RELEASE SETTEMBRE 2016 ( V4 )
particolare backup Classic basato su OpenVIX 4.2 [ 005 ] SOFTWARE :
Nemoxyz-OpenVIX4.2-005-GST190-NOVUMslimHDOrangeLight-Zgemma-H2H[16-09-2016]usb
[ backup by Nemoxyz - 16 SETTEMPRE 2016 - V4 ]
Versione proposta per decoder AIR SAT DIGITAL
ZGEMMA - STAR - H.2H ( dual core fisico )
https://i.imgur.com/pbiVbTnh.jpg
OpenVIX 4.2 [005] NOVUM slim HD ORANGE light MOD - GST 1.9.0
BACKUP FEATURES ( data backup 16-09-2016 - V4 = aggiornamento completo a versione 4.2 - 005 ) :
  • Bootlogo OpenVIX 4.2 - NOVUM slim ORANGElightMOD - by Nemoxyz Design
  • SPINNER SAT.technology power
  • SKIN NOVUM SLIM HD orange light mod by Nemoxyz ( piccole correzioni nei colori )
  • host name = ZGEMMA-H2H
  • Password accesso FTP / OpenWebIF = zgemma
  • Codice PARENTAL CONTROL = 1357
  • POWER TIMER IMPOSTATO CON SPEGNIMENTO "DEEP-STANDBY DOPO 10MINUTI DALLO STAND-BY
  • GST 190 Gstreamer ultimissima aggiornata versione integrato in OpenVIX
  • EMC4.0 media player ehnanced -->> Tasto ROSSO ( telecomando zgemma ) !!!
  • TASTO giallo configurato con varie funzioni offerte dal software openVIX ( telecomando zgemma ) !!!
  • BWMON plugin BANDWIDTH MONITOR ( monitoraggio banda lan & wifi )
  • Xmltv importer ( EPG guide ) configurato con Rytec italy (impostato epg.dat su media/hdd)
  • isettingE2 3.3.8 (NUOVISSIMA VERSIONE DEL FAMOSO plugin!)
    Configurazione auto su ManuTEK+DTT - aggiornamento automatico 2volte al gg !!
  • Dual feed Hotbird 13° + Astra 19.2° + DTT italia nazionale ( ManuTEK settings by Nemoxyz settingman )
  • [center-img]https://i.imgur.com/NPsDTSDh.jpg[/center-img] [center-img]https://i.imgur.com/V7SCACBh.jpg[/center-img] [center-img]https://i.imgur.com/MyAcGTDh.jpg[/center-img] [center-img]https://i.imgur.com/fgQwhSeh.jpg[/center-img] [center-img]https://i.imgur.com/hcmNsdBh.jpg[/center-img] [center-img]https://i.imgur.com/R1tfaN0h.jpg[/center-img] [center-img]https://i.imgur.com/mFXhIyAh.jpg[/center-img] [center-img]https://i.imgur.com/hLOMatch.jpg[/center-img] [center-img]https://i.imgur.com/4pq6AfWh.jpg[/center-img] [center-img]https://i.imgur.com/Am9PhUPh.jpg[/center-img] [center-img]https://i.imgur.com/lk9r3boh.jpg[/center-img] [center-img]https://i.imgur.com/qCmTEv6h.jpg[/center-img] [center-img]https://i.imgur.com/ITdpygph.jpg[/center-img] [center-img]https://i.imgur.com/qkWzN9gh.jpg[/center-img] [center-img]https://i.imgur.com/AeWaJchh.jpg[/center-img] [center-img]https://i.imgur.com/jATkf0Wh.jpg[/center-img] [center-img]https://i.imgur.com/Vo8nNtTh.jpg[/center-img] [center-img]https://i.imgur.com/07ldIHJh.jpg[/center-img] [center-img]https://i.imgur.com/UrIdCRhh.png[/center-img] Qui sotto in download potrete scaricare il file compresso in RAR al cui interno troverete l'immagine backup in versione Flash by USB che potrete installare comodamente tramite il flashing via USB.[/b] [b][color=#FF0000][u]piccola guida per installazione:[/u][/color][/b] [b][i][list]
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "zgemma"
  • A DECODER SPENTO INSERITE LA PENNA USB NELL'APPOSITA PORTA ( porta usb posteriore!!) ED ACCENDETE IL DECODER DAL BOTTONCINO POSTERIORE, comparirà la dicitura FLASH!!
  • ATTENDENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' PIU' E SUL VISORE DEL DECODER NON SARA' SCOMPARSA LA SCRITTA "FLASH" poi il decoder si riavviarà in automatico!!
  • A QUESTO PUNTOIL DECODER ESEGUIRA' AUTONOMAMENTE IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( PER RIUMOVERE LA PENNA USB SPEGNETE IL DECODER E RIMUOVETE!! )
[/i][/b]
Guida MOUNT USB DEVICE & XpiconS ( hotbird 13 + Astra + DTT completi originali by Nemoxyz )
[/list][/b]
Versione: SET-2016-v4-GST190
Dimensione: 59.5 MB
Vedi Download: [BCKP] ZGEMMA-STAR H.2H Nemoxyz OpenVIX-4.2 NOVUMslimHD orangeMOD
Modificato 5 volte da Nemoxyz 10 anni. Motivazione: Le informazioni sono state aggiornate
qualcuno di voi ha avuto qualche problema con il plugin media scanner? se lo avvio mi crasha tutto
hai ragione. funziona tutto. Grazie mille
@Nemoxyz, scusa ma hovisto che non ci sono release con *********. E' una scelta oppure arriverranno? GRAZIE
Salve @cepx premetto il fatto che non sarebbe questa la sede giusta per un commento del genere ( qui si parla di backup openVIX4.2 per zgemmaH.2H )...cmq si è da molto tempo ( parecchi mesi , circa 1anno credo...) che per scelta evitiamo release ed abbiamo operato in rispetto del team della image da te menzionata. Regolamento punto 2 comma 8 -->>> rules
cepx
