Sezione dedicata ai decoder Ferguson ARIVA combo ATV
Nome: [IMAGE] Ferguson ARIVA ATV Combo Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 07-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 FERGUSON ARIVA ATV COMBO 4K ( CPU ARM )
https://i.imgur.com/MOsbvPi.png
FEATURES:
iSettingE2 OE2.x - NEW VER - v3.6.3r1 - ( 09 MAGGIO 2025 )
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [07-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-arivacombo-20251107_mmc.zip
Dimensione: 141.61 MB
Vedi Download: [IMAGE] Ferguson ARIVA ATV Combo Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 9 volte da Nemoxyz 6 anni. Motivazione: Download Aggiornato
scusate se rompo un po su questo decoder , non esiste ancora una guida e setting ?? questa non va bene ?[PCKGSETTINGS] FERGUSON ARIVA ATV COMBO NEMOXYZ OPENATV 6.3 GST1.17 EXTEP3 CBCGOLD INTERSTELLAR, questo non ha il pulsantino di accenzione dietro. mi date una dritta per favore , altrimenti non faccio ordine !! aspetto il tempo che ci vuole per h10 zgemma, grazie
@pallonaccio lascia stare la descrizione è errata ( ora la sistemo !! ) con il pulsantino dietro è un errore, flasha il decoder come tutti i decoder usb-flash !! metti software nella penna usb e dai ok su decoder accendi e/o da telecomando !! Questo modello è enigma2 non va a liste !! ci sta dentro tutto il necessario nel package settings leggi bene le descrizioni !! PS & NB: ti ho spostato sotto il topic dedicato , perfavore rispettiamo le sezioni altrimenti diventa un guazzabuglio medioevale il sito !! Thanks !!
scusate se sono un po scocciante questa la devoinserire su immaggine originale????? [PCKGsettings] Ferguson ARIVA ATV Combo Nemoxyz OpenATV 6.3 GST1.17 exteP3 CBCgold Interstellar DIC2019-Ver1, scusate , ma non voglio fare casini, e' nuovo x me questo apparato !!
Nemoxyz ha scritto:@Grandesat certamente, con tutti i nostri backup funziona bene !! ;-)
Ciao ho provato questo backup ma non funziona bene il exteplayer3 con iptv in questo ricevitore.
Questo plugin con il octagon sf8008 funziona perfettamente.
volevo sapere se ce la possibilità di importare la lista canali da enigma2 a live tv di android?
@Grandesat è un problema hardware di questo modello. il backup non ci entra nulla con il software che viene creato da ATV per cui non incide con le sue feature le ottimizza solamente scegliendo le migliori. Importare la lista canali ?? Che intendi , spiega meglio...se intendi lo streaming dei canali sat e dtt sintonizzati dal decoder verso la app android si certamente devi installare la app ( tipo dreamDroid o dreamplayer ) e poi connetterti al decoder sul suo IP. Saluti.
Nemoxyz ha scritto:@Grandesat è un problema hardware di questo modello. il backup non ci entra nulla con il software che viene creato da ATV per cui non incide con le sue feature le ottimizza solamente scegliendo le migliori. Importare la lista canali ?? Che intendi , spiega meglio...se intendi lo streaming dei canali sat e dtt sintonizzati dal decoder verso la app android si certamente devi installare la app ( tipo dreamDroid o dreamplayer ) e poi connetterti al decoder sul suo IP. Saluti.
infatti non do la colpa al backup in precedenza ci avevo già provato in tutti modi senza risultato positivo, ho provato questo backup con la speranza di farlo funzionare.
in quanto riguarda alla lista canali ..la mia domanda è se ce qualche modo di importare la lista canali funzionante in Enigma2 verso android con la app Live tv nello stesso ordine che si trova in enigma2 visto che Live tv di android fa la ricerca canali ma li metti in completo disordine ... oppure esiste qualche editore canali per Android?
@Grandesat capisco , precisavo soltanto per chi leggerà in futuro per non confondere.
Ti ripeto la domanda, tu vuoi vedere i canali SAT e DTT del decoder sul tuo android creando uno streaming oppure vuoi impostare la tua IPTV sul tuo android sono 2 cose differenti. Se è la prima usando le app che ti menzionavo vedrai la lista canali così come la vedi nel decoder , precisamente in quell'ordine.
Se invece vuoi impostare la tua iptv su android devi usare il link m3u ( peraltro in questo caso siamo off-topic come argomento qui , va trattato in altra sezione )
Editor per canali android non credo ci sia, la app live tv non la conosco.
Ciao a tutti ho da poco questo decoder e ho difficoltà ad installare enigma2 i link ai file di questo thread non funzionano e in rete si trovano versioni contrastanti su come caricare le immagini..le stesse poco chiare istruzioni fornite con l'acquisto sono differenti da quelle postate qui...Qualcuno riesce a darmi istruzioni in merito? Esiste qualche guida non ufficiale?
Grazie.
Ciao innanzi tutto grazie per l arisposta...mi spiego meglio...la procedura indicata nel foglio allegato alle istruzioni ricevute insieme al decoder indica una procedura totalmente differente da quella descritta nei post precedenti e cioè:
- Scarica quello appropriato dal sito web sulla chiavetta USB:
- tre dati dall'archivio Devono essere sulla chiavetta USB nella cartella e2 / update
- nell'applicazione livetv dovresti attivare l'uso di enigma2
- Inserisci la pendrive in Ariva e quando Ariva si avvia, fai clic sul pulsante verde del telecomando
- Quando viene visualizzato il pannello di selezione del sistema, premere il pulsante blu sul telecomando
Questa è la traduzione dal tedesco delle istruzioni avute insieme al decoder...
In rete ho trovato una procedura molto simile a questa e più dettagliata nei vari passaggi che è questa:
La prima cosa che dobbiamo fare per installare la nostra immagine enigma2 è attivare il menu di selezione del sistema operativo.
Quando viene acceso per la prima volta, il nostro ricevitore carica il sistema della serie AndroidTV.
1- Dopo aver caricato AndroidTV andiamo all'applicazione Live TV e la selezioniamo.
2- Vai a Setup-Config e fai clic su OK
3- Ora nella configurazione andiamo su Misc, andiamo su Preference, Use E2 set Enable e chiediamo se vogliamo riavviare, diciamo SI.
INSTALLAZIONE DI ENIGMA2
1- Dopo aver scaricato l'immagine, la scompattiamo e inseriamo la cartella e2 nella directory principale della pendrive.
2- Quando il ricevitore è scollegato, inserire la chiavetta USB 2.0 sul retro del ricevitore.
3- Accendi il ricevitore e riceveremo la seguente schermata, che durante l'osservazione ci dà l'opportunità di eseguire Android o Enigma2.
4- Quando la parola MENU appare sul display del ricevitore, premere il pulsante verde sul telecomando e l'installazione dell'immagine avrà inizio.
5- Al termine dell'installazione, l'installazione del ricevitore verrà riavviata e potrai ora goderti l'immagine
Come vedi queste due procedure sono molto diverse da quella descritta nei post precedenti...
Dato che il link dell'immagine base è riferito ad un'immagine risalente a più di un anno fa, volevo installare un'immagine più recente come la openspa-7.4.013-arivacombo-20210213_mmc.zip
Ho quindi provato ad installare questa immagine seguendo sia la vostra guida che quella indicata dal produttore del decoder (uguale a quella trovata in rete) ma senza riuscire ad installare nessuna immagine...(provato anche con ultima openatv) ...
Seguendo la guida del produttore ad un certo punto il decoder si blocca mostrando una finestra con scritto Manual Update
Seguendo la guida postata qui il dec si riavvia nel sistema Android e non installa l'immagine...
Spero di essere stato più chiaro stavolta,effettivamente il mio post precedente era poco chiaro.
Grazie.
@vadinho
Spoiler
Dal quick reply
Oppure da Editor completo
non da "invio allegati" quello serve per file zip & rar esclusivamente. Grazie per la cortese attenzione.
@vadinho dal link che trovi "LINK IMAGE BASE : openATV6.3 IMAGES BASE DOWNLOAD ( selezionate categoria modello decoder ultima versione stabile ATV 6.3 ),e una volta scaricata, prova a seguire la guida indicata, poi facci sapere... :party:
