Nome: [IMAGE] ZGEMMA H5 Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 31-OTTOBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 ZGEMMA H5 H265ready ( CPU MIPS )
https://i.imgur.com/tNrKSld.png
FEATURES:
- XKlass plugin installato da configurare con vostre liste
- EPGimporter ( EPG guide ) configurato con SATtek Rytec Sources -> TASTO GIALLO TELECOMANDO
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (19 MAGGIO 2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
Versione: SATtekBUILD-Ver1 [31-10-2025]
File: SATtekCBGInterstellarATV-7.6.0-zgemmah5-20251031_usb.zip
Dimensione: 151.47 MB
Vedi Download: [IMAGE] ZGEMMA H5 Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 28 volte da Nemoxyz 9 anni. Motivazione: Download Aggiornato
nemo ho scoperto il problema, allora ho messo il backup opentatv ma niente ancora problemi con la wifi addirittura mi diceva non connesso quando invece lo era ma sempre veramente scarso, poi ho scaricato la openatv pura e vanno alla grande come potrei risolvere? il tuo backup è troppo bello per rinunciarci...
spostato sotto openATV backup!! @fracd
Il mio backup parte dalla openATV pura !! per cui che gran stranezza mi viene da dire !!??? ( non tocco nulla sul lato wifi anche perchè non la uso durante la creazione dei backup !! lascio poi all'utente eventualmente di installare il tutto come tu hai fatto !! ).
L'unica cosa che posso pensare è che deduco che nel frangente fra la release da me fatta ( ormai marzo..) potrebbero aver migliorato qlcsa in sezione drivers per wifi usb !??? dammi il tempo di creare il backup nuovo con la nuova base di maggio ed avrai la tua versione con la skin e mie ottimizzazioni !! ;) Saluti.
Nemo buonasera alla fine ho scelto questo backup fluido e completo di tutto...volevo esporti un piccolo problema sto guardando alcuni canali h265 in streaming e sorpresa alcuni si vedono davvero bene ed altri sento solo l'audio sai da cosa può dipendere? Da smartphone ad esempio sono tutti visibili il problema si presenta da decoder potrebbe essere un problema di codec che ne pensi?
E' sicuramente un problema di codec non ci sono dubbi !!! Ma poi in streaming un canale H265 ??( presumo un full Hd 1080p ?? ) mi sembra una esagerazione ed una forzatura considerando la debolezza di fondo delle reti adsl/fibra nazionali. In ogni caso si la risposta corretta è il "codec" che non interpreta bene! Saluti.
Si alla fine è un full HD 1080p...hanno fa poco attivato la fibra 100mb 80 reali...si può fare qualcosa per correggere i codec? Cambiando immagine c'è la possibilità che i codec funzionino a dovere?
Non credo...considera che le images sono varie con funzioni diverse ma enigma2 è lo stesso per tutte di base. Ma poi non capisco perchè mai complicare le cose con un codec non ancora molto diffuso...sinceramente mi sembra controproducente!
Nemo buonasera mi sta succedendo una cosa strana da stamattina, premendo il tasto fav mi apre la lista favoriti ma invece di partire da manutek best2017 parte fa favourites sto impazzendo a capire come mai...puoi aiutarmi?
Quando si aggiorna la lista settings in automatico è normale ( è un bug irrisolto di enigma2 ) devi premere blu salire di livello selezionare una cartella bouquet e dentro un canale e poi dal prossimo riavvio sarà tutto ok !! Saluti.
Grazie Nemo stavo impazzendo...ascoltaa c'è un modo per evitare che al cambio canale ci sia un buffer di pochi secondi... è fastidioso
No è una caratteristica dei drivers air sat digital degli zgemma. Non si può fare nulla dipende dal buffer che si crea per gli streaming, sui veri canali nn succede!! Ci si deve accontentare ;)
  • 1
  • 2
  • 3
  • 4
  • 5
  • 14
