Sezione dedicata ai decoder Skybox A3 - A4 - M5 - AS100 - M3S
ciao per curiosità  perchè questo decoder si chiama as100 android, ho cercato in rete ma non ho capito bene. qualcuno puo darmi dei ragguagli in merito.
e un combinato e utilizza come sistema base operativo android
Andriod Features
CPU ARM Cortex-A9 1GHz Dual Core
GPU Mali-400 MHz Dual Core High Performance GPU
RAM DDR3 1600MHz 1GHz
Flash 4GB (extendable, support up to 32GB TF card)
I/O Ports TF/Micro SD Card Slot * 1
Android USB 2.0 Host * 2
DVB-S2 PVR USB 2.0*1
HDMI Out (v1.4) * 1
Optical Audio Out (SPDIF) * 1
RS232 for DVB-S2 Upgrading*1
Video Decode H.264(AVC-HD), VC-1(WMV-HD), Mpeg1/2/4, Divx-HD, Xvid-HD, RMVB
Video Format RM/RMVB, AVI, MP4, MPG, DAT, VOB, MOV, FLV, ASF,MKV, TS, M2T, M2TS, TP, TRP, WMV, IFO, ISO, M2P
Audio Format MP3, WMA, OGG, AAC, WAV, AC3, LPCM, FLAC
Picture Format JPG, JPEG, BMP, GIF, PNG
Wireless Connectivity
802.11 b/g/n Wi-Fi with an external antenna DLNA (Digital Living Network Alliance) supported
Multi-Screen Interactive supported
USB Wi-Fi Dongle supported
e quasi l'evoluzione della specie
*** Messaggio aggiunto il 17-01-2015 1:59 ***
DVB S2 Features
Dual-Core CPU, 396 MHz MIPS Processor
Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;Fully compliant MPEG-2 MP@HL & MP@ML;
SCPC & MCPC receivable from C/Ku band satellites;multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)
NIT search supported;
Support MPEG-5;
Support HDMI 1.3;
Support PVR(store in USB disk);
Multimedia files playback(by USB);
Support Electronic Program Guide(EPG) for 7 days;
Teletext and subtitle out through OSD;Support multi-lingual DVB subtitle and teletext;
Automatic and manual channel scan options;automatic service scan
channel-change time < 1 second
Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable
Multiple display mode: 1080p/1080i/720p/570p/576i/480p;
MPEG-2 / H.264 Hardware decoding; Videotext Decoder
Analog audio output: stereo(L+R);
Digital audio output: S/PDIF by coaxial and optical;S/PDIF Interface for digital bit stream out (AC-3)
YCbCr available;
Screen format:auto, 4:3, and 16:9;
Upgrade software through USB2.0 port;
Powerful program management function, parent lock;
CA 1x slot
10/100Mbit Ethernet Interface
directly bouquet-lists
HIGH light LED Display
WIFI insde
*** Messaggio aggiunto il 17-01-2015 2:04 ***
android intefaccia
dvb
