Sezione dedicata ai decoder GigaBlue UHD TRIO 4K
Nome: [IMAGE] GigaBlue UHD TRIO 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 06-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 GIGABLUE TRIO 4K ( CPU ARM )
https://i.imgur.com/WwZ8vrB.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (19 MAGGIO 2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
Versione: SATtekBUILD-Ver1 [06-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-gbtrio4k-20251106.rar
Dimensione: 378.73 MB
Vedi Download: [IMAGE] GigaBlue UHD TRIO 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 9 volte da Nemoxyz 7 anni. Motivazione: Download Aggiornato
Password accesso FTP / OpenWebIF = " NON SETTATA "
( eseguite impostazione tramite comando telnet-putty "passwd" e digitatela 2 volte (blind-mode= scrive ma nn si vede!) scusate questa non l ho capito significa che la password accesso ftp non settata vuole dire che non c e oppure e scritta prorio " NON SETTATA " e quindi tramite puty digitare cosa 2 volte scusate l ignoranza grazie per eventuali risposte
@bancomat se dopo c'è scritto :
ovvio che la password "non è settata" nel vero senso della parola inteso che non esiste password !! la devi settare insomma !! segui la procedura da telnet dai quel comando e poi digiti la tua password personale 2 volte al buio, si setta e procedi. Saluti.
quindi se non metto nulla rimane libera senza password , posso anche non settarla giusto metto root e niente e entro in ftp ,
@bancomat premesso che impostare una password è questione di sicurezza con dispositivi che sono collegati in rete. Lo consiglio caldamente.Cmq si diciamo che in FTP e telnet entri solo con root e basta ma non entri in openwebif senza perchè è impostata che la richiede per cui essendo nulla fino a che non la setti non ti fa entrare, a meno che non togli impostazione dallo stesso omonimo plugin.
ora è tutto ok. Un problema che ho notato anche sulla openesi è un effetto rallenty al cambio canale non so se mi spiego, si può risolvere?
@bancomat il lag al cambio canale solitamente dipende dai drivers della casa madre e non dal sistema operativo. Se lo noti su tutte le release è per questo motivo !! E' avulso dal fatto che sia ATV o ESI o PLi o altra image purtroppo...
ciao grazie sempre molto esaudient senti come posso far si che sul diplay del decoder resti il numero del canale invece che l orario
@bancomat quelle impostazioni con orario sono messe per rubare risorse al decoder, la visualizzazione del numero canale rallenta.
Ad ogni modo se vai in menu impostazioni ci dovrebbe essere l'estensione VFDcontrol ( led display ) per poter modificare queste impostazioni.
saluti.
innanzitutto buonasera a tutti!
non riesco a fisualizzare le so***m quale app posso utilizzare?
grazie in anticipo
Cosimo
ok ho risolto... mi rimane il problema delle picons... le ho messe nella cartella /usr/share/enigma2 ma non le vede... bisogna settale la folder dove vengono messe?
Cosimo
@Merei noooo :clown: :clown: :clown: non le devi mettere lì !! ingombri la flash inutilmente !! ci sta una guida apposita sotto ogni download per i vostri decoder , perchè non la leggi !!! ???? vanno messe in media/hdd con pennetta o hdd installati !!
