Sezione dedicata ai decoder WorldVision Force+1 plus (combo triplo tuner: dual sat e dvb-t /dvb-c)
ho un force1 plus collegato via hdmi alvisione full hd lg.da stamattina il decoder non trasmette più nulla a video tramite hdmi ma solo tramite rca
con hdmi test ho il seguente crash log
open /usr/lib/enigma2/python/Plugins/Extensions/HdmiTest/plugin.png
[SCREENNAME]  PluginBrowser
1 6c 1
KEY: 108 0 KEY_DOWN DOWN 2016-02-03 11:18:54.160749
0 6c 1
KEY: 108 1 KEY_DOWN DOWN 2016-02-03 11:18:54.162771
1 160 1
KEY: 352 0 KEY_OK OK 2016-02-03 11:18:54.497976
action ->  SetupActions ok
[HdmiTest] fallback to default translation for HdmiTest
[HdmiTest] fallback to default translation for Command
[HdmiTest] fallback to default translation for Real physical address
[HdmiTest] fallback to default translation for Addressed to
[HdmiTest] fallback to default translation for Send
[HdmiTest] fallback to default translation for Cancel
[HdmiTest] fallback to default translation for Monitor
[HdmiTest] fallback to default translation for Wakeup TV
[HdmiTest] fallback to default translation for Tx:
[HdmiTest] fallback to default translation for Rx:
[SKIN] Parsing embedded skin <embedded-in-'HdmiTest'>
[SCREENNAME]  ['HdmiTest_summary', 'SimpleSummary']
[SCREENNAME]  HdmiTest
0 160 1
KEY: 352 1 KEY_OK OK 2016-02-03 11:18:54.599136
1 160 1
KEY: 352 0 KEY_OK OK 2016-02-03 11:18:58.728122
eHdmiCEC: send message 82 20 00
0 160 1
KEY: 352 1 KEY_OK OK 2016-02-03 11:18:58.730574
eHdmiCEC: received message 89 01
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2016-02-03 11:19:01.670446
action ->  SetupActions right
unknown action SetupActions/right! typo in keymap?
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2016-02-03 11:19:01.682803
1 160 1
KEY: 352 0 KEY_OK OK 2016-02-03 11:19:02.680758
eHdmiCEC: send message 83
0 160 1
KEY: 352 1 KEY_OK OK 2016-02-03 11:19:02.682951
eHdmiCEC: received message 84 00 00
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2016-02-03 11:19:04.342124
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2016-02-03 11:19:04.353725
1 160 1
KEY: 352 0 KEY_OK OK 2016-02-03 11:19:04.912916
eHdmiCEC: send message 84 20 00 03
0 160 1
KEY: 352 1 KEY_OK OK 2016-02-03 11:19:04.915384
1 6a 1
KEY: 106 0 KEY_RIGHT RIGHT 2016-02-03 11:19:08.880487
0 6a 1
KEY: 106 1 KEY_RIGHT RIGHT 2016-02-03 11:19:08.892330
1 160 1
KEY: 352 0 KEY_OK OK 2016-02-03 11:19:09.454913
eHdmiCEC: send message 85
0 160 1
KEY: 352 1 KEY_OK OK 2016-02-03 11:19:09.457093
eHdmiCEC: received message 82 00 00
eHdmiCEC: received message 87 00 E0 91
eHdmiCEC: received message 00
Traceback (most recent call last):
  File "/usr/lib/enigma2/python/Plugins/Extensions/HdmiTest/plugin.py", line 374, in messageReceived
    self["rxtext"].setText(self.rxText(cmd, data, length) + "\n" + self["rxtext"].getText())
  File "/usr/lib/enigma2/python/Plugins/Extensions/HdmiTest/plugin.py", line 394, in rxText
    return "%02X" % ord(data[0]) + " " + abortReason[ord(data[1])]
KeyError: 224
(PyObject_CallObject(<bound method HdmiTest.messageReceived of <class 'Plugins.Extensions.HdmiTest.plugin.HdmiTest'>>,(<enigma.iCECMessagePtr; proxy of <Swig Object of type 'ePtr< iCECMessage > *' at 0x2601aa0> >,)) failed)
		</enigma2crashlog>
	</crashlogs>
</openATV>
provato sia openatv ,openpli che eurosat.
inpostato varie risoluzioni ma nulla.
provato altro cavo e altra presa ma nulla.Strano che cmq la tv riceve l'input perchè si illumina l'icona della hdmi ma non viene tramsmesso nula a video
[war=]admin wrote: possibilmente quando riportiamo crashlogs così lunghi usiamo il bbcode -->> < code > che inserisce in finestra il tutto rendendolo meno kilometrico!! thanks !![/war]
