Buonasera sto tentando ad installare alcuni plugin ma quello che mi preme di più isettinge2 che non riesco ad installare ne tramite la lista dei plugin, ne tramite telnet e nemmeno scaricando ipk e installandolo manualmente. Qualcuno sa aiutarmi il box è un zgemma h9t openatv 6.3.
Ecco il log
commands ...
command line: /usr/bin/opkg install --force-overwrite enigma2-plugin-extensions-isettinge2
next commands:
sync
outputs ...
Processo in esecuzione:
--- PreInst * IPK Scripting v2.0 - date 19.09.2018 ---
Remove old folders...
Installing enigma2-plugin-extensions-isettinge2 (3.4.4) on root.
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/po/fr/LC_MESSAGES/SettingMan.mo': Write failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/po/it/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/po/it/LC_MESSAGES/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/po/it/LC_MESSAGES/SettingMan.mo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/po/lv/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/po/lv/LC_MESSAGES/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/po/lv/LC_MESSAGES/SettingMan.mo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/IconPlugin.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Conf/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Conf/arm/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Conf/arm/LcnAr': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Conf/arm/unrar': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Conf/arm/scan_lcn_arm.so': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Conf/rules.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Selection.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_LkAgt.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Local.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_About.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_MesBox.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_InfoTuner.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Succefully.cfg': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Scan.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Conf.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Cl.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/keymap.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Librerie.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Dgtv.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Thread.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Fonts/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Fonts/Roboto-Regular.ttf': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_ScanSetup.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_DiskInfo.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/SD/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/FHD/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/FHD/ServiceScanMini.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/FHD/NotifyText.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/FHD/MessageAds.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/FHD/MiniBox.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/AuthCredent.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/ReadmeFile.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/ServiceScanMini.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Main.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/About.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/ico_sat.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/progress_bar_ber.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/mini_progress_red.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/progress_bar_scan.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/ico_telnet.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/progress_bar_snr.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/progress_small_orange.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/progress_bar_agc.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/progress_big_blue.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/smflogo.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Buttons/progress_big_red.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/NotifyText.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/NewLcnScanner.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/LcnScanner.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_info.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/dtt.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/PayPal.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/icon_blue.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_error.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_error_128px.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/network_error.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/clock_on.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/clock_off.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/sat_m.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/key_menu.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/icon_green.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_esc_yellow_128px.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_esc_red_128px.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/DownloadSetting.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/key_info.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/key_epg.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/dtt_m.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_info_128px.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_question_128px.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/cable.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/DownloadPlugin.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/sat.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_question.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/key_0.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/uplogo.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/icon_red.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/cable_m.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Icons/input_wait_128px.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/VirtualKeyBoard.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Console.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/MessageAds.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Selection.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/Backup.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/RegistrCredent.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/MiniBox.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/MessBox.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/ChangeLog.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/HDR/ServiceScan.xml': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Skins/UHD/': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_PgUpdate.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Iptv.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/__init__.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Ads.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Backup.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_ScanLcn.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/IconPluginError.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_ChNum.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Autotimer.pyo': Write to restore size failed
WarnCollected errors:
 * pkg_write_filelist: Failed to open ///var/lib/opkg/info/enigma2-plugin-extensions-isettinge2.list: No space left on device.
 * opkg_install_pkg: Failed to extract data files for enigma2-plugin-extensions-isettinge2. Package debris may remain!
 * opkg_solver_install: Cannot install package enigma2-plugin-extensions-isettinge2.
ing when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_StartMenu.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/plugin.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Lcn.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Start_Lcn.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/iSettingE2/Setting_Maintain.pyo': Write to restore size failed
To remove package debris, try `opkg remove enigma2-plugin-extensions-isettinge2`.
To re-attempt the install, try `opkg install enigma2-plugin-extensions-isettinge2`.
Esecuzione terminata!!
@jollyx90 isettingE2 va scaricato in versione ARM da qui >> www.isettinge2.com
Una volta scaricato a messo via FTP in cartella /tmp/ va installato con comando
opkg install /tmp/*.ipk
di seguito la guida per configurare il plugin
Se utilizzi un nostro backup che trovi in downloads trovi tutto già settato !!
LINKS donwload utili
- FTPclient winSCP download QUI ( invio files FTP )
Ok !!! ma sei sicuro di aver messo la versione ARM dentro la cartella temporanea ??? /tmp ?? perchè da log non sembra così...non vorrei sbagliare.
Riprova !! Riavvia il decoder e fai i passaggi come descritti.
Si ho rifatto tutto, controllo che siano arm ovviamente. Allora scaricando dalla repository ufficiale download plugin il primo me lo fa installare poi dopo non me fa inserire più. L'errore non è di isettinge2 ma di tutti. Ho riscaricato il firmware, cambiato pennetta, cambiando entrata ma l' errore è sempre questo
commands ...
command line: /usr/bin/opkg install --force-overwrite enigma2-plugin-extensions-netspeedtest
next commands:
sync
outputs ...
Collected errors:
 * pkg_write_filelist: Failed to open ///var/lib/opkg/info/enigma2-plugin-extensions-netspeedtest.list: No space left on device.
 * opkg_install_pkg: Failed to extract data files for enigma2-plugin-extensions-netspeedtest. Package debris may remain!
 * opkg_solver_install: Cannot install package enigma2-plugin-extensions-netspeedtest.
Installing enigma2-plugin-extensions-netspeedtest (1.0rc1) on root.
Downloading http://feeds2.mynonpublic.com/6.3/h9/3rdparty/enigma2-plugin-extensions-netspeedtest_1.0rc1_all.ipk.
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/logo.png': Write failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/speedtest.py': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/__init__.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/default.py': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/default.pyo': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/plugin.py': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/plugin.png': Write to restore size failed
Warning when extracting archive entry '/usr/lib/enigma2/python/Plugins/Extensions/NetSpeedTest/plugin.pyo': Write to restore size failed
To remove package debris, try `opkg remove enigma2-plugin-extensions-netspeedtest`.
To re-attempt the install, try `opkg install enigma2-plugin-extensions-netspeedtest`.
Ha scritto dopo 8 minuti 37 secondi:
Ma una cosa che davo per scontato mentre non è così, la memoria flash mi risulta 1MB come è possibile? Sto diventando matto
@jollyx90 devi riflashare il decoder e poi seguire istruzioni che ti ho dato. Cioè ipk all-arm da sito isettinge2 e lo metti in temp dai comando installazione oppure da tasto blu installi ipk da tool di instlazione. Non ti inventare altri modi perché non sono validi e rimani in questo modo.
Riflashato ma come se l' immagine openatv occupaase tutta la flash. Con openpli nessun problema
@jollyx90 openatv ultimamente ne combina una al minuto....ti consiglio per gli zgemma openESI 8.6 oppure come dicevi bene openpli !!! prova la openESI che va alla grande!!
