Sezione dedicata ai decoder mut@nt HD51 4K UHD 2160p combo tuners
Nome: [IMAGE] mut@nt HD51 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 05-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 MUTANT HD51 4K ( CPU ARM )
https://i.imgur.com/e22WMzz.png
FEATURES:
iSettingE2 OE2.x - NEW VER - v3.6.3r1 - ( 09 MAGGIO 2025 )
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [05-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-mutant51-20251105.rar
Dimensione: 269.93 MB
Vedi Download: [IMAGE] mut@nt HD51 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 21 volte da Nemoxyz 8 anni. Motivazione: Download Aggiornato
Ma solo 6,22 Mb ? E' possibile ? Ci sta un errore o non ho capito qualcosa? Poi non mi risulta esatta la procedura per flashare. Col mio Mut@nt per flashare la pennetta usb va messa nella porta usb anteriore,poi per fare avviare la procedura devo togliere l'alimentazione e rimetterla tenendo premuto il tasto anteriore . Forse non avendo a disposizione il decoder sei stato fuorviato.
@crax56 ti ho spostato sotto il topic ufficiale del package settings di cui stai parlando altrimenti andiamo al manicomio!! Scrivete sempre sotto quello cui vi riferite!! ;) è meglio !!
Forse non hai letto bene le descrizioni ???
Attenzione
La versione proposta consta di software base (da scaricare da questoLINK) non configurato + speciale pacchetto IPK di configurazione.Per mancanza "fisica" del dispositivo su cui lavorare è stato implementato un pacchetto automatizzato di configurazione completa per il dispositivo in uso.Ad operazione completata ( LEGGETE ISTRUZIONI IN BASSO !!! ) avrete il decoder configurato come da shots rappresentativi !! )
SCARICATE IL SOFTWARE IMAGE BASE DA QUESTO LINK SCOMPATTATE IL FILE E TROVERETE UN CARTELLA DENTRO DAL NOME "hd51"
Siccome la image base è molto grande non posso caricarla tutta insieme al package settings!! per cui ho messo link esterno ( diretto per prendere la image base ) e il pacakge settings per poter operare la configurazione e settaggio e creare in automatico il backup come lo vedi in foto!!
Adesso ti è più chiaro ?? Cmq se avessi letto le descrizioni in toto avresti capito meglio ;) Bisogna sempre leggere !! Fin dalla prima riga di quello che viene scritto!! ;)
Per quanto riguarda la procedure flash usb hai ragione non avendo il decoder non sapevo che si dovesse fare in questo modo!! Ora la modifico per i posteri!! GRazie della segnalazione!! Saluti.
Hai Ragione .Non ho letto attentamente convinto che fosse un backup solito.Ma per quanto riguarda le modalità di flash della immagine stai parlando di un Mut@nt diverso dal mio nelle modalità di fare il flash?Il mio è HD51 4K-HEVC.
@crax56 non ci stiamo capendo. :-D
Il concetto base è che il mutant HD51-4K ( cui stiamo facendo riferimento ) si è quello !!! no problem !! Non lo abbiamo come parco macchine su cui creare un vero e proprio backup ( lo scrivo in descrizione le motivazioni...se ora hai letto capirai !! )
Cmq in breve, non avendo il decoder , un backup nel vero senso della parola non si può realizzare, per cui mesi fa ho inventato e progettato personalmente questa modalità del package settings!! Per estendere il nostro supporto a tutti i modelli che non abbiamo fisicamente e che verranno eventualmente richiesti da voi utenti.
( vedi in firma richiesta pacakge settings + skin : viewtopic.php?f=3&t=37283 ).
Essa consiste in una fase iniziale di installazione del software base come classicamente conosci!! Nè più nè meno ( l'installazione software è la stessa sempre!! ) !! Poi al fine di impostare tutto come se fosse un backup c'è questo package (IPK , tipica estensione dei pacchetti di installazione enigma2 ) che consente con una semplice operazione di avere il decoder configurato come se fosse un backup.
( leggi attentamente passo passo le istruzioni nelle descrizione su come si monta qst package settings )
Spero di essere stato chiaro se hai altre domande sono qui per rispondere. Ad ogni modo se tu segui passo passo la guida giungi ad una perfetta configurazione. Saluti.
si puo' usare questo backup setting per la versione openatv 6.1 ?
Ha scritto dopo 25 minuti 27 secondi:
si puo’ usare questo backup setting per la versione openatv 6.1 ?
Che intendi dire ?? nn capisco..... i picons sono gli stessi che hai usato anche prima....per cui che differenza fa ??
Nemoxyz ha scritto: 8 anni
allora ho installato la openatv 6.1 , zero problemi per il cambio canali che si aveva con la open Pili 6.1.
adesso, per i picons posso usare questi?
ho seguito la guida per installare epg su chiavetta .
l ho chiamata sempre HDD ( in grande) , ho inserito il file misc... che mancava in settings, adesso se vado in ftp non trovo la cartella HDD per copiare i picons.
come faccio ?
@niellodj che gran confusione..... :x :-o :-o :-o :-/ :-/ :-/
Si puoi usare gli unici che abbiamo a disposizione !! Questi non so a cosa ti riferisci!! sono tutti uguali per tutti i backup i picons non cambiano cambia solo la dimensione !!
Per skin HD usi la 220x132 per skin FullHD usi la 417x250 molto semplice!!! li trovi tutti qui : Categoria DOWNLOADs:   Enigma2 Picons & XpiconS
Sono gli stessi che sono annoverati alla fine di ogni descrizione , di ogni backup e di ogni modello...se ci fai caso!!!
Con openATV non hai tutti questi problemi come con openpli !! non seve a nulla rinominare in HDD lo abbiamo scritto in lungo e largo per il forum... :-) ma tutti tendiamo ad avre qst cattiva abitudine di non leggere e documentarci purtroppo....
Rifai tutto, collega pennetta ed openATV ha l'automount automatico !! la trovi in media/hdd senza far nulla !!! assicurati soltanto che sia formatta FAT32 in modo completo!!!
Per openpli non so dirti il perchè faccia questo rallentamento...forse era un momento non so dirti...dovrei avere un HD51 per provare così a distanza difficile capire...
Cmq openATV 6.1 è perfetta per Hd51 e vai tranquillo!! Presto aggiorno tutta la sezione Hd51 dei package settings.
scusami per far sì che gli epg vengano salvati nella pennetta, devo inserire il file in setting mic epg con HDD ?
e poi la chiavetta devo formattarlo in fat 32 con quale nome?
Devi usare la configurazione dove hai letto con "misc" impostato su media/hdd ( non HDD ) e cmq...non ha davvero molto senso fare questa cosa io lascerei default in etc/enigma2/epg.dat !!! perchè mutant HD51è velocisssimo ha tantissimo spazio 1GB su flash cosa serve che metti epg su pennetta ??? nulla....ne abbiamo già parlato anche di questo.. :-)
quindi la chiavetta la formatto in fat32 la nomino hdd e se voglio cambiare i settings devo mettere hdd piccolo no HDD ( strano su dm800 se con hd interno si metteva hdd piccolo).
grazieee
@silvio1963 per prima cosa ho spsotato i post s[…]
