Lista + Firmware per decoder Zgemma-STAR H2 dual tuner COMBO sat + DTT
Nome: [BCKP] ZgemmaSTAR-H2 Nemoxyz OpenATV-5.1-GST171 CBGold [K4.0.1]
Descrizione: RELEASE FEB 2016 !!!!
particolare backup Classic basato su OpenATV 5.1 SOFTWARE :
Nemoxyz-OpenATV5.1-GST171-ClassicBLUEgolden-ZgemmaSTAR-H2[07-02-2016]usb
[ backup by Nemoxyz - 07 Febbraio 2016 ]
Versione proposta per decoder AIR SAT DIGITAL
( Zgemma Star H2 )
https://sat.technology/images/2hp66tk.jpg
OpenATV 5.1 CLASSIC BLUE GOLDEN - GST 1.7.1
https://i.imgur.com/9nOoqGo.jpg
BACKUP FEATURES ( data backup 07-02-2016 ) :
  • Bootlogo OpenATV ClassicGolden bye Nemoxyz Design
  • SPINNER SAT.technology power
  • host name = ZGEMMA-H2
  • Password accesso FTP / OpenWebIF = zgemma
  • Codice PARENTAL CONTROL = 1357
  • GST 171 gestreamer ultima versione integrato di base da openATV 5.1
  • EMC4.0 media player ehnanced -->> Tasto FILE LIST !!!
  • Xmltv importer ( EPG guide ) configurato con Rytec italy
  • isettingE2 3.3.7 (NUOVISSIMA VERSIONE DEL FAMOSO plugin!)
    Configurazione auto su ManuTEK+DTT - aggiornamento automatico 2volte al gg !!
  • Mono feed Hotbird 13° + DTT italia nazionale ( manutek settings )
  • [center-img]https://i.imgur.com/OqhScns.jpg[/center-img] [center-img]https://i.imgur.com/kRNZTP1.jpg[/center-img] [center-img]https://i.imgur.com/Lm3dede.jpg[/center-img] [center-img]https://i.imgur.com/U0j8f6Y.jpg[/center-img] [center-img]https://i.imgur.com/KKY1tUY.jpg[/center-img] [center-img]https://i.imgur.com/u6t0aFO.jpg[/center-img] [center-img]https://i.imgur.com/XO1SIBK.jpg[/center-img] [center-img]https://i.imgur.com/waSFJph.jpg[/center-img] [center-img]https://i.imgur.com/c42ozWz.jpg[/center-img] [center-img]https://i.imgur.com/IXwZG3R.jpg[/center-img] [center-img]https://i.imgur.com/jfo0SU5.jpg[/center-img] [center-img]https://i.imgur.com/Mokvrr3.jpg[/center-img] [center-img]https://i.imgur.com/tpIDWFM.jpg[/center-img] [center-img]https://i.imgur.com/AxesOOJ.jpg[/center-img] [b]Qui sotto in download potrete scaricare il file compresso in RAR al cui interno troverete l'immagine backup in versione Flash by USB che potrete installare comodamente tramite il flashing via USB.[/b] [b][color=#FF0000][u]piccola guida per installazione:[/u][/color][/b] [b][i][list]
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "zgemma"
  • A DECODER SPENTO INSERITE LA PENNA USB NELL'APPOSITA PORTA ( porta usb posteriore!!) ED ACCENDETE IL DECODER DAL BOTTONCINO POSTERIORE, comparirà la dicitura FLASH!!
  • ATTENDENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' PIU' E SUL VISORE DEL DECODER NON SARA' SCOMPARSA LA SCRITTA "FLASH" poi il decoder si riavviarà in automatico!!
  • A QUESTO PUNTOIL DECODER ESEGUIRA' AUTONOMAMENTE IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( PER RIUMOVERE LA PENNA USB SPEGNETE IL DECODER E RIMUOVETE!! )
[/i][/b]
[/list][/b]
Versione: FEB-v1
Vedi Download: https://sat.technology/dlext/details?df_id=308
salve nella descrizione del posto non specifica nulla,ma quando apro il file zip sulla destra nella descrizione specifica che è valida per "BOOT LOADER 751MHz "quindi non sò a a cosa devo fare riferimento?
@espanico87 non ti sto seguendo bene!!?? cosa intendi dire ??? questo backup è valido per zgemma H2 che ha un unico bootloader da 750MHZ non ne esistono altri!! vai tranquillo usalo senza problemi !! Saluti.
Nemoxyz ha scritto:@espanico87 non ti sto seguendo bene!!?? cosa intendi dire ??? questo backup è valido per zgemma H2 che ha un unico bootloader da 750MHZ non ne esistono altri!! vai tranquillo usalo senza problemi !! Saluti.
intendo dire che dato che nell'altro post della openatv c'è scritto questo messaggio "SPETTACOLARE VERSIONE BACKUP VALIDA SOLO PER:
BOOTLOADER - 751 MHz (kernel 4.0.1) --- Zgemma-STAR H2 ", ho pensato che appunto ci vuole un bootlooder specifico che il mio decoder non ha e che quindi dovrei caricare.....perciò ho preferito questa opena tv qui dove nel post nn c'è scritto quel messaggio......però aprendo il file zip...sulla destra nella descrizione ritrovo scritto questo messaggio qui.....e perciò ho fatto questa domanda
ah si ho capito....
no guarda è solo un refuso di scrittura descrizione derivante da altri e precedenti descrizioni di altri modelli simili.
(cmq il boot è per tutti 751 MHz )
cmq vai tranquillo quello che pubblico qui è sempre super testato !! su Zgemma H2 ci sono solo bootloader 751 MHz !!!
puoi usare senza problemi il tutto!! hai fatto bene ad usare questo qui perchè è molto veloce rispetto all'altro in cui la skin sebbene più allettante lo rallenta un tantino. Questioni di scelte!! Saluti !!
Nemoxyz ha scritto:ah si ho capito....
perfetto...grazie mille per la risposta....un ultima cosa...ma tra questa qui e l'eurosat quale mi consigli?????qual'è più leggera e veloce?
lo sono entrambe !!! EuroSAT è più completa in fatto di plugins presenti e scaricabili ma leggermente più onerosa in fatto di skin.
questa è più scarna ma un tantino più sprint essendo solo un piccolo ritocco della skin base!!
Nemoxyz ha scritto:lo sono entrambe !!! EuroSAT è più completa in fatto di plugins presenti e scaricabili ma leggermente più onerosa in fatto di skin.
ho provato l'eurosat e sembrava andar bene ma ci impiegava troppo tempo a spegnersi.....ora sto provando questa qui in base openatv speriamo vada meglio...
@espanico87 molto strano questo comportamento, ipotizzo che in quella fase di spegnimento ti possa essere capitato un momento che in background stesse aggiornando qualcosa ( vedi per esempio xmltv importer ) e che quindi fino al termine del processo di update nn ti spenga il decoder anche dopo aver richiesto lo stand-by deep!
Perchè dai test fatti eurosat 2.0 e veloce tanto quanto openATV 5.1
nemoxyz i tuoi backup sono spettacolari,ma io sono il solito pauroso di fare danni.Vengo da un tuo backup su italisat e noto ora ke non fai piu backup su questa immagine,ma nn è un problema per me passare alla openatv e ke non so se devo fare qualche passaggio in più oppure fare un flash normale.Grazie cmq del lavoro che svolgi per noi comuni mortali :-D
scusatemi,io ho un problema con questo bkp, quando lo installo, al boot si ferma al 50% e va in loop,si blocca! qualcuno è successo? cosa posso fare?
@cocotom credo dipenda localmente dal tuo esemplare perchè è stato installato diverse volte senza problemi su molti decoder zgemma H2 come leggi!!
Cmq sto per uscire con una versione "interstellar" golden classic ;) con la nuovissima openATV 5.2 !! magari potrai provare questa !!!
tempo di ultimare i ritocchi !! Saluti...
avevo intuito, infatti è l'unico backup che il mio decoder non riesce ad installare! Pazienza, proverò la nuova! Grazie!
Ancora devo prenderci la mano e già tu stai facendo quella nuova,sei un grande ma io sono quello dei problemi assurdi....ora te li elenco e so ke qualcuno mi può aiutare.
1)il meteo come lo imposto?
2)ho una usb da 8 gb e non mi parte il timeshift perche mi chiede di formattare in ext2 ma quando provo a formattare mi da un errore impossibile configurare.
Mi potete aiutare?
@Erik Barale buonasera e benvenuto nella nostra […]
