FINE SUPPORTO
O COLLEGO SERIALE AL DECODER E INSERISCO PRESA USB NEL PC
APRO STB TOOL 1.8
NEL PORT SELEZIONABILI TROVO : prolific USB TO serial COMM pORT (COM 5)
lascio baud: 115200
vado su FLASHWR carico file FW e schiaccio write
quando appare PLEASE REST THE STB collego la presa di corrente e il decoder incomincia e viene visualizzato questo:
Please reset the STB!
BOOTROM ...
Start Calibration ...
CLOCK_OFFSET = -17
DELAY_90_OFFSET = 0
DELAY_9090_OFFSET = 0
DQS_IN_90_OFFSET = 0
0:range 2 start = 0 end = 0 rl_add_i = 4
0:range 2 start = 0 end = 1 rl_add_i = 4
0:range 2 start = 0 end = 2 rl_add_i = 4
0:range 2 start = 0 end = 3 rl_add_i = 4
0:range 2 start = 0 end = 4 rl_add_i = 4
0:range 2 start = 0 end = 5 rl_add_i = 4
0:range 2 start = 0 end = 6 rl_add_i = 4
0:range 2 start = 0 end = 7 rl_add_i = 4
0:range 2 start = 14 end = 14 rl_add_i = 4
0:range 2 start = 14 end = 15 rl_add_i = 4
0:range 2 start = 14 end = 16 rl_add_i = 4
0:range 2 start = 14 end = 17 rl_add_i = 4
0:range 2 start = 14 end = 18 rl_add_i = 4
0:range 2 start = 14 end = 19 rl_add_i = 4
0:range 2 start = 14 end = 20 rl_add_i = 4
0:range 2 start = 14 end = 21 rl_add_i = 4
0:range 2 start = 14 end = 22 rl_add_i = 4
0:range 2 start = 14 end = 23 rl_add_i = 4
0:range 2 start = 14 end = 24 rl_add_i = 4
0:range 2 start = 14 end = 25 rl_add_i = 4
0:range 2 start = 14 end = 26 rl_add_i = 4
0:range 2 start = 14 end = 27 rl_add_i = 4
0:range 2 start = 14 end = 28 rl_add_i = 4
0:range 2 start = 14 end = 29 rl_add_i = 4
0:range 2 start = 14 end = 30 rl_add_i = 4
0:range 2 start = 14 end = 31 rl_add_i = 4
0:range 2 start = 14 end = 32 rl_add_i = 4
0:range 2 start = 14 end = 33 rl_add_i = 4
0:range 2 start = 14 end = 34 rl_add_i = 4
0:range 2 start = 14 end = 35 rl_add_i = 4
0:range 2 start = 14 end = 36 rl_add_i = 4
rang0: 00 0 0 , rang1: 00 0 0 , rang2: 23 1 0, rang3: 00 0 0
DDR2 Calibiration param is: clk star 14, end 36, rdclk_rising_latch 1, digclk_neglatch 0, rd_add 4
0xa4 = 33339000
0x38 = 72140001
0x50 = 00190910
0x4c = 00090001
0x44 = 001b0000
0x54 = 09090909
Calibration done, cost 8 s
DDR Calibration SUCCESS
Got sync byte!
Start sending client...
Start to check serial...
!! ClientTest FAIL: Can not receive any responses from STB!!
!! ClientTest FAIL: RSP error!!
AIUTOOOOOOO!!!!!
sembra non dialoghi con la porta ma usi un cavo nullmodem o un cavo seriale comune se usi cavo nullmodem corretto allora prova a scaricarti un'altro stbtool e riprova.
