RELEASE SETTEMBRE 2016 ( V4 )
particolare backup Classic basato su OpenVIX 4.2 [ 005 ] SOFTWARE :
Nemoxyz-OpenVIX4.2-005-GST190-NOVUMslimHDOrangeLight-Zgemma-H2[15-09-2016]usb
[ backup by Nemoxyz - 15 SETTEMPRE 2016 - V4 ]
Versione proposta per decoder AIR SAT DIGITAL
( Zgemma Star H2 )
https://i.imgur.com/bZAuj4k.png?2
OpenVIX 4.2 [005] NOVUM slim HD ORANGE light MOD - GST 1.9.0
https://i.imgur.com/Jh67RRs.jpg
BACKUP FEATURES ( data backup 15-09-2016 - V4 = aggiornamento completo a versione 4.2 - 005 ) :
  • Bootlogo OpenVIX 4.2 - NOVUM slim ORANGElightMOD - by Nemoxyz Design
  • SPINNER SAT.technology power
  • SKIN NOVUM SLIM HD orange light mod by Nemoxyz ( piccole correzioni nei colori )
  • host name = ZGEMMA-H2
  • Password accesso FTP / OpenWebIF = zgemma
  • Codice PARENTAL CONTROL = 1357
  • POWER TIMER IMPOSTATO CON SPEGNIMENTO "DEEP-STANDBY DOPO 10MINUTI DALLO STAND-BY
  • GST 190 Gstreamer ultimissima aggiornata versione integrato in OpenVIX
  • EMC4.0 media player ehnanced -->> Tasto ROSSO ( telecomando zgemma ) !!!
  • TASTO giallo configurato con varie funzioni offerte dal software openVIX ( telecomando zgemma ) !!!
  • BWMON plugin BANDWIDTH MONITOR ( monitoraggio banda lan & wifi )
  • Xmltv importer ( EPG guide ) configurato con Rytec italy (impostato epg.dat su media/hdd)
  • isettingE2 3.3.8 (NUOVISSIMA VERSIONE DEL FAMOSO plugin!)
    Configurazione auto su ManuTEK+DTT - aggiornamento automatico 2volte al gg !!
  • Dual feed Hotbird 13° + Astra 19.2° + DTT italia nazionale ( ManuTEK settings by Nemoxyz settingman )
  • [center-img]https://i.imgur.com/mPemiG1h.jpg[/center-img] [center-img]https://i.imgur.com/etkdUvph.jpg[/center-img] [center-img]https://i.imgur.com/MyAcGTDh.jpg[/center-img] [center-img]https://i.imgur.com/fgQwhSeh.jpg[/center-img] [center-img]https://i.imgur.com/hcmNsdBh.jpg[/center-img] [center-img]https://i.imgur.com/R1tfaN0h.jpg[/center-img] [center-img]https://i.imgur.com/mFXhIyAh.jpg[/center-img] [center-img]https://i.imgur.com/hLOMatch.jpg[/center-img] [center-img]https://i.imgur.com/4pq6AfWh.jpg[/center-img] [center-img]https://i.imgur.com/Am9PhUPh.jpg[/center-img] [center-img]https://i.imgur.com/lk9r3boh.jpg[/center-img] [center-img]https://i.imgur.com/qCmTEv6h.jpg[/center-img] [center-img]https://i.imgur.com/ITdpygph.jpg[/center-img] [center-img]https://i.imgur.com/qkWzN9gh.jpg[/center-img] [center-img]https://i.imgur.com/AeWaJchh.jpg[/center-img] [center-img]https://i.imgur.com/jATkf0Wh.jpg[/center-img] [center-img]https://i.imgur.com/Vo8nNtTh.jpg[/center-img] [center-img]https://i.imgur.com/07ldIHJh.jpg[/center-img] [center-img]https://i.imgur.com/UrIdCRhh.png[/center-img] Qui sotto in download potrete scaricare il file compresso in RAR al cui interno troverete l'immagine backup in versione Flash by USB che potrete installare comodamente tramite il flashing via USB.[/b] [b][color=#FF0000][u]piccola guida per installazione:[/u][/color][/b] [b][i][list]
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "zgemma"
  • A DECODER SPENTO INSERITE LA PENNA USB NELL'APPOSITA PORTA ( porta usb posteriore!!) ED ACCENDETE IL DECODER DAL BOTTONCINO POSTERIORE, comparirà la dicitura FLASH!!
  • ATTENDENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' PIU' E SUL VISORE DEL DECODER NON SARA' SCOMPARSA LA SCRITTA "FLASH" poi il decoder si riavviarà in automatico!!
  • A QUESTO PUNTOIL DECODER ESEGUIRA' AUTONOMAMENTE IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( PER RIUMOVERE LA PENNA USB SPEGNETE IL DECODER E RIMUOVETE!! )
[/i][/b]
[/list][/b]
Versione: SET-2016-v4-GST190
Dimensione: 64.6 MB
Vedi Download: [BCKP] Zgemma-H2 Nemoxyz OpenVIX-4.2 NOVUMslimHD orangeMOD
Modificato 12 volte da Nemoxyz 10 anni. Motivazione: Le informazioni sono state aggiornate
Mono feed Hotbird 13° + DTT italia nazionale ( manutek settings ), ma astra non va , poi la numerazione dei canali sul zgemma h2 rimane sempre sullo zero, dal telecomando i canali vanno avanti
tanti saluti
@siler10
Se leggeste e vi documentaste prima di scrivere..... ( lo abbiamo detto si e no un milione di volte ??? )
quando è montato un settings mono ( in questo hotbird 13 + setting DTT ita nazionale , appunto...come potrebbe andare astra ??? ) il file satellite.xml è impostato solo per mono!!
Serve mettere quello per dual !!!! Questo si può fare solo scaricando una lista dual che lo contiene !!
Ho scritto qui in annuncio globale come si procede -->>
[GUIDA] IMPOSTARE IL DUAL ( HB + ASTRA ) ENIGMA2 ALL
La seconda parte " poi la numerazione dei canali sul zgemma h2 rimane sempre sullo zero, dal telecomando i canali vanno avanti " stento a comprendere cosa tu voglia intendere, se spieghi meglio magari riusciamo a capirci !!
Tanti cari saluti.
ma ci mancherebbe !!! @siler10 non c'è da scusarsi assolutamente !!! ;) dico solo che se leggete il forum a fondo avete a disposizione tante di quelle informazioni & guide che davvero , lo dico senza false modestie, raramente si trovano così ben organizzate!! frutto del lavoro di tutti coloro collaborano qui sul fourm. Un salutone.
io solo questo voglio dire sul mio zgemma star h2 sul display rimane sempre 0 , in pratica , 1 - 2- 3 - 4 . retequattro , canale 5 , 6 e cosi via non ce la progressione, questo volevo dire ieri
@siler10
Ah ok ora ho capito l'errore a cui facevi riferimento !! Si ho individuato !!!
Sto ponendo rimedio è una piccola mancanza nelle impostazioni led display!!!
Sospendo il file....Tempo di sistemare e ricaricare il backup in downloads e sarà disponibile la versione ( V2 ) 20 marzo 2016 !!!
Messaggio aggiunto 46 minuti 43 secondi:
NB: ok corretto !!! potete scaricare il nuovo file !! Saluti !! ;-)
siler10 ha scritto:adesso si avevo visto giusto
Non menzionando "display led" nella tua prima frase....era poco comprensibile ecco perchè del fraintendimento. Nel secondo messaggio ho capito cosa intendessi.
Risolto velocemente!! Saluti e grazie per aver notificato il difetto. ;) bye
Salve raga,stavo provando questa immagine,visto che ancora sto avenndo problemi con il mio zgemma h2 ,appena va via la corrente rimane la scritta boot sul diplay e poi tutto fermo,ho provato mille immagini e mille metodi scritti su vari forum ma il problema persiste..quallcuno di voi ha trovato soluzione...??
@micael1981
Alcuni esemplari zgemma H2 ( come del resto anche il suo predecessore cloud ibox 3 ) hanno questo problema di fragilità in boot insita !!
La sopravvenuta mancanza di corrente determina una corruzione a livello di bootloader che determina a sua volta il mancato loading di sistema.
Il modo migliore per ovviare è quello di provare a spegnere in deepstandby e poi spegnere il bottoncino posteriore.
Non lasciare il decoder in standby semplice!! perchè essendo problematico i ripeterà qualunque software andrai ad utilizzare ( proprio perchè non dipende dal software !! ) puoi provare a reinviare il bootloader per stabilizzarlo, ma la vera "panacea" sarebbe quella di farlo sostituire in garanzia perchè difettato. Saluti.
Buongiorno, volevo chiedere se esistesse un backup con openvix 4, dato che pare abbia altre funzioni come ad esempio le registrazioni da canali i**v. Se avete ulteriori info ve ne sarei grato, saluti
