OFFICIAL-IMAGE-SATtechnology: Ver1 - 05-07-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 MEELO+ TURBO ( CPU MIPS )
SATtekEleganceBLUE-7.0-meeloplusturbo-20220705_usb
IMAGE FEATURES:
- SPINNER Technology POWER
LINK DONWLOAD ED INFO:
INSTALLAZIONE
Eseguire il seguente comando:
wget -O - -q http://updates.mynonpublic.com/oea/feed | bashGuida MOUNT USB DEVICE & XpiconS ( SAT + DTT completi originali by Nemoxyz )
[HiRes]X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024)
[LowRes]ASTRA 19.2°E:
[HiRes]X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026)
[LowRes]EUTELSAT 5°W + 9°E:
[HiRes]X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026)
[LowRes]Versione: SATtekBUILD-Ver1 [05-07-2022]
UNA NOTA IMPORTANTE CHE PRECISIAMO FORTEMENTE:<br>E’ VIETATO QUALUNQUE USO DEI FILE DA NOI PRODOTTI A SCOPI NON REGOLAMENTARI! E' SEMPLICEMENTE UN BACKUP SOFTWARE E/O LISTA CANALI E QUESTA RIMANE TALE! CI ASTENIAMO DA OGNI RESPONSABILITA’ QUALUNQUE RIPRODUZIONE DELLA DESCRIZIONE CREATA DA SAT.TECHNOLOGY E’ ASSOLUTAMENTE VIETATA SE NON TRAMITE PREVIA RICHIESTA ED AUTORIZZAZIONE DA PARTE NOSTRA!
Vedi Download: [IMAGE] MEELO+ Turbo Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
PRODOTTI Hi-Tek MECOOL
GamsGo Accounts DAZN
Marketplace
SPORTsEvents EPGTracker
il CINEtip
