Sezione dedicata ai dispositivi Apple iPhone & iPad
Moderatore: Content Writers
GSE Smart IPTV Pro -- ( App-Store available )
https://i.imgur.com/M6nmHB7m.jpg
E un'applicazione perfetta per coloro i quali si accostano al mondo della IPTV con dispositivi Apple!! Supporta pienamente la lingua italiana , straordinariamente molto semplice utilizzare questa applicazione che si presenza completamente gratuita e completa
GSE Smart IPTV Pro è in grado di leggere le liste M3U ( il formato più diffuso ) ma anche altri tipi di liste!!
Principali funzionalità di GSE Smart IPTV Pro
– Built-in powerful player , No need to look for third party player to support these formats
– Support : Local M3U Playlists (user can upload via FTP)
– Support : Remote Playlists (User can add their http remote playlists)
– Support : Secure Playlist (No need to type full url , just register http url with username , please note no need to provide user email)
– Support : Database Playlist (User can add their local playlists to database , then edit , add , delete etc … )
– Support : Export database playlist to M3U format (export file can be found on and download via FTP , can be use even as M3U beautifier)
– Support : EPG in XMLTV format (xml , zip , gz formats allowed). EPG xmltv formats can be import from local or also support remote epg source.
Remote epg source can be updated regularly.
– Support : Playlist can be upload via FTP or HTTP web interface
– Faster and better intelligence M3U parser. M3U playlist should start with #EXTM3U , and playlists should be properly formated , but our intelligent parser has ability to detect , fix and correct error lines
– Advanced built in player features :
Our player support almost all popular formats including RTMP with all options including tokens. No need to define seperate options , just pass whole rtmp url with options , our application will handle the rest.
– Subtitle support in srt formats , can be upload via FTP or HTTP
Funzioni extra di GSE Smart IPTV Pro
– Youtube support– Favourite playlist
– User can now add favourite channels from local , remote , database etc
– Favourite playlist can be export to M3U, import back to database–. Download Remote playlist to Local
– User can now directly download http remote playlist to local playlist– Remote playlist can be add to database straight away– View playlist contents
– User can now view what is inside the M3U/JSON playlist content for LOCAL/REMOTE
– Good for the beginner to see how M3U/JSON playlist works– Dynamic Language support features
– Language set to default language , however users can switch between 31 languages without changing device language setting.
