Sezione dedicata ai decoder Sunray4 SR4dm800HDse-V2 triple tuner sim 2.20
Nome: [BCKP] SR4-HDse V2 Sim2.20 Nemoxyz OpenATV-5.1 Skin-maK-HD-SSL88a
Descrizione: Carissimi ciao a tutti!!! GRANDE NOVITA' GRAFICA SU DECODER Sunray 4 versione V2
NemoxySAT-tv release :
Basata sulla versione originale LAST RELEASE OpenATV 5.1( i ringraziamenti vanno al team OpenATV creatore e sviluppatore dell'immagine ) + trial Tuner COMBO SAT + DTT drivers )
BACKUP FEATURES ( data backup 28-09-2015 ) :
MINIMAL AMBER KravenHD - SKIN - dreambox SR4 V2 - mod by Nemoxyz Design
[center-img]images/xsmfl.jpg[/center-img]
[center-img]images/25fhwsi.jpg[/center-img]
[center-img]https://i.imgur.com/ED9YXJCh.jpg[/center-img]
[center-img]images/9auwzd.jpg[/center-img]
[center-img]images/2uo6q3a.jpg[/center-img]
[center-img]images/1zn8ymx.jpg[/center-img]
[center-img]images/21jsw44.jpg[/center-img]
[center-img]images/kbcfv8.jpg[/center-img]
[center-img]https://i.imgur.com/12pDwANh.jpg[/center-img]
[center-img]images/15gcxhu.jpg[/center-img]
[center-img]images/vybqk8.jpg[/center-img]
Qui sotto in download potrete scaricare il file compresso in RAR al cui interno troverete l'immagine backup in versione NFI che potrete installare comodamente tramite il flash via web-browser.
Guida MOUNT USB DEVICE & XpiconS ( hotbird 13 + DTT completi originali by Nemoxyz )[/*]
Versione: SET2015-V1
File: Nemoxyz-OpenATV-5.1-SSL88a(SKmaK+isetE2-334-xmlTV)-SR4-HDseV2-sim2.20-[28-09-2015].rar
Vedi Download: https://sat.technology/dlext/details?df_id=241
SPETTACOLARE VERSIONE BACKUP VALIDA SOLO PER:
SUNRAY SR4 dm800HDse V2 (kernel 3.2 dreambox ) --- Clone Sunray4 SR4 v2 sim 2.20
Versione-BACKUP-V1 = 28 SETTEMBRE 2015 !!!! (NEW VERSION!!)
VI PROPONGO IL BACKUP CON PERSONALIZZAZIONE NEMOXYZSAT-TV MINIMAL AMBER EDITION !!
BASATO SULLA NUOVISSIMA OpenATV 5.1 IMAGE con bootlogo Design by Nemoxyz
( sim 2.20 - kernel 3.2 INDICATO PER cloni sunray SR4 versione V2 )
[center-img]images/fwuo78.jpg[/center-img]
( RELEASE-master SETTEMBRE 2015 !! )
E' un mio backup personalizzato E SUPER AGGIORNATO CON ULTIMA RELEASE !! in tutte le svariate opzioni che offre questo software !!
- Personalizzazione della SKIN KravenHD Minimal Amber versione ottimizzata per dreambox SR4 V2 ( many thanks to Kraven ) by Nemoxyz
- PLUGIN isettingE2 installato!! ( ELENCO DTT DISPONIBILE IN CONTINUO AGGIORNAMENTO )
Nemoxyz-OpenATV-5.1-maK-HD(isettE2-334-XMLTVImp)SR4dm800HDse-V2-[28-09-2015]usb
[ backup by Nemoxyz - 28 SETTEMBRE 2015 ]
La versione MANUTEK-forum-Backup di una delle migliori e complete immagini-software attualmente per decoder della serie dreambox :
O P E N - A T V - S O F T W A R E ---- 5.1
- Bootlogo Nemoxyz Design Minimal Amber Edition
- SPINNER -->> Nemoxyz POWER mini
- SPLASH SCREEN openATV Backup & powered by -->> Nemoxyz version2
- New ICONs Amber-FIRED completatemente sostituite e rinnovate
- Skin Kraven completamente moddata ( versione per dreambox SR4 V2 ) : Infobar e SecondInfobar modificate, meteo Località, buttons panel, Colori
- Trial Tuner correttamente settato
- host name = SR4-dm800HDseV2 ( nome LAN - samba )
- username = root ( mi raccomando non confondetevi !! lo username è il classico di tutti i deks!!! enigma2 !! )[/color][/*]
- Password accesso FTP / OpenWebIF = dreambox
- FlashTOOL integrato in image plugins ( ufficiale OpenATV - per modello Dreambox )
- Enhanced Movie Center v4.0 ( attivazione plugin tramite tasto "TV" del telecomando )
- KravenHD tool di configurazione ( colori e Località Meteo sostituibile !! )
- EPG import installato e configurato Rytec XmlTV italy
- CROSSEPG INSTALLATO in accoppiata con plugin eCLOUDITALY ( settaggio epg settimanale ) utile per chi utilizza supporto di memorizzazione
- isettingE2 3.3.4( NUOVISSIMA VERSIONE DEL FAMOSO plugin!! configurazione auto su ManuTEK thanks to Diamondear !! PROVINCE DTT SELEZIONABILI !!)
--->> aggiornamento automatico 2volte al gg !!! - MONOfeed Hotbird 13° + DTT NAZIONALE
- ManuTEK settings 18-09-2015 (NemoxyzSATtv)
- SCOMPATTATE IL FILE RAR TROVERETE IL FILE "nfi" DENTRO
- A DECODER SPENTO TENETE PREMUTO BOTTONCINO DAVANTI MENTRE ACCENDETE DA ON/OFF POSTERIORE OPPURE PIGIATE IN ACCENSIONE IL TASTO "PIROLINO" POSTERIORE DI MODALITA'"FLASHING"
- IL DECODER A QUESTO PUNTO SI PREDISPONE IN MODALITA' FLASH RESTITUENDOVI L'INDIRIZZO IP ASSEGNATOGLI (SULL'OLED POTRETE VISUALIZZARLO)
- ACCEDENDO A TALE INDIRIZZO IP VIA BROWSER ( CONSIGLIO GOOGLE CHROME ) ENTRERETE NELL'INTERFACCIA DI FLASHING SCEGLIETE ->> FIRMWARE UPGRADE E SELEZIONATE IL FILE "nfi" PRECEDENTEMENTE SCOMPATTATO E PROCEDETE AL CARICAMENTO.
- A QUESTO PUNTO IL FILE VIENE CARICATO E PASSA POI AL FLASHING , SPUNTATE "REBOOT" COSìCHè DOPO AVER CONCLUSO IL DECODER SI RIAVVIA DA SOLO!!
- inserita la penna usb o hdd usb formattati in fat32 ( dietro o di lato ) poi si attende che carica e vi dirà che nn c'é nulla da riprodurre se vuoto di contenuti multimediali
Modificato 3 volte da Nemoxyz 10 anni.
