Sezione dedicata ai decoder Skybox A3 - A4 - M5 - AS100 - M3S
Buon giorno ragazzi!
Qualcuno lo possiede gia?
Non si riesce a trovare molto in giro.Avete qualche consiglio?
Inviato dal mio GT-I9300 con Tapatalk 2
te lo consiglio io, perchè lo sto testando ed ho un ottimo prodotto. Sto creando anke una recensione con tutte le foto, a giorni la pubblico!!!!! :D
Product Description
Skybox A4 hd Original
General Specifications:
Dual-Core CPU, 396 MHz MIPS Processor
Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;
Fully compliant MPEG-2 MP@HL & MP@ML;
Fully compliant MPEG-1 Layer I & II & III, Dolby Digital Audio(AC3);
SCPC & MCPC receivable from C/Ku band satellites;
multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)
NIT search supported;
Support MPEG-5;
Support HDMI 1.3;
Support PVR(store in USB disk);
Multimedia files playback(by USB);
Support Electronic Program Guide(EPG) for 7 days;
Teletext and subtitle out through OSD;
Support multi-lingual DVB subtitle and teletext;
Automatic and manual channel scan options;
automatic service scan
channel-change time < 1 second
OSD in many languages and skin-support
Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable
Multiple display mode: 1080p/1080i/720p/570p/576i/480p;
MPEG-2 / H.264 Hardware decoding
Videotext Decoder
Analog audio output: stereo(L+R);
Digital audio output: S/PDIF by coaxial and optical;
S/PDIF Interface for digital bit stream out (AC-3)
YCbCr available;
Screen format:auto, 4:3, and 16:9;
Upgrade software through USB2.0 port;
Powerful program management function, parent lock;
CA 1x slot
10/100Mbit Ethernet Interface
directly bouquet-lists
HIGH light LED Display
Support 2 USB
Grazie per le info tecniche. Tu dove lo hai reperito?
se cerchi su google lo trovi
sembra fighissimo con sta sim ..........
pero mi sa che non monta enigma quindi cè sempre il problema delle liste
su consiglio di nemoxyz e su spinta di daniele specchi, ho proceduto all acquisto dell A4 (per info contattate in pvt i mod). attendo quindi la spedizione.
il software dovrebbe essere quello classico degli skybox, ma la cosa interessante (a parte tutte le connessioni) è la cpu dual core che dovrebbe consentire di sfogliare la lista canali senza far bloccare la visione ( problema degli skybox meno potenti, come il mio f3)!
il mitico daniele sta preparando una recensione a puntino, che vorrei ampliare pure io non appena l'avro tra le mani!
Inviato dal mio iPad Mini bianco con Tapatalk HD
mscambio ha scritto:sembra fighissimo con sta sim ..........
Xke esistono skybox con enigma?
Non credo loro usano softw loro
inviato da Tapatalk 4 Pro
Io li volevo comprare, ma alla fine il cliente tra A4 e F3s preferisce comprare F3s xkè costa di meno e nn ha nulla in meno rispetto a A4, voi che ne pensate?
Non ho mai provato un A4 ma f3 come qualità  prezzo non è male, poi ognuno guarda nelle sue tasche e decide ;)
A4 è lo stesso sistema dell'F quindi cambia solo la risposta nel cambio canali
i due decoder sono molto simili. Cambia solo il cambio dei canali
Topic di Test
Hai riscontrato qualche problema sul Forum?? ;-)
Iscriviti su Telegram
