Backup OpenATV-4.0-dm800seV2 SSL dailybuild-gjstroom by korn nf
OpenATV-4.0-beta-dm800seV2 dailybuild
This image is a 100% build from OpenATV source code.
You can safely use the online update function, I tricked the driver date 100 years in the future so the present (and working) drivers are not overwritten during update.
I added the secret-feed (softcams) and changed the default language to US. It's a 100% clean image !
Please note: The image is still under development, so don't expect everything to work.
source: dailybuild
drivers: 20131001 (patched)
bootloader: ssl88a
skin: MetrixHD
=Red]Image flashing:
Internet Explorer (recommended)
SUNRAY-FlashUP
Powercycle after flashing
Note1:[/B] You can get a MetrixWeather ID for your location here: http://open-store.net/index.php?page=metrixweather
Just edit the line 'config.plugins.MetrixWeather.woeid=640161' and remove all other config.plugins.MetrixWeather.x lines in your /etc/enigma2/settings file.
Before you start editing give a init 4 (enigma2 stops), edit above file and give a init 3 (enigma2 starts).
Note2:OpenATV uses a different remote keymap, you can change the mappings using: Menu - Setup - System - Button setup
Note3: Softcams are installable via 'blue button' - so***m - download softcams
Note4:The default location for ***a*.cfg is in /usr/keys/***a*.cfg !
CST motor settings 42E - 30W 28-04-2014
***a* 2.11 - Mgcamd 1.35a
New menu - Greekstreamtv - Greek net radio [/COLOR]
[center]Immagine[/center]
foreca weather forecast grmod
https://dl.dropboxusercontent.com/s/mf3 ... -20-05.nfi
Costruisci il tuo PC
