ESCLUSIVA openESI - 9 VERSIONE BACKUP "BrownLeather BASE skin Darkness " by Nemoxyz
BASE IMAGE:( OpenESI 9 new GST1.17 )
Versione-BACKUP= Ver2 ( minor fix ) = 18 OTTOBRE 2019 ( SERVICEAPP + STupdate )
DESCRIZIONE:
Software openESI 9 ottimizzato per le massime prestazioni del vostro dispositivo by Nemoxyz
DISPOSITIVO & MODELLO :
Adatto ad un dispositivo Enigma2 zgemma H3series ( H.2H - H3.2TC - H.2S plus ) DRIVERS COMBO SAT+DTT TUNER (sat)
GSTREAMER PLAYER & KERNEL:
GST 1.17 + ServiceApp
SKIN BACKUP:
o p e n E S I 9 ---- BASE skin Darkness
NOME FILE in download:
Nemoxyz-OpenESI9-baseSkin-GST1.17-(isetE2-344+EPG+ST-update+EMC4)-ZGEMMA-H3series
[ backup by Nemoxyz - 18 OTTOBRE 2019 ]
BACKUP FEATURES :
  • New --->> Bootlogo Leather stamp --> BASE skin openESI mod SATtechnology Edition ( Nemoxyz design )
  • SPINNER -->> new Technology POWER NEW special VERSION White "mini turbo technology"
  • DUAL Tuner COMBO SAT+DTT AUTOMATICAMENTE SETTATO
  • host name = ZGEMMA-H3series ( nome LAN - samba )
  • PARENTAL CONTROL CODE : 1357
  • SERVICEAPP INSTALLATO per velocizzare dispositivo ( da impostare da menu-sistema-serviceapp l' Exteplayer3 )
  • La image ha il VODplay integrato per approfondimenti
    katrame @ Software Image OpenESI 9.0 - EOL ( end of line ) - Extraddons e Feeds migrati
  • ST-List-update plugin per ricarica la Lista manualmente da telecomando
  • Premere tasto verde sotto openESI extra per avere il secret-feed
  • EPG IMPORT PLUGIN SETTATO PER LO SCARICO EPG GIORNALIERO ( rytec sources SATtek mod )
  • isettingE2 3.4.4 ( NUOVISSIMA VERSIONE DEL FAMOSO plugin!! configurazione auto su ManuTEK thanks to Diamondear !! PROVINCE DTT SELEZIONABILI !! )
  • DUAL Hotbird 13°+ Astra 19.2° DTT NAZIONALE ITALIA
  • ManuTEK settings 07 OTTOBRE 2019 (NemoxyzSATtv SAT+DTT nazionale)
  • CHANGELOG settings: blog/setting-e2-manutek/
SCREENSHOTS DI PRESENTAZIONE:
  • SCOMPATTATE IL FILE RAR TROVERETE UN CARTELLA DENTRO DAL NOME: "zgemma"
  • INSERITE LA CARTELLA "zgemma" IN UNA PENNA USB FORMATTATA FAT32
  • A DECODER SPENTO INSERITE LA PENNA USB NELL'APPOSITA PORTA ( porta usb posteriore!!) ED ACCENDETE IL DECODER DAL BOTTONCINO POSTERIORE, SI AVVIERA' IL FLASH
  • ATTENDENDETE IL CARICAMENTO FINO A CHE LA PENNA USB NON LAMPEGGERA' ED IL DECODER SI AUTORIAVVIERA AUTOMATICAMENTE
  • A QUESTO PUNTO IL DECODER ESEGUIRA' IL BOOT CON LA VOSTRA NUOVA IMMAGINE CARICATA!!( ATTENZIONE: RIUMOVETE LA PENNA USB SOLO DOPO AVER SPENTO IL DECODER!! )
3) Vi chiederà eventualmente di confermare , scegliete "SI" , scarica i settings ed ecco che il dispositivo sarà completamente ottimizzato e potrete utilizzarlo andando in lista canali!
Guida MOUNT USB DEVICE & XpiconS ( completi originali by Nemoxyz ) Versione: OTT2019-Ver2
Vedi Download: [BCKP] ZGEMMA H3series ( H.2H ) Nemoxyz OpenESI 9 BrownLeather Darkness-base-skin GST1.17 exteP3
Modificato 9 volte da Nemoxyz 8 anni. Motivazione: Le informazioni sono state aggiornate
@agostinolaporta
!!!AVVISO IMPORTANTE!!! "Errori Fake su File compressi"
Al fine di garantire un utilizzo corretto, evitando errori di "FILE DANNEGGIATO" dei nostri file compressi in WinRAR presenti in donwloads ( problema non reale causato invece dai vostri sistemi PC datati!! ), risulta assolutamente necessario effettuare aggiornamento a versione WinRAR non inferiore a v5.50. La versione corretta ed aggiornata la potete trovare al seguente link : [url=https://www.keeplinks.org/p15/655bb93dba934]WINrar-download-versione-aggiornata[/url]
Se avete riscontrato questo errore è colpa del vostro "decompressore" datato per cui è necessario aggiornare il vostro WinRAR in uso oppure utilizzare 7zip come decompressore universale
SALVE, SAPETE SE E' POSSIBILE TOGLIERE LA FUNZIONE DI CAMBIO CANALE CON I TASTI FRECCIA DX E SX DEL TELECOMANDO? STO SPULCIANO NEI VARI MENU' MA SEMBRA CHE IN QUESTA IMMAGINE TALE FUNZIONE NON CI SIA...GRAZIE!
@fragovic devi avere la cortesia di non usare il maiuscolo !! please !!! Significa gridare come da "netiquette" internet!!
Qui ci teniamo molto all'eleganza e non siamo sordiii :D:D ci sentiamo non gridare !!! ahahaha
Sono funzioni che puoi dare e rimuovere tramite "hotkey" da menu apposito interfaccia utente GUI si dovrebbe trovare..ora a memoria non ricordo.
Ma la domanda è come mai vuoi cambiare ??? sono utili !!
Chiedo venia per l'uso improprio del maiuscolo......Il problema è che non è possibile togliere la funzione cambio canale sulle 2 frecce.....Vorrei assegnare un'altro hotkey ai suddetti tasti...
@fragovic è possibile andando appositamente da menu "hotkey" te l'ho già scritto !!! Quale funzione gli vuoi assegnare fammi capire...che facciamo prima !!!
Nemoxyz ha scritto:@fragovic è possibile andando appositamente da menu "hotkey" te l'ho già scritto !!! Quale funzione gli vuoi assegnare fammi capire...che facciamo prima !!!
Scusami forse non mi sono spiegato bene: su hotkey non è associata nessuna funzione di cambio canali per i tasti freccia, c'è di default...Chiedevo appunto se era possibile toglierla in qualche modo ma ripeto, ho gia visto in tutto il menu' dell'immagine...
@fragovic forse tu ti ostini a non voler leggere quello che scrivo. :-D :-)
Se tu giri il menu ed in particolare sotto interfaccia utente trovi l'estensione Hotkey ( come su tutti gli enigma2 ) ora se tu entrei dentro e selezioni il tasto che vuoi cambiare te lo fa cambiare.
Gli devi assegnare altra funzione ovviamente!! Essendo un tasto importante è messo di base, non puoi solo escluderlo gli devi dare altra funzione.
Nemoxyz ha scritto:@fragovic forse tu ti ostini a non voler leggere quello che scrivo. :-D :-)
Infatti è proprio quello che ho fatto, ho assegnato al tasto freccia dx e sx la funzione di mostrare la lista canali ma, oltre a mostrarmi appunto la lista, mi cambia contestualmente anche canale, cosa che io non voglio, voglio solo che mi mostri la lista canali e basta!
ah ok ora ho perfettamente capito!!!! Si vede che è la image che impone questo. si tratta di dover modificare internamente la mappatura comandi. E' un po complicatello.
Non sempre si ha qst risultato che a seguito di cambio hotkey permane la funzione precedente. per qst motivo rispondevo in quel modo.
Ad ogni modo non capisco perchè di questa scelta ??? su/giù fanno quello che tu richiedi, destra/sinistra invece cambiano canale è normale !!!
Mi spieghi meglio così cerco di capire ?
Nemoxyz ha scritto:ah ok ora ho perfettamente capito!!!! Si vede che è la image che impone questo. si tratta di dover modificare internamente la mappatura comandi. E' un po complicatello.
Diciamo che è una mia fissa, nelle altre immagini potevo tranquillamente associare qualsiasi singola funzione ai tasti freccia , ora ho la certezza che in questa non si puo' fare ...Grazie mille !!!
Ps: quando sara' disponibile la 7.0?
@RyoSaeba2 si è un problema noto prova a mettere GSTplayer da serviceapp e vedi se ti vanno, oppure disinstalla e reinstalla serviceapp e vedi se ti migliora , purtroppo di base la image ha avuto un problema sui feeds al momento della installazione ed alcune librerie non si sono correttamente installate.
