Sezione dedicata ai decoder GigaBlue ultra UE 4K
Nome: [IMAGE] GIGABLUE UHD UE 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 07-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 GIGABLUE ULTRA UE 4K ( CPU ARM )
https://i.imgur.com/yz12dqu.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (19 MAGGIO 2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
Versione: SATtekBUILD-Ver1 [07-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-gbue4k-20251107_usb.zip
Dimensione: 145.22 MB
Vedi Download: [IMAGE] GIGABLUE UHD UE 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 14 volte da Nemoxyz 6 anni. Motivazione: Download Aggiornato
scusate ragazi ma Gigablue UHD UE 4K e GigaBlue Ultra UE 4K montano la stessa immagine , cioe questo bacpkup va bene
quindi praticamente dovrei scaricare dal sito open atv 3 per il decoder e dopo caricarci il backup che funziona in entrambi i casi se il decoder arriva gia con opeant tv invece basta caricarci il backup se ho capito bene , perche per Gigablue UHD UE 4K non trovo nulla
alve ho il ricevitore gigablu ue k4 ho scaicato l 'immagine [PCKGsettings] GIGABLUE Ultra UE 4K Nemoxyz OpenATV 6.4 GST1.17 exteP3 CBCgold Interstellar pero lo messa nella penetta ho fatto la procedura per caricare l'immagine ma non me lo flescha il decoder perchè io non ho la prima immagine che avete messo sul sito ora siccome l'immagine e aggiornata non ci sono tuttui i file se e possibile avere l'immagine completa se no non me la istalla grazie
@arlok dovresti leggere meglio la prima pagina laddove scarichi...
Ovviamente inserendo nella pennetta un package settings non si flasherà un bel niente !! :laugh: Ti serve la image base ( nella descrizione scrivo dove poterla scaricare...ehhh se leggeste e dedicaste 5minuti alla descrizione...non sareste così in panne!! :) solo dopo aver installato la image base potrai installare il package settings che è un pacchetto IPK, ovviamente da che mondo e mondo un IPK non è un sistema operativo...ma solo un configuratore!! Come ovviamente descrivo...
Fammi sapere se e dove trovi problemi dopo aver letto attentamente le descrizioni che ti aiuto !! Saluti.
PS: spostato sotto il topic dedicato...perchè scrivere altrove ? Non capisco...
grazie per la risposta ma gia ho messo un altra immagine su bigablu ue k4 e funziona pero vorrei mettere questa immagine che avete vuoi sul sito solo che io non la ho tutta completa perche la prima volta che sul sito anno messo l'immagine completa io non lo scaricata ed quindi ora ho scaricato solo questa ma c'e solo l'aggiornamento ed mi mancano gli atri pacchetti della vostra immagine se lei me la puo girare completa io gli ne sarei grato grazie GIGABLUE Ultra UE 4K Nemoxyz OpenATV 6.4 GST1.17 exteP3 CBCgold Interstellar
@arlok non ci stiamo capendo... :clown:
Se tu dedichi 5 minuti a leggere laddove scarichi potrai capire che la image base la puoi scaricare dal sito della openATV ed il package settings è un pacchetto di configurazione che la rende come la vedi in foto, non c'è mai stata una versione completa !!! Per il semplice motivo che non avendo questo modello disponibile non ho mai avuto modo di fare il backup, indi per cui mi chiedi una cosa che non è mai esistita. In ogni caso ed ogni modo non è possibile mandare e/o "girare" nulla ( per nostre regole interno ) se non attraverso la nostra piattaforma di downloads.
Questa frase : " la prima volta che sul sito hanno messo l’immagine completa" non ha senso per 2 motivazioni :
1) quello che ti ho scritto prima
2) Sono esclusivamente io al 99% che creo ed inserisco e carico immagini, backups e/o packages settings per cui lo so per certo !!
Lo ripeto altra volta ancora: Fatti una lettura completa ed approfondita qui : [IMAGE] GIGABLUE UHD UE 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Poi se non comprendi qualcosa ne riparliamo, però fallo !! LEGGI !!! :laugh: Te l'ho già scritto nel precedente messaggio solo leggendo si capisce come operare con questo package settings.
@bancomat si la teamblue è la image ufficiale dei decoder Gigablue. Per quanto riguarda openpli i modelli 4K sono supportati per cui trovi anche quella. Se ti interessa un package settings allora in quel caso per openpli posso vedere di realizzarlo basta fare richiesta qui > request.php
Ciao
installato nuova pckg ma non funziona bene continui crash e poi escono quadrattini grigi quando fa aggiornamenti ? provato 2 volte
sempre uguale
@cmp salve buonsera , mi dai maggiori dettagli? passo dopo passo intendo quando e dove accade che vedi questi quadratini grigi ? E di quali aggiornamenti parli ? Il package ricontrollato ed è perfetto non si notano problemi , non differisce da altri , per cui mi viene da pensare che la image base potrebbe essere il problema , che versione hai installato ?
L'invio dei files immagini si può fare tramite servizio "IMGur"in questo modo
Spoiler
Dal quick reply
Oppure da Editor completo
