Nome: [IMAGE] ZGEMMA H9 COMBO (UHD-4K) Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 31-OTTOBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 ZGEMMA H9 COMBO ( CPU ARM )
https://i.imgur.com/jpP7S79.jpg
FEATURES:
iSettingE2 OE2.x - NEW VER - v3.6.3r1 - ( 09 MAGGIO 2025 )
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [31-10-2025]
File: SATtekCBGInterstellarATV-7.6.0-zgemmah9combo-20251031.rar
Dimensione: 150.78 MB
Vedi Download: [IMAGE] ZGEMMA H9 COMBO (UHD-4K) Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 28 volte da Nemoxyz 7 anni. Motivazione: Download Aggiornato
Ciao Nemoxyz, la release è fantastica. C'è un solo problema, presente anche nella versione di OpenATV su cui questa immagine è basata. In pratica il refresh dello schermo durante la navigazione nei vari menu è molto lento, cosa che non accade nelle ultime release di OpenATV. Per caso riesci a risolvere? Grazie ;-)
@marcktorius in riferimento a questa discussione :
Problema VOD h9t con tutti i fw!
il software utilizzato è di marzo 2018 perchè l'utente @shanghai68 lo menzionava come il migliore per via della riproduzione perfetta contenuti multimediali. Per cui la release è così !! Non è recente ilsoftware base per le problematiche di cui sopra, ora tu mi muovi questa altro "neo" non so mettetevi d'accordo !! ahaha :-) volendo se a te nn interessa il fatto vod e mkv e vuoi la fluidità dei menu allora prendi il software nuovo di base recente luglio 2018 dal sito openATV 6.1 e poi ci monti lo stesso pacchetto tanto il package settings l'ho creato e costruito con un algoritmo universale. Saluti.
@marcktorius no perchè è un problema eventualmente"genetico" della image per cui per risolverlo ne devi compilare una nuova. ( quindi siccome openATV lo fa usare la più recente come ti ho già segnalato ). L'unica cosa che ti posso dire è di assicurarti che serviceapp sia impostato correttamente su "exteplayer3" dovrebbe aiutare in fluidità menu. Saluti.
salve.....vi aggiorno come da comuicazione ricevuta ..da AIRDIGITAL.........
our zgemma h9t is OPENATV and OPENPLI official supported.
you can update the newest image which download from site, because we've released new driver....
e stanno lavorando per risolvere il problema.....sicuramente con openpli appena risolvono sara piu fluido e veloce...questo non togliere di creare con openpli con drive funzionanti....si potrebbeee!!!!!!!
ragazzi mi spiegate come instllarla? io scarico c'è la cartella h9 e i due file metto la cartella e i due file nella root della penna usb formattata in fat 32 a decoder spento poi accendo ma non parte il flash come mai?
trovato da solo a chi serve e ha zgemma h9t premere il tasto reset e tenere premuto prima di accendere il bottone bianco poi rilasciare reset dopo qualche secondo ;-) inizierà a lampeggiare rossa e bianca l'icona sul display anteriore a fine flash (è questione di poco) comparirà in automatico la schermata sulla tv
Scusate, voglio chiarirmi un dubbio: va bene anche per H9 combo?
E soprattutto: risolve i problemi con i VOD?
Grazie e scusate la pedanteria....
jackour ha scritto: 7 anni trovato da solo a chi serve e ha zgemma h9t premere il tasto reset e tenere premuto prima di accendere il bottone bianco poi rilasciare reset dopo qualche secondo ;-) inizierà a lampeggiare rossa e bianca l'icona sul display anteriore a fine flash (è questione di poco) comparirà in automatico la schermata sulla tv
ottimo lo metto in evidenza!! :-)
Ha scritto dopo 25 secondi:
strillozzo ha scritto: 7 anni Scusate, voglio chiarirmi un dubbio: va bene anche per H9 combo?
si e si , nessuna pedanteria !! vai tranquillo !! saluti.
Sto provando da 2 ore, tengo premuto reset, accendo, conto fino a 3 e lascio reset ma non parte mai il flash.
Ho messo nella root della chiavetta formattata fat32 la cartella "h9" e gli altri file che erano nel file zip. dove sbaglio?
Inoltre, ho letto che la cpu è ARM, che pacchetti devo installare? ho provato alcuni ipk arm ma non me le installa.
Buongiorno, ho risolto, io sbagliavo porta usb, usavo la 2.0, poi ho inserito la chiavetta nella usb 3.0 (blu) e ha subito funzionato.
Grazie mille!!!
  • 1
  • 2
  • 3
  • 4
  • 5
  • 24
Bene! Intendi fare leggere la carta Tivusat nello[…]
Sì non credo valga la pena,ti ringrazio ;-)
Grazie mille, buona serata.
