hi, sorry for writing in english. I'm not italian..
1st question: How can change the loading symbol in the left corner?
2nd question: How can deactive/uninstall the updates every few hours (right corner on screen)?
thank you all :) Grazie
Hi @gunner41 no problem I can understand English quite well so you can feel comfortable and we can talk in this language smoothly.
First fo all : I moved your topic to the appropriate location under the magicbox mg4 hd forum
Well , coming to technical answers :
1) The symbol in the left corner the right "name" is "spinner" !! It's a turbine rolling , our logo ( sat.technology - Nemoxyz's backups logo ) so changing it , should be a no-sense operation, sorry if answer you in this way!! If you choice us, using our backup you have to accept also our logos ;) I think...
Anyway if you look for it you can change by overwriting relative "png" files in this position " /usr/share/enigma2/spinner/
2) You write about "updates" alerts incoming in the right of the screen, but wich backup-image are you talking about ? Maybe EGAMI backup image ?? or other ??
kind regards.
Hi! Thanks for your fast replay :)
I like your Backups and I am really glad I found your page, you are doing great work!
But unfortunately, I cant find the Spinner folder I could change the loading symbol in the left corner. Do you know how can I Change it?
Thanks!
Hello !! Pleased to be helpfull !! Well, you can find "spinner" directory by using FTP client like "filezilla client" do you understand what I mean ?
Regards.
