In primis chiedo scusa per aver postato qui ma una sezione per il Vu+ UNO non esiste e non sapevo dove scrivere.
Il mio problema stà nell'avviare in automatico la VPN con OpenVPN, ho impostato tutto i file e se avvio da telnet parte benissimo ma appena spengo e riavvio il decoder non parte mi da un errore come potete vedere nel log in allegato.
Thu Jan  1 01:00:18 1970 OpenVPN 2.1.3 mipsel-oe-linux [SSL] [LZO2] [EPOLL] built on Jun 25 2015
Thu Jan  1 01:00:18 1970 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA.  OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
Thu Jan  1 01:00:18 1970 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Jan  1 01:00:18 1970 LZO compression initialized
Thu Jan  1 01:00:18 1970 UDPv4 link local (bound): [undef]:1194
Thu Jan  1 01:00:19 1970 UDPv4 link remote: 178.255.153.76:1194
Thu Jan  1 01:00:19 1970 VERIFY ERROR: depth=1, error=certificate is not yet valid: /C=SK/ST=Bratislava/L=Bratislava/O=Tiger_At_Work___Co._k._s./OU=tigerVPN/CN=tigerVPN/name=tigerVPN/emailAddress=help@tigervpn.com
Thu Jan  1 01:00:19 1970 TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Thu Jan  1 01:00:19 1970 TLS Error: TLS object -> incoming plaintext read error
Thu Jan  1 01:00:19 1970 TLS Error: TLS handshake failed
Thu Jan  1 01:00:19 1970 SIGUSR1[soft,tls-error] received, process restarting
Thu Jan  1 01:00:21 1970 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Jan  1 01:00:21 1970 Re-using SSL/TLS context
Thu Jan  1 01:00:21 1970 LZO compression initialized
Thu Jan  1 01:00:21 1970 Attempting to establish TCP connection with 178.255.153.76:443 [nonblock]
Thu Jan  1 01:00:22 1970 TCP connection established with 178.255.153.76:443
Thu Jan  1 01:00:22 1970 TCPv4_CLIENT link local: [undef]
Thu Jan  1 01:00:22 1970 TCPv4_CLIENT link remote: 178.255.153.76:443
Enter Auth Username:Thu Jan  1 01:00:22 1970 ERROR: could not read Auth username from stdin
Thu Jan  1 01:00:22 1970 Exiting
ora il problema stà nella data per quello che ho potuto capire come posso ovviare questo problema e fart partire la vpn con ritardo dopo che i transporder hanno aggiornato la data del decodr???? come immagine uso la BK 2.1.7
Grazie mille
