salve a voi tutti
mi è stato portato questo decoder ( HDTV HD V8 800S2 ) qualcuno ne sa qualcosa ?
fatemi sapere
nel frattempo faccio a tutti i più sinceri AUGURI DI BUON NATALE E UN FELICE ANNO NUOVO !!!!!!! :-D :-D
*** Messaggio aggiunto il 26-12-2014 14:55 ***
QUESTE SONO LE CARATTERISTICHE
800S2 HD pvr Linux digital satellite receiver
1) 300 MHz MIPS Processor - Linux Operating System
2) Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;
3) Fully compliant MPEG-2 MP@HL & MP@ML;
4) Fully compliant MPEG-1 Layer I & II & III, Dolby Digital Audio(AC3);
5) SCPC & MCPC receivable from C/Ku band satellites;
6) multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)
7) NIT search supported;
8) Support MHEG-5;
9) Support HDMI 1.3;
10) Support PVR(store in USB disk);
11) Multimedia files playback(by USB);
12) Support Electronic Program Guide(EPG) for 7 days;
13) Teletext and subtitle out through OSD;
14) Support multi-lingual DVB subtitle and teletext;
15) Automatic and manual channel scan options;
16) automatic service scan
17) channel-change time < 1 second
18) OSD in many languages and skin-support
19) Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable;
20) LED Display
21) Multiple display mode: 1080i/720p/570p/576i/480p;
22) MPEG-2 / H.264 Hardware decoding
23) Videotext Decoder
24) Analog audio output: stereo(L+R);
25) Digital audio output: S/PDIF by coaxial and optical;
26) S/PDIF Interface for digital bit stream out (AC-3)
27) YCbCr available;
28) 2 x Scart (RGB, FBAS or S-Video)
29) Screen format:auto, 4:3, and 16:9;
30) Upgrade software through USB2.0 port;
31) Powerful program management function, parent lock;
32) CA 1x slot and CI 1xslot
33) 10/100Mbit Ethernet Interface
34) directly bouquet-lists
ciao
l'ho beccato in Inghilterra
*** Messaggio aggiunto il 05-01-2015 13:59 ***
ciao
è possibile capire che tipo di immagine monta ?
*** Messaggio aggiunto il 05-01-2015 20:03 ***
cerco immagine
Compatible as: Openbox and ***box S9, S10, S11, S12, HDTV500S2v8 and HDTV800S2v8
***Not compatible as: DM500v8 and DM800v8
ora provo s12 vediamo che succede
@sila1924 allora non era il punto corretto dove […]
