Backup e Tools per MAGICBOX MG4 HDhttps://i.imgur.com/dHZnYjUh.jpg
NUOVISSIMA RELEASE VERSIONE BACKUP "GREEN ARROW BLACK LEATHER v1.0"
BASE IMAGE( ULTIMA RELASE DI EGAMI NEW IMAGE 8 mod per per Miraclebox MBmini )
Versione-BACKUP= Ver1-Egami-8.0.6 = 22 NOVEMBRE 2017
DESCRIZIONE
QUESTA RELEASE E' UN'ELEGANTE "FRECCIA VERDE LUMINOSA" SCOCCATA NELLE TENEBRE DI ENIGMA2 !!!BACKUP IMPRESSIONANTE CON FEATURES FENOMENALI !!!
SKIN "DARK" DA GUSTARE E SCOPRIRE GIORNO DOPO GIORNO su base EGAMI 8
L'AMBIENTAZIONE DARK IN ONORE AL CONTROVERSO BENIAMINO DC comics ARROW rende tale BACKUP una rarità nel panorama Enigma2 ( elaborazioni grafiche Nemoxyz-Design )
DISPOSITIVO & MODELLO :
Adatto ad un dispositivo Enigma2 MAGICBOX MG4-HD DRIVERS COMBO SAT+DTT TUNER (sat) correttamente installati
https://i.imgur.com/c9nYyrXh.jpg
GSTREAMER PLAYER & KERNEL
GST 1.11.2 + exteplayer3 default ( impostato tramite serviceapp )
NEW KERNEL 3.12.1
SKIN BACKUP
E G A M I 8.0.6 -------SatTEK - GREEN ARROW BlackLEATHER
https://i.imgur.com/XdW88cmh.png
NOME FILE in download
Nemoxyz-EGAMI-8.0.6-exteP3+VODplay-(isetE2-341+EPGimp+EMC4+Bmon+Ytube)-MG4-HD
[ backup by Nemoxyz - 22 NOVEMBRE 2017 ]
BACKUP FEATURES
  • New --->> Bootlogo --> NEW SAT.TECHNOLOGY GREEN ARROW BLACK LEATHER ( Nemoxyz design )
  • SPINNER NEW -->> SAT.TECHNOLOGY "MIRAKURU DESIGN GREEN POWER" version G-A-B-LV1.0
  • host name = MG4-HD ( nome LAN - samba )
  • IMPOSTATO AUTOSTANDBY DA MENU POWERtimer stand-by ( DOPO 120 MIN di standby va in deepstandby !! ) !!!
  • Exteplayer + GSTREAMER GST 1.11.2 massima fluidità !!!
  • EGAMI 8 INTEGRA IL VOD-PLAYER IN CHANNEL LIST **tasti attivi ( migliorato OSD in VODplay ) !!
  • EMC 4.0 movie center installato , attivabile tramite tasto file list/media
  • RED KEY = EPGimporter setup , settato per il download giornaliero EPG ( new sources ott 2017 )
  • EGAMI BACKUP-TOOL INTEGRATO MOD by Nemoxyz ( revision SET 2017 ) per MBminiplus
  • ManuTEK settings 16-11-2017 (NemoxyzSATtv SAT+DTT nazionale)
https://i.imgur.com/coQYAish.jpg
https://i.imgur.com/Xsx3wlSh.jpg
https://i.imgur.com/SrOkliBh.jpg
https://i.imgur.com/ROv8nCxh.jpg
https://i.imgur.com/K62EOdzh.jpg
https://i.imgur.com/to9HJ4Fh.jpg
https://i.imgur.com/0pfslnch.jpg
https://i.imgur.com/MJqm7eph.jpg
https://i.imgur.com/z8vnNBHh.jpg
https://i.imgur.com/zn1xRjFh.jpg
https://i.imgur.com/mAGRDrMh.jpg
https://i.imgur.com/bnjfpUQh.jpg
https://i.imgur.com/RXhQXcgh.jpg
https://i.imgur.com/qNKhXH8h.jpg
https://i.imgur.com/EaaO2EGh.jpg
https://i.imgur.com/dnk5Nnfh.jpg
https://i.imgur.com/t2Qlkrsh.jpg
https://i.imgur.com/UF7WrJZh.jpg
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME "magibox" ( o magicbx a seconda del modello )
  • ATTENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' ( circa 8-90 minuti ), RIMUOVERE LA PENNA USB E RIACCENDERE.
  • A QUESTO PUNTO IL DECODER ESEGUIRA' IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( ATTENZIONERIMUOVETE LA PENNA USB SOLO DOPO AVER SPENTO IL DECODER!! )
Guida INSTALLAZIONE METEO e selezione località tramite plugin dedicato myMETRIX-MOD Weather TOOL ( mod by Nemoxyz )
  • DA MENU - PLUGIN ( o tasto verde ) - myMETRIX-MOD Weather
    https://i.imgur.com/H0rGHTbh.jpg
  • SEGUITE LE ISTRUZIONI A VIDEO ALL'INTERNO DEL PANNELLO DI SETUP DEL PLUGIN!! SALVATE E RIAVVIATE ED AVRETE LA VOSTRA LOCALITà METEO!!
    https://i.imgur.com/8FiVimoh.jpg
Versione: NOV2017-Ver1
Vedi Download: [BCKP] MAGICBOX MG4-HD Nemoxyz EGAMI 8.0.6 extePlayer3 Green ARROW BlackLeather
Modificato 9 volte da Nemoxyz 9 anni. Motivazione: Le informazioni sono state aggiornate
@marioioio
Solo al tuo esemplare succede questa cosa purtroppo !!! Sul magicbox che uso per fare il backup si accende e si spegne senza problemi.
Per cui ergo e ti ripeto ancora una volta il problema è locale e ristretto sul tuo esemplare e non un qualcosa di universale.
Prima di affermare una cosa bisogna esserne certi.
Purtroppo è un difetto all'origine credo!! è di fabbrica nata male la flash del tuo esemplare e che genera qst problema.
Se hai provato tutti i software da openpli a egami , passando per openatv etc etc non c'è soluzione se non cambiare decoder e prendere un modello con meno problemi.
Consigli per gli acquisti
Bella immagine,peccato che per scaricare da pannello quello che "serve" chiede di aggiornare...ma se si aggiorna si rischia di mandare in blocco il decoder?
@puppeapera la versione del 4 febbraio del backup ( perchè di baclup si tratta !!) è una 7.2.16 ultima versione non si deve aggiornare nulla e si scarica tutto quello che vuoi !! Strano che faccia questa richiesta!! cmq non dovrebbe bloccare nulla eventualmente saluti.
Buongiorno perché non mi da il tuner sat lo vado a configurare e mi riporta alla schermata tuner non configuraoto
@felice.t molto strano !!! quando ho creato il backup tutto perfetto sull'esemplare sia il tuner SAT che DTT !! Inoltre altri utenti lo usano senza problemi !! Prova a montare un altroi backup od altra image per fare riscontro.
marioioio ha scritto: 9 anni salve anche questa immagine ha il problema che il decoder non si spegne
Anche a me succcede, in più ho delle difficoltà a far assegnare un indirizzo ip, sia tramite protocollo DHCP ,sia tramite indirizzo statico
