5 event timers,off/Once/Daily/Weekly Mode
Subtitle Subtitle support
Teletext VBI insertion for Teletext,CC and WSS
Save Channel Automatic save for last channel
Ethernet Support RMII interface, Internet Sharing
RS232S Support TWIN and Software upgrade
CAS Smartcard reader built-in
PS: il digitale terrestre adesso e tutto ok con nuovo fw. , --->> continua descrizione -->>>QUI
ragazzi qualcuno sa se supporta la funzione unicable per far si che funzioni anche con illuminatore scr?
grazie!
Con un firmware simile all'enigma 2 sarebbe una bomba
Comunque è abbastanza interessante come decoder
Occorre lavorarci su
Poi chissà ...
ciao raga qualkuno di voi l'ha già  provato?? io l'ho acquistato ma sinceramente non riesco a farlo partire[war=]SOTTOPOSTO A MODERAZIONE!!! LEGGETEVI IL REGOLAMENTO PRIMA DI DARE FIATO ALLE TROMBE!![/war]
CIao,
anche io sono molto interessato a questo decoder per un acquisto futuro.
Chi ce l'ha potrebbe riportare come va il cambio canali quando si passa da Sat a Digitale terrestre? Il cambio è veloce?
In più , non sono riuscito a trovare le specifiche di questo decoder da nessuna parte (parlo di processore, ram ecc). Chi ce l'ha potrebbe far luce anche su questo aspetto?
kok
leggi tutto sopra
-- 22-11-2014 16:55 --
leggi tutto sopra
Allego il Change Log dell'ultima versione firmware.....
V8 COMBO Change Log
20141120
-DVB-T & T2 *******************[war=][warn]SOTTOPOSTO A MODERAZIONE !!! ATTENZIONE A COSA SCRIVI!! LEGGITI IL REGOLAMENTO!![/warn][/war]
-IP Camera and Radio bug fixed.
20141114
-***a* bug fixed.
20141110
-Unicable UI changed.
-*********** bug fixed.
20141029
-Youporn bug fixed.
-Update UI icon.
20141024
-Update UI options.
20141014
-Update satellite list.
-Bug fixed.
mariomario01 ha scritto:....si.....testato....tutto ok! ;-)
Sei un grande, grazie! :)
P.S. Da dove l'hai scaricato l'ultimo firmware?
Un saluto
kok
  • 1
  • 2
  • 3
  • 4
  • 5
  • 10
