Sezione dedicata ai decoder OCTAGON SF-8008 Combo DVBS2X DVBT2 4K UHD 2160p
Nome: [IMAGE] OCTAGON SF8008 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 05-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 OCTAGON SF8008 ( CPU ARM )
https://i.imgur.com/6hJ7b3j.png
FEATURES:
iSettingE2 OE2.x - NEW VER - v3.6.3r1 - ( 09 MAGGIO 2025 )
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [05-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-sf8008-20251105.rar
Dimensione: 383.96 MB
Vedi Download: [IMAGE] OCTAGON SF8008 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 11 volte da Nemoxyz 7 anni. Motivazione: Download Aggiornato
Khayr ha scritto: 7 anni Buongiorno Nemoxyz, una volta scompattato il file image (ho preso l'ultimo da qui http://images.mynonpublic.com/openatv/c ... pen=sf8008) non vedo la cartella dal nome "vipercombo". Grazie per l'aiuto :)
Khayr
@Khayr leggo solo ora mi era sfuggito!!! ma dico cosa ci entro vipercombo con questo pacakge settings che si riferisce a octagon sf8008 ??
@adrianixoli il meteo attualmente è off !!! a causa di non so quale problema di metrix openstore !!! ne abbiamo parlato qui con altri utenti che usano in altri backup per altri modelli lo stesso sistema meteo o similare ( che si appoggia allo stesso server !! ) leggi tu stesso
Nemoxyz @ [IMAGE] ZGEMMA H5 Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
Nemoxyz @ [IMAGE] ZGEMMA H5 Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Ci vuole pazienza!! vedrò se riesco ad informarmi meglio sul perchè si protrae da giorni questo problema.
saluti.
@Nemoxyz penso che @Khayr si riferisca alla guida che c’e Sopra alle righe dove dice:
SCOMPATTATE IL FILE SCARICATO DELLA IMAGE E TROVERETE UN CARTELLA DENTRO DAL NOME "vipercombo"
@darius3 naturalmente neanche a doverlo precisare !!! si tratta di un errore di battitura di riporto da scrittura descrizione simile, di un logica disarmante!!
ovvio che la cartella sarà con il nome "sf8008" si tratta di octagon sf8008 di conseguenza quella troverai!! E' rimasta solo la dicitura vipercombo...
cmq sistemato !!! ora tutto ok grazie per la segnalazione. Saluti.
@Nemoxyz era ovvio però sai com'è sempre meglio precisare visto che lui è andato in difficoltà ed ha chiesto gli abbiamo tolto il dubbio.
finalmente oggi mi è arrivato il decoder, volevo chiedere questo pacchetto mi conviene applicarlo prima o dopo aver caricato la lista iptv?
Ha scritto dopo 3 minuti 31 secondi:
ultima info.... il link per l'image base pare non andare.... oppure è un problema mio ?
Ha scritto dopo 33 secondi:
https://amzn.tohttp//bit.ly/openATV62-O ... e-download
@darius3 ti devo dare merito e ragione!! meglio precisare e dirlo una volta in più e non lasciare il dubbio!! bravo!! Prima lo devi applicare per avere le impostazioni volute come da descrizione!! la iptv la metti alla fine di tutto. Sistemato link !! ora dovrebbe funzionare !!
https://bit.ly/openATV62-OctagonSF8008- ... e-download
se comapare qst suffisso >> amzn.tohttps// levalo e va di sicuro il link, ci deve essere un problema sui reindirizzamenti sul sito cerchiamo di controllare e vediamo.
@Nemoxyz il link va correttamente grazie....
allora sto provando a mettere l'image base ma forse credo ci sia qualche cosa che mi manca.... ho scaricato l'ultima versione presente sul sito indicato openatv-6.2-sf8008-20190117_mmc -> scompatto dentro ho una cartella octagon più un file .bin, dentro la cartella octagon c'è la famosa cartella sf8008, la copio in una pendrive formattata fat32->inserisco la pendrive nella usb a lato destro del decoder-> premo il pulsante centrale e poi accendo il tasto dietro-> sul display viene visualizzato upt ma dopo qualche secondo appare una schermata nera con le seguenti opzioni:
Startup_1
Startup_2
Startup_3
Recovery from USB
Recovery from Network
A questo punto credevo di dover selezionare recovery from usb ma se do ok mi da error while downloding....
cosa sbaglio?
Ha scritto dopo 14 minuti 41 secondi:
mi rispondo da solo.... invece di inserire soltanto la cartella sf8008 ho inserito la cartella octagon con il file .bin e selezionato recovery from usb... update complete!
@Nemoxyz si l'esperienza personale aiuta molto... devo chiedere una mano però perchè vorrei sostituire ST-VODplayer v1.0 per xc di lullula ma dalla rimozione plugin su octagon si aprono una serie di menu a tendina:
drivers
extensions
languages
settings
skins
systemplugins
in nessuno di questi riesco a trovare ST-VODplayer v1.0 o qualcosa di simile.... probabilmente ci sarà qualche abbreviazione, sai a quale corrisponde? ne ho cancellata una vxp... mi pare ma niente da fare è ancora caricato il plugin.
Inoltre per quanto riguarda l'ultima parte della guida quella che riguarda mount & xpicons quando inserisco la penna usb formattata in fat32 vuota all'interno, in quale schermata e quale plugin devo tenere aperto? ho provato ad inserire tramite ftp la cartella indicata ma mi da un messaggio che esistono già i file che voglio inserire e non me li sovrascrive... sbaglio qualcosa?
@darius3 nel caso del pacakge settings tale plugin STvod player da me installato manualmente via package in installazione lo devi rimuovere manualmente !! vai in FTP in usr/lib/enigma2/python/extensions/plugins e trovi cartella e la cancelli.
Vai in etc/enigma2/ trovi cartella e la rimuovi !! poi procedi al riavvio GUI del decoder !!
oppure puoi mandare tramite telnet qst comandi :
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/SATtek-VODPlayer
rm -rf /etc/enigma2/stvodplayer
Ora potrai installare XCplugin !!!
Tu dentro la pennetta usb FAT32 ( rinominata HDD possibilmente ) ci copi da pc dento la root la cartella "picon" e stop !! la colleghi al decoder e basta.
Non devi tenere aperto nulla!!
Nemoxyz ha scritto: 7 anni @darius3 nel caso del pacakge settings tale plugin STvod player da me installato manualmente via package in installazione lo devi rimuovere manualmente !! vai in FTP in usr/lib/enigma2/python/extensions/plugins e trovi cartella e la cancelli.
indicazioni precise con le quali sono riuscito a fare tutto.... mi rimane solo da capire il xcplugin perchè non ho le stesse diciture come dalle foto.... mi sposto nel topic apposito grazie mille super gentili!
Il decoder cmq è una meraviglia (per quel che ne capisco ed il mio utilizzo :grin: )
Salve a tutti vorrei porre una piccola questione sperando che qualcuno mi possa rispondere ; volevo sapere una volta impostato i parametri video, se io dovessi guardare un canale in 4k esempio Rai 4k ( quando accendono il trasponder ovvio) il decoder fa l'upscaling in automatico oppure abbiamo il video che diventa di tutti i colori a mo' di arcobaleno o messaggi tipo " no video " o cose simili???
Capisco in anticipo che per vedere il canale 4k della Rai dobbiamo essere dotati di decoder certificati EC..EC...e che senza la cosiddetta 232 non si vede nulla..ma la mia domanda resta!!!! Saluti
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
Leggendo qualche post sopra ci sta la soluzione. O[…]
Zgemma h17 bloccato in boot
!!!AVVISO IMPORTANTE!!! "Errori Fake su Fil[…]
@manta buonasera, secondo me il connettore spli[…]
