Sezione dedicata ai decoder HEROBOX EX3 HD (combo tuner sat e dtt)
https://i.imgur.com/dHZnYjUh.jpg
NUOVISSIMA RELEASE VERSIONE BACKUP "GREEN ARROW BLACK LEATHER v1.0"
BASE IMAGE( ULTIMA RELASE DI EGAMI NEW IMAGE 8 mod per Herobox EX3-HD )
Versione-BACKUP= Ver2 - Egami8.0.3 = 14 GIUGNO 2017 ( image MOD su base EGAMI 801 GST1.11.2 )
DESCRIZIONE
QUESTA RELEASE E' UN'ELEGANTE "FRECCIA VERDE LUMINOSA" SCOCCATA NELLE TENEBRE DI ENIGMA2 !!!BACKUP IMPRESSIONANTE CON FEATURES FENOMENALI !!!
SKIN "DARK" DA GUSTARE E SCOPRIRE GIORNO DOPO GIORNO su base EGAMI 8.0.1
L'AMBIENTAZIONE DARK IN ONORE AL CONTROVERSO BENIAMINO DC comics ARROW rende tale BACKUP una rarità nel panorama Enigma2 ( elaborazioni grafiche Nemoxyz-Design )
DISPOSITIVO & MODELLO
Adatto ad un dispositivo Enigma2 Herobox EX3-HD DRIVERS SAT + DTT combo TUNER correttamente installati
https://i.imgur.com/qjNhvyhh.jpg
GSTREAMER PLAYER & KERNEL
GST 1.11.2 + exteplayer3 default ( impostato tramite serviceapp )
KERNEL 3.12.1
SKIN BACKUP
E G A M I 8.0.3 -------SatTEK - GREEN ARROW BlackLEATHER
https://i.imgur.com/XdW88cmh.png
NOME FILE in download
Nemoxyz-EGAMI-8.0.3-exteP3+VODplay-(isetE2-339+EPGimp+EMC4+Youtube+Bmon)-EX3-HD
[ backup by Nemoxyz - 14 GIUGNO 2017 ]
BACKUP FEATURES
  • New --->> Bootlogo --> NEW SAT.TECHNOLOGY GREEN ARROW BLACK LEATHER ( Nemoxyz design )
  • SPINNER NEW -->> SAT.TECHNOLOGY "MIRAKURU DESIGN GREEN POWER" version G-A-B-LV1.0
  • New Widgets & Labels introdotti ( esclusivi Nemoxyz modding della SKIN !! )
  • Tuner SAT+ usb DTT tuner ready ( tramite feeds ) AUTOMATICAMENTE SETTATO ( TUNER A SAT )
  • host name = Herobox-EX3-HD ( nome LAN - samba )
  • IMPOSTATO AUTOSTANDBY DA MENU POWERtimer stand-by ( DOPO 120 MIN di standby va in deepstandby !! ) !!!
  • Exteplayer + GSTREAMER GST 1.11.2 massima fluidità !!!
  • EGAMI 8.0.3 INTEGRA IL VOD-PLAYER IN CHANNEL LIST !!
  • EMC 4.0 movie center installato , attivabile tramite tasto file list/media
  • EGAMI BACKUP-TOOL INTEGRATO MOD by Nemoxyz ( revision GIUGNO 2017 ) per Herobox EX SOLO PRO V3 ( toolscript NCS = new-change-system , tale script accessibile da MENU-pannelloEGAMI-TooSCRIPTs è stato implementato da Nemoxyz al fine di consentire il cambio nome dei files backup e rendere la cartella completamente compatibile conil dispositivo in uso )
  • isettingE2 3.3.9( configurazione auto su ManuTEK thanks to Diamondear !! PROVINCE DTT SELEZIONABILI !! )
  • ManuTEK settings 03-06-2017 (NemoxyzSATtv SAT+DTT nazionale)
https://i.imgur.com/1ZUST7Gh.jpg
https://i.imgur.com/Xsx3wlSh.jpg
https://i.imgur.com/SrOkliBh.jpg
https://i.imgur.com/ROv8nCxh.jpg
https://i.imgur.com/K62EOdzh.jpg
https://i.imgur.com/to9HJ4Fh.jpg
https://i.imgur.com/0pfslnch.jpg
https://i.imgur.com/MJqm7eph.jpg
https://i.imgur.com/z8vnNBHh.jpg
https://i.imgur.com/zn1xRjFh.jpg
https://i.imgur.com/mAGRDrMh.jpg
https://i.imgur.com/bnjfpUQh.jpg
https://i.imgur.com/RXhQXcgh.jpg
https://i.imgur.com/qNKhXH8h.jpg
https://i.imgur.com/EaaO2EGh.jpg
https://i.imgur.com/Kc6qwIEh.jpg
https://i.imgur.com/dnk5Nnfh.jpg
https://i.imgur.com/UF7WrJZh.jpg
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "herobox"
  • ATTENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' ED A MONITOR TV NON VI DIRA' DI SPEGNERE DECODER, RIMUOVERE LA PENNA USB E RIACCENDERE.
  • A QUESTO PUNTO IL DECODER ESEGUIRA' IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( ATTENZIONE RIMUOVETE LA PENNA USB SOLO DOPO AVER SPENTO IL DECODER!! )
[/i]
Guida MOUNT USB DEVICE & XpiconS ( hotbird 13 + DTT completi originali by Nemoxyz ) Guida INSTALLAZIONE METEO e selezione località tramite plugin dedicato myMETRIX-MOD Weather TOOL ( mod by Nemoxyz )
  • DA MENU - PLUGIN ( o tasto verde ) - myMETRIX-MOD Weather
    https://i.imgur.com/H0rGHTbh.jpg
  • SEGUITE LE ISTRUZIONI A VIDEO ALL'INTERNO DEL PANNELLO DI SETUP DEL PLUGIN!! SALVATE E RIAVVIATE ED AVRETE LA VOSTRA LOCALITà METEO!!
    https://i.imgur.com/8FiVimoh.jpg
Versione: GIU2017-Ver2
Dimensione: 75.47 MB
Vedi Download: [BCKP]Herobox EX3-HD Nemoxyz EGAMI 8.0.3 extePlayer3 Green ARROW BlackLeather
Modificato 5 volte da Nemoxyz 9 anni. Motivazione: Le informazioni sono state aggiornate
