Sezione dedicata ai decoder AMIKO VIPER 4K51
Nome: [IMAGE] AMIKO VIPER 4K51 Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 04-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 AMIKO VIPER 4K51 ( CPU ARM )
https://i.imgur.com/sBEkfJp.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (19 MAGGIO 2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
Versione: SATtekBUILD-Ver1 [04-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-viper4k51-20251104_usb.zip
Dimensione: 142.69 MB
Vedi Download: [IMAGE] AMIKO VIPER 4K51 Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 5 volte da Nemoxyz 6 anni. Motivazione: Download Aggiornato
buongiorno Nemoxyz,
prima di tutto grazie per i setting, però mi è sorto un problemone, ho scaricato openatv 6.3 ,nella cartella c'è solo una cartella e1x000 che l'ho copiato nella chiavetta, ho pigiato il tasto dietro poi quello avanti , poi mi dice " root " non carica nulla e adesso se lo riaccendo togliendo la chiavetta mi dice " boot" e non fa niente, preticamente è morto tutto nero, potresti aiutarmi.
grazie in anticipo
arzius78 ha scritto: 6 anni buongiorno Nemoxyz,
grazie in anticipo
nemoxyz
ho provato anche a rinominare nella cartella e1x000 ( il file noforce con force) ma quando effettuo tutta la procedura tasto dietro poi tasto avanti si ferma su root e non va più avanti, hai una soluzione ? mi è arrivato venerdì ed ora è non mi carica più nemmeno la vecchia immagine.
Grazie spero tu possa aiutarmi.
Grazie mille
@arzius78 tu devi mettere la cartella dentro la penna usb con il file "force" hai fatto bene a rinominarlo , da spento accendi ed il decoder deve andare in modalità flash. Ora considera che questo decoder è nuovo non lo conosco onestamente mi affido all'esperienza...e quando c'è file noforce questa è la procedura.
saluti.
Quindi se seguo tutto alla lettera come ho fatto lasciando force dentro la cartella e rimane fermo su root ha qualcosa il decoder?
Ha scritto dopo 1 minuto 21 secondi:
Scusami secondo te gli zgemma sono meglio se si consigliami te, grazie
@arzius78 potrebbe avere problemi la pennetta oppure la image scaricata , scaricane un'altra di un'altro giorno. Zgemma H9 combo 4k è migliore perchè più supportato !! vai in sezione consigli acquisti ci sono molti suggerimenti in merito. saluti.
Buongiorno, provo a scrivere per trovare una soluzione che sto cercando da giorni senza successo. Posseggo un amiko viper combo su cui ho regolarmente installato una open ATV 6.4. tramite procedura indicata. ******Grazie a tutti
Bgiorno ad auguri. Argomento fuori regole!! Attenzione. Peraltro anche offtopic qui si parla del package settings oggetto del topic non della openatv generica... Posso dire solo che serve la 232 e chiuso argomento. Saluti.
