Ragazzi ho tra le mani questo decoder ma in giro non si trova niente..qualcuno mi ha detto che e' come l'openbox ma io ho qualche dubbio..consigli?
HD MPEG4/H.264 DVB-S2 Receiver with LAN&WiFi
Key Features:
Solution: Sunplus SHPE1512A
Fully HD MPEG4/H.264 DVB-S2 compliant
One CA slot available for pay-TV channels
LAN:10/100Mbit Ethernet(RJ45)
WiFi:802.11n. Support internet function (USB WiFi optional)
Support Network Application (Youtube /EBOOK /Google map /Weather/IPTV...) via
LAN or WiFi.
Support PVR function via USB & multimedia player & time-shift function.
Support Dolby AC3/E-AC-3/AAC/HE-AAC/MS10, RealAudio, WMA, DTS (optional).
Video resolution: 1080p,1080i, 720p, 576p, 576i
SCPC and MCPC receivable from C/Ku band satellites
Support DiSEqC 1.0/1.1/unicable/1.2/1.3(USALS)
OSD language: English and other languages as per request
Variable aspect ratio:Auto,16:9 Pillar box,4:3 Pan and Scan,4:3 Letter Box
Fully support Electronic Program Guide (EPG) for 7 days
Auto/Manual channel search/Blind scan
Favorite channel edit & parental lock function
Support teletext/subtitle/audio language selection
PAL/NTSC auto-conversion
Capacity for storing up to 6000 channels
Easy and fast software upgrade via USB port
Interfaces:HD-out, S/PDIF(Coaxial), USB, CA Slot, RS232, Scart,
Ethernet(RJ45), WiFi(optional)
Specifications:
CPU AND MEMORY
CPU: Sunplus SPHE1512A
DDR memory: 2GBit
FLASH memory: 64MBit
TUNER:
Receiving frequency range: 950~2150MHz
Input signal level: -65~-25 dBm
Input impedance: 75
DiSEqC control: V1.0/1.1/unicable/1.2/1.3(USALS)
LNB Power: 13V/18V/OFF, max=500mA, support short-circuit protection.
DE-MODULATION
Demodulation: QPSK,8PSK
Input symbol rate: 2-45Ms/s
VIDEO & AUDIO DECODING
Video decode: MPEG2 MP@ HL & MPEG4 AVC/H.264 HP@L 4.1,RealVideo, FLV, DivX
