OFFICIAL-IMAGE-SATtechnology: Ver2 - 17-11-2022 ( aggiornamenti branch )
DISPOSITIVO
Adatto ad un decoder Enigma2 MUTANT HD51 4K ( CPU ARM )
SATtekEleganceBLUE-7.0-mutant51-20221117_usb.zip
SATtekEleganceBLUE-7.0-mutant51-20221117_recovery_emmc.zip
IMAGE FEATURES:
- SPINNER Technology POWER
LINK DONWLOAD ED INFO:
INSTALLAZIONE
Eseguire il seguente comando:
wget -O - -q http://updates.mynonpublic.com/oea/feed | bashGuida MOUNT USB DEVICE & XpiconS ( SAT + DTT completi originali by Nemoxyz )
[HiRes]X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024)
[LowRes]ASTRA 19.2°E:
[HiRes]X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026)
[LowRes]EUTELSAT 5°W + 9°E:
[HiRes]X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026)
[LowRes]Versione: SATtekBUILD-Ver2 [17-11-2022]
Vedi Download: [IMAGE] MUT@NT HD51 4K Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
PRODOTTI Hi-Tek MECOOL
GamsGo Accounts DAZN
Marketplace
SPORTsEvents EPGTracker
il CINEtip
