Sezione dedicata ai decoder EVO NOVA Combo
https://i.imgur.com/dHZnYjUh.jpg
NUOVISSIMA RELEASE VERSIONE BACKUP "GREEN ARROW BLACK LEATHER v1.0"
BASE IMAGE( ULTIMA RELASE DI EGAMI NEW IMAGE 8 mod per EVO NOVAcombo )
Versione-BACKUP= Ver5-Egami8.0.6 = 01 FEBBRAIO 2018 ( COMPLETO AGGIORNAMENTO new image base EGAMI 8.0.6 GST1.11.2 )
DESCRIZIONE
QUESTA RELEASE E' UN'ELEGANTE "FRECCIA VERDE LUMINOSA" SCOCCATA NELLE TENEBRE DI ENIGMA2 !!!BACKUP IMPRESSIONANTE CON FEATURES FENOMENALI !!!
SKIN "DARK" DA GUSTARE E SCOPRIRE GIORNO DOPO GIORNO su base EGAMI 8.0.6
L'AMBIENTAZIONE DARK IN ONORE AL CONTROVERSO BENIAMINO DC comics ARROW rende tale BACKUP una rarità nel panorama Enigma2 ( elaborazioni grafiche Nemoxyz-Design )
DISPOSITIVO & MODELLO :
Adatto ad un dispositivo Enigma2 EVO NOVAcombo DRIVERS COMBO SAT+DTT TUNER (sat) correttamente installati
[/size]
https://i.imgur.com/RZ3CkKmh.jpg
GSTREAMER PLAYER & KERNEL
GST 1.11.2 + exteplayer3 default ( impostato tramite serviceapp )
KERNEL 4.10.6
SKIN BACKUP
E G A M I 8.0.6 -----SatTEK - GREEN ARROW BlackLEATHER
https://i.imgur.com/XdW88cmh.png
NOME FILE in download
Nemoxyz-EGAMI-8.0.6-exteP3+VODplay-(isetE2-341+EPGimp+EMC4+Bmon+Ytube)-NOVAcombo
[ backup by Nemoxyz - 01 FEBBRAIO 2018 ]
BACKUP FEATURES
  • New --->> Bootlogo --> NEW SAT.TECHNOLOGY GREEN ARROW BLACK LEATHER ( Nemoxyz design )
  • SPINNER NEW -->> SAT.TECHNOLOGY "MIRAKURU DESIGN GREEN POWER" version G-A-B-LV1.0
  • host name = NOVAcombo ( nome LAN - samba )
  • Exteplayer + GSTREAMER GST 1.11.2 massima fluidità !!!
  • EGAMI 8 INTEGRA IL VOD-PLAYER IN CHANNEL LIST !!
  • Plugin YOUTUBE per visionare i vostri video preferiti
  • EMC 4.0 movie center installato , attivabile tramite tasto file list/media
    ( https://sat.technology/viewtopic.php?f=89&t=32006 )
  • EGAMI BACKUP-TOOL INTEGRATO MOD by Nemoxyz ( revision GIU 2017 ) per NOVAcombo
  • ManuTEK settings 17-01-2018 (NemoxyzSATtv SAT+DTT nazionale)
https://i.imgur.com/BS3Xu2yh.jpg
https://i.imgur.com/Xsx3wlSh.jpg
https://i.imgur.com/SrOkliBh.jpg
https://i.imgur.com/ROv8nCxh.jpg
https://i.imgur.com/K62EOdzh.jpg
https://i.imgur.com/to9HJ4Fh.jpg
https://i.imgur.com/0pfslnch.jpg
https://i.imgur.com/MJqm7eph.jpg
https://i.imgur.com/z8vnNBHh.jpg
https://i.imgur.com/zn1xRjFh.jpg
https://i.imgur.com/mAGRDrMh.jpg
https://i.imgur.com/bnjfpUQh.jpg
https://i.imgur.com/RXhQXcgh.jpg
https://i.imgur.com/qNKhXH8h.jpg
https://i.imgur.com/EaaO2EGh.jpg
https://i.imgur.com/n6p8eJlh.jpg
https://i.imgur.com/dnk5Nnfh.jpg
https://i.imgur.com/UF7WrJZh.jpg
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME"novacombo"
  • A QUESTO PUNTO IL DECODER ESEGUIRA' AUTONOMAMENTE IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( PER RIMUOVERE LA PENNA USB SPEGNETE IL DECODER E RIMUOVETE altrimenti si creano errori su usb!! )
Guida MOUNT USB DEVICE & XpiconS ( hotbird 13 + DTT completi originali by Nemoxyz ) Guida INSTALLAZIONE METEO e selezione località tramite plugin dedicato myMETRIX-MOD Weather TOOL ( mod by Nemoxyz )
  • DA MENU - PLUGIN ( o tasto verde ) - myMETRIX-MOD Weather
    https://i.imgur.com/H0rGHTbh.jpg
  • SEGUITE LE ISTRUZIONI A VIDEO ALL'INTERNO DEL PANNELLO DI SETUP DEL PLUGIN!! SALVATE E RIAVVIATE ED AVRETE LA VOSTRA LOCALITA' METEO!!
    https://i.imgur.com/8FiVimoh.jpg
Versione: FEB2018-Ver5
Modificato 12 volte da Nemoxyz 9 anni. Motivazione: Le informazioni sono state aggiornate
