Nome: [PKCGsettings+BASEimg] OCTAGON SF8008 4k UHD Nemoxyz SATtek Elegance BLUE v2.0 GST1.15.2 ExteP3
Autore: Nemoxyz
Descrizione:
NUOVISSIMA RELEASE VERSIONE Package settings + BASEimage "SATtek Elegance BLUE v2.0"
VERSIONE SOFTWARE & SORGENTE (MOD & BASE-IMAGE)BASE IMAGE:( SATtekHomeBUILD v2.0 - dedicated sat.technology feeds )
Versione-BACKUP= Ver2 ( small fix ) = 16 APRILE 2019 ( GST1.15.2 + New Weather plugin + STvodPlayer v1.0 )
DESCRIZIONE
OTTIMIZZATA E SUPER STABILE VERSIONE BACKUP basata su image Elegance BLUE SATtekHomeBUILD by Nemoxyz
Original software based on teamblue-6.3 recipes patched by Nemoxyz - Many Many thanks to teamblue team
DISPOSITIVO & MODELLO
Adatto ad un dispositivo Enigma2 Octagon SF8008 UHD 4K combo DRIVERS correttamente installati
GSTREAMER PLAYER + versione package
GST 1.15.2 + extePlayer3 ( last version - serviceapp installato - GSTplayer selzionabile )
pacakge settings versione 2.0 IPK autoinstallante
SKIN BACKUP:
SATtek E l e g a n c e ---- BLUE v 2 . 0
"Difficult to reach..Elegance is not for Everyone..."
NOME FILE in download:Nemoxyz-SATtekEleganceBLUEv2.0-GST1.15.2+exteP3-(isetE2-344-EPG+Ytube+Weather+STvodPv1)-OctagonSF8008
[ package settings + base image by Nemoxyz - 16 APRILE 2019 ]
BACKUP FEATURES
- New --->> Bootlogo --> SATtek Elegance BLUE ( Nemoxyz design )
- SPINNER -->> new Technology POWER NEW special VERSION "mini turbo technology"
- Informazione Meteo località ( impostabile da plugin WEATHER SATtek Elegance BLUE - Nemoxy Mod )
- host name = OctagonSF8008 ( nome LAN - samba )
( eseguite impostazione tramite comando telnet-putty "passwd" e digitatela 2 volte (blind-mode= scrive ma nn si vede!) - PARENTAL CONTROL CODE : 1357
- NEW Weather Plugin integrato ( in sostituzione della versione precedente che oramai aveva i server meteo non operativi ) - TASTO GIALLO per il setup
- Youtube plugin per poter visionare i vostri filmati Youtube preferiti ( plugins browser tasto verde )
- SERVICEAPP INSTALLATO con default ExtePlayer3 per velocizzare dispositivo + GSTplayer selezionabile
- ST-VODplayer v1.0 ( basato su versione base XCplugin multi - skin design by Nemoxyz ) PER VISUALIZZAZIONE VOD & Live IPTV molto semplice e veloce da configurare classicamente il file xml in "etc/enigma2/stvodplayer" ( vedi shots sotto ). Trovere all'interno il file "stvodplayer_e2_01-Live-VOD-List.xml" in cui inserire DNS / porta / username / password
- Eventualmente se volete un VODplayer più specifico e completo con molte altre funzioni, disinstallate questo plugin ( tasto verde - tasto rosso rimuovi STvoPlayer v1.0 )
Vi consiglio questi plugins: ( versione Lite utile per decoder non molto potenti o Completa )
XCplugin LITE mod by Lululla - [OLDVER] XC-plugin LITE VODplayer - Multi - stand-alone IPK install ( mod by Lululla )
XCplugin mod by Lululla - [OLDver] XC-plugin VODplayer stand-alone IPK install ( XC mod by Lululla ) ver 6.7 non supportato!! - EPG IMPORT PLUGIN SETTATO PER LO SCARICO EPG GIORNALIERO ( rytec sources SATtek mod )
( viewtopic.php?f=89&t=32006 ) - isettingE2 3.4.4 ( NUOVISSIMA VERSIONE DEL FAMOSO plugin!! configurazione auto su ManuTEK thanks to Diamondear !! PROVINCE DTT SELEZIONABILI !! )
- ManuTEK settings 10 APRILE 2019 (NemoxyzSATtv SAT+DTT nazionale)
(DTT da scansionare con uLCN di isettingE2 per la vs zona DTT qualora non trovaste la provincia ) - CHANGELOG settings: blog/setting-e2-manutek/
SCREENSHOTS DI PRESENTAZIONE
Qui sotto in download potrete scaricare il file compresso in RAR al cui interno troverete la base-image + pacakge settings di configurazion in versione Flash by USB che potrete installare comodamente tramite il flashing via USB.
- SCOMPATTATE IL FILE SCARICATO DELLA IMAGE E TROVERETE UN CARTELLA DENTRO DAL NOME "octagon" + file "usb_update.bin"
QUALORA NON DOVESSE COMPLETARE IL BOOT IN ALCUNI CASI CAPITA CHE DIA SCHERMATA BLU DI ERRORE ( E' SOLO TEMPORANEO !! ) POTRETE DIRETTAMENTE PROSEGUIRE BLOCCANDO E CONGELANDO IL DECODER CON IL COMANDO "init 4" DA TELNET E PROSEGUITE CON LA PROCEDURA QUI DI SEGUITO!!
Codice: Seleziona tutto
IMPOSTAZIONE SATtek VOD player
Impostare il file che trovate nella cartella /etc/enigma2/stvodplayer/ "stvodplayer_e2_01-Live-VOD-List.xml" come da foto indicative
Modificato 2 volte da Nemoxyz 7 anni.
Motivazione: Download Aggiornato
- ✅ PROVA AMAZON PRIME iscrizione gratuita 30gg per tanti contenuti Video e spedizioni rapide 🌐
- ✅ GamsGo Accounts DAZN ⚽️🏀🏈⚾️🎾🏐 Marketplace 🌐
