Backup e Tools per MAGICBOX MG4 HD RELEASE SETTEMBRE 2016 ( V4 )
particolare backup Classic basato su OpenVIX 4.2 [ 005 ] SOFTWARE :
Nemoxyz-OpenVIX4.2-005-GST190-NOVUMslimHDOrangeLight-MAGICBOX-MG4HD-[12-09-2016]
[ backup by Nemoxyz - 12 SETTEMBRE 2016 - V4 ]
Versione proposta per decoder MAGICBOX MG4-HD
(cartella magibox / magicbx / magicbox etc etc a scelta secondo il modello)
http://i57.tinypic.com/vdjwit.jpg
OpenVIX 4.2 [005] NOVUM slim HD ORANGE light MOD - GST 1.9.0 NEW!!!
https://i.imgur.com/RxgPTuu.jpg
BACKUP FEATURES ( data backup 12-09-2016 - V4 = aggiornamento completo a versione 4.2 - 005 ) :
  • Bootlogo OpenVIX 4.2 - NOVUM slim ORANGElightMOD - by Nemoxyz Design
  • SPINNER SAT.technology power
  • SKIN NOVUM SLIM HD orange light mod by Nemoxyz ( piccole correzioni nei colori )
  • host name = MAGICBOX-MG4HD
  • Password accesso FTP / OpenWebIF = magicbox
  • Codice PARENTAL CONTROL = 1357
  • POWER TIMER IMPOSTATO CON SPEGNIMENTO "DEEP-STANDBY" DOPO 10 MINUTI DALLO STAND-BY
  • GST 190 Gstreamer ultimissima aggiornata versione integrato in OpenVIX
  • EMC4.0 media player ehnanced -->> Tasto ROSSO ( telecomando mg4 hd ) !!!
  • TASTO giallo configurato con varie funzioni offerte dal software openVIX ( telecomando mg4 hd ) !!!
  • BWMON plugin BANDWIDTH MONITOR ( monitoraggio banda lan & wifi )
  • Xmltv importer ( EPG guide ) configurato con Rytec italy
  • isettingE2 3.3.8 (NUOVISSIMA VERSIONE DEL FAMOSO plugin!)
    Configurazione auto su ManuTEK+DTT - aggiornamento automatico 2volte al gg !!
  • Dual feed Hotbird 13° + Astra 19.2° + DTT italia nazionale ( ManuTEK settings by Nemoxyz settingman )
  • [center-img]https://i.imgur.com/LnzYZcQh.jpg[/center-img] [center-img]https://i.imgur.com/FtjDPhOh.jpg[/center-img] [center-img]https://i.imgur.com/WNlSYVRh.jpg[/center-img] [center-img]https://i.imgur.com/oE6idVvh.jpg[/center-img] [center-img]https://i.imgur.com/ZeDsAnnh.jpg[/center-img] [center-img]https://i.imgur.com/QLaojVSh.jpg[/center-img] [center-img]https://i.imgur.com/BWeFoWfh.jpg[/center-img] [center-img]https://i.imgur.com/2ev4Ah8h.jpg[/center-img] [center-img]https://i.imgur.com/TgWN6rah.jpg[/center-img] [center-img]https://i.imgur.com/9Uoa5YMh.jpg[/center-img] [center-img]https://i.imgur.com/Gp0YE9Ah.jpg[/center-img] [center-img]https://i.imgur.com/3baIIfih.jpg[/center-img] [center-img]https://i.imgur.com/X351KyUh.jpg[/center-img] [center-img]https://i.imgur.com/tLGq3PIh.jpg[/center-img] [center-img]https://i.imgur.com/WRntPxjh.jpg[/center-img] [center-img]https://i.imgur.com/v4IHCJAh.jpg[/center-img] [center-img]https://i.imgur.com/f2dVtvah.jpg[/center-img] [center-img]https://i.imgur.com/UrIdCRhh.png[/center-img] Qui sotto in download potrete scaricare il file compresso in RAR al cui interno troverete l'immagine backup in versione Flash by USB che potrete installare comodamente tramite il flashing via USB.[/b] [b][color=#FF0000][u]piccola guida per installazione:[/u][/color][/b] [b][i][list]
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "magibox"
  • PRESTATE MOLTA ATTENZIONE !!! IL NOME CARTELLA PER IL VOSTRO MAGICBOX POTRE ESSERE NECESSARIO CAMBIARLO:
    magicbx , magibox, magibx etc etc...Qualora il backup dovesse non andare potrebbe essere lì il problema!!
  • A DECODER SPENTO INSERITE LA PENNA USB NELL'APPOSITA PORTA ( suggerisco porta usb posteriore!!) ED ACCENDETE IL DECODER DAL BOTTONCINO POSTERIORE
  • ATTENDENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' PIU' in assenza del VISORE DEL DECODER che NON SARA' COMPARSA LA SCRITTA A LED "DONE"
  • A QUESTO PUNTO SPEGNETE IL DECODER DAL BOTTONCINO POSTERIORE RIMUOVETE LA PENNA USB E RIAVVIATE CON LA VOSTRA NUOVA IMMAGINE CARICATA!!
[/i][/b]
Guida MOUNT USB DEVICE & XpiconS ( hotbird 13 + DTT completi originali by Nemoxyz ) [/list][/b]
Versione: SET-2016-V4-GST190
Dimensione: 57.45 MB
Vedi Download: [BCKP] MAGICBOX MG4-HD Nemoxyz OpenVIX-4.2 NOVUMslimHD orangeMOD
Modificato 8 volte da Nemoxyz 10 anni. Motivazione: Le informazioni sono state aggiornate
salve a tutti ragazzi ottimo il sito, volevo solo un aiuto per questa immagine per quanto riguarda l'inserimento delle picon, non riesco ad inserirle nel decoder non trovo la cartella usb che indicate è possibile??? grazie in anticipo.
@nerosoft
Ciao grazie per i complimenti !! facciamo del nostro meglio !! ;) Per le picons le devi mettere su penna usb ( tutte quante sotto la cartella picon , come il file che scarichi in pratica ) , poi collegando la penna usb te le ritrovi operative!!
oppure se la penna è già collegata all porta usb del decoder , tramite filezilla ( ftp client ) le mandi appunto su media/hdd/picon ( oppure media/"nome-dato-alla-penna-usb"/picon , spero di essere stato chiaro !! cmq la cosa migliore è caricare l'intera cartella picon su usb e poi colleghi la penna al dek !! Saluti.
