Sezione dedicata ai decoder ATEMIO 6200 HD (combo tuner: sat e dtt)
https://i.imgur.com/wCCi7Uph.png
NUOVISSIMA RELEASE VERSIONE BACKUP "GREEN ARROW BLACK LEATHER v1.0"
BASE IMAGE( ULTIMA RELASE DI EGAMI NEW IMAGE 8 mod )
Versione-BACKUP= Ver1-Egami-8.1 = 05 APRILE 2018
DESCRIZIONE
QUESTA RELEASE E' UN'ELEGANTE "FRECCIA VERDE LUMINOSA" SCOCCATA NELLE TENEBRE DI ENIGMA2 !!!BACKUP IMPRESSIONANTE CON FEATURES FENOMENALI !!!
SKIN "DARK" DA GUSTARE E SCOPRIRE GIORNO DOPO GIORNO su base EGAMI 8
L'AMBIENTAZIONE DARK IN ONORE AL CONTROVERSO BENIAMINO DC comics ARROW rende tale BACKUP una rarità nel panorama Enigma2 ( elaborazioni grafiche Nemoxyz-Design )
DISPOSITIVO & MODELLO :
Adatto ad un dispositivo Enigma2 ATEMIO 6200 HD DRIVERS SAT+DTT TUNER ready correttamente installati
https://i.imgur.com/qERcG6eh.jpg
GSTREAMER PLAYER & KERNEL
GST 1.13 + exteplayer3 default ( impostato tramite serviceapp + possibilità di selezionare GSTplayer )
KERNEL 3.14.2
SKIN BACKUP
E G A M I 8.1 -------SatTEK - GREEN ARROW BlackLEATHER
https://i.imgur.com/0pgKUhrh.png
NOME FILE in download
Nemoxyz-EGAMI-8.1-GreenARROWBLv1-(exteP3+GSTp-isetE2-341+EPGimp+EMC4+Bmon+Ytube)-ATEMIO-6200HD
[ backup by Nemoxyz - 05 APRILE 2018 ]
BACKUP FEATURES
  • New --->> Bootlogo --> NEW SAT.TECHNOLOGY GREEN ARROW BLACK LEATHER ( Nemoxyz design )
  • SPINNER NEW -->> SAT.TECHNOLOGY "MIRAKURU DESIGN GREEN POWER" version G-A-B-LV1.0
  • host name = ATEMIO-6200HD ( nome LAN - samba )
  • Exteplayer + GSTplayer + GSTREAMER GST 1.13 assima fluidità !!!
  • EGAMI 8 INTEGRA IL VOD-PLAYER IN CHANNEL LIST **tasti attivi ( migliorato OSD in VODplay ) !!
  • EMC 4.0 movie center installato , attivabile tramite tasto file list/media ( skin mod ver by Nemoxyz )
  • RED KEY = EPGimporter setup , settato per il download giornaliero EPG ( new sources ott 2017 )
  • EGAMI BACKUP-TOOL INTEGRATO MOD by Nemoxyz per MBminiplus
  • ManuTEK settings 29-03-2018 (NemoxyzSATtv SAT+DTT nazionale)
https://i.imgur.com/yGGDyT9h.jpg
https://i.imgur.com/z6PIcE1h.jpg
https://i.imgur.com/KBQkn5jh.jpg
https://i.imgur.com/QFRNzrfh.jpg
https://i.imgur.com/6e48FI9h.jpg
https://i.imgur.com/kMKdfa5h.jpg
https://i.imgur.com/Obxsip2h.jpg
https://i.imgur.com/99wPJ5Jh.jpg
https://i.imgur.com/VnZMO8rh.jpg
https://i.imgur.com/b7vzLuvh.jpg
https://i.imgur.com/ktBeGsHh.jpg
https://i.imgur.com/EIo7uPHh.jpg
https://i.imgur.com/EZtTcHZh.jpg
https://i.imgur.com/0jnr0NLh.jpg
https://i.imgur.com/LtrZ3CSh.jpg
https://i.imgur.com/qNFw48oh.png
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "atemio"
  • INSERITE LA CARTELLA "atemio" IN UNA PENNA USB FORMATTATA FAT32
  • ATTENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' ED A MONITOR TV NON VI DIRA' DI SPEGNERE DECODER, RIMUOVERE LA PENNA USB E RIACCENDERE.
  • A QUESTO PUNTO IL DECODER ESEGUIRA' IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( ATTENZIONE: RIMUOVETE LA PENNA USB SOLO DOPO AVER SPENTO IL DECODER!! )
Guida MOUNT USB DEVICE & XpiconS ( hotbird 13 + DTT completi originali by Nemoxyz ) Guida INSTALLAZIONE METEO e selezione località tramite plugin dedicato myMETRIX-MOD Weather TOOL ( mod by Nemoxyz )
  • DA MENU - PLUGIN ( o tasto verde ) - myMETRIX-MOD Weather
    https://i.imgur.com/H0rGHTbh.jpg
  • SEGUITE LE ISTRUZIONI A VIDEO ALL'INTERNO DEL PANNELLO DI SETUP DEL PLUGIN!! SALVATE E RIAVVIATE ED AVRETE LA VOSTRA LOCALITà METEO!!
    https://i.imgur.com/8FiVimoh.jpg
Versione: APR2018-Ver1-SATtekMod
UNA NOTA IMPORTANTE CHE PRECISIAMO FORTEMENTE:<br>E’ VIETATO QUALUNQUE USO DEI FILE DA NOI PRODOTTI A SCOPI NON REGOLAMENTARI! E' SEMPLICEMENTE UN BACKUP SOFTWARE E/O LISTA CANALI E QUESTA RIMANE TALE! CI ASTENIAMO DA OGNI RESPONSABILITA’ QUALUNQUE RIPRODUZIONE DELLA DESCRIZIONE CREATA DA SAT.TECHNOLOGY E’ ASSOLUTAMENTE VIETATA SE NON TRAMITE PREVIA RICHIESTA ED AUTORIZZAZIONE DA PARTE NOSTRA!
Vedi Download: [BCKP] ATEMIO 6200 HD Nemoxyz EGAMI 8.1 exteP3 + GSTp Green ARROW BlackLeather
Modificato 3 volte da Nemoxyz 8 anni. Motivazione: Le informazioni sono state aggiornate
@Nemoxyz ottimo lavoro, bellissima grafica però....troppo verde. Nella lista canali , info canale non si può cambiare con un altro colore, perchè secondo me la Egami è migliore come immagine rispetto a OpenATV. Comunque non è una critica ma di gusti, siccome a me il pesto mi piace ma troppo disgusta :-D :-D :-D , una fritturina di pesce c'è vuole....Ahahhaaha. @Nemoxyz quando vedi @ManuTEK salutamelo..... AhhhAhhhAhhha
Ahaha sono sicuro che ci osserva !!! @ManuTEK e secondo me presto farà un sua puntatina...
Guarda passando alla disquisizione estetica tu intendi questo :
Intendi le scritte verdi dopo il nome canale in bianco ??
In realtà se noti e se vai con il cursore sopra il canale c'è una striscia verde che evidenzia e tutto diventa bianco!! evidenziato e ben visibile
Il fatto della colorazione è una tematica della skin che ho creato di sana pianta, la GREEN-Arrow per cui modificare quel colore comporterebbe modifiche sostanziali da altra parte, per cui nn so quanto sia fattibile...
Però dal punto di vista gastronomico...embè il pesto fatto in casa con i crismi non ci sono paragoni...di questi "tigulli" vari che ormai lasciano il tempo che trovano...però la fritturina mista ci sta tutta!! E si sa...è l'ago della bilancia per saggiare a che livello è la cucina del "ristoratore" ahahahahha :-D 8-)
rony
