Sezione dedicata ai decoder 4K UCLAN Ustym cpu ARM Huawei
Nome: [IMAGE] UCLAN USTYM 4K PRO combo Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver2 (some little fixes) - 04-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 UCLAN Ustym 4K PRO Combo ( CPU ARM )
https://i.imgur.com/eoMRcoV.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (19 MAGGIO 2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
Versione: SATtekBUILD-Ver2 [04-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-ustym4kpro-20251104.rar
Dimensione: 368.77 MB
Vedi Download: [IMAGE] UCLAN USTYM 4K PRO combo Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 19 volte da Nemoxyz 5 anni. Motivazione: Download Aggiornato
Qualcuno mi dice come configurarlo, e se esiste un firmware con Netflx YouTube ecc.. e magari anche IPTV grazie sto diventando pazzo con i canali, poi quel numero a sinistra che fa confusione
io lo prenderei anche, devo fare un pagamento... ma se la USB non la legge? Siccome ho provato altri firmware messi su diverse Pen Drive USB sia sulla presa USB3 Blu che quella USB2 bianca dietro ma dice che non trova nessuna immagine. Non vorrei prendere questo firmware e poi non lo riesco a leggere lo stesso. Siccome il mio decoder è nuovo, e se ha un difetto lo dovrei mandare via al più presto, volevo sapere se è un difetto di questo decoder oppure qualcos'altro, Grazie
@sullivan2002 la prima cosa che devi fare è leggere attentamente le istruzioni , perchè mi pare di intuire che tu non abbia capito come funziona un package settings ( quello che ti ho indicato nello specifico ) , poi le domande eventualmente relative ad esso le farai lì nel topic dedicato, per dubbi o cose che non hai capito nelle istruzioni laddove ti ho indicato ( nel link ci sta scritto tutto come si usa un package ) e quale image installare e da dove prendere il software base, se volete imparare ma non leggete diventa complicato indicarvi la via.
Comunque provo a scaricarlo. Per caso esiste qualcosa tipo portale Youtube Netflix OPPURE posso installarci anche il Denys_OS?
@sullivan2002 è questione invece di leggere come ti dicevo in precedenza. :laugh: Ci sta differenza fra un image base ( software senza alcuna impostazione e non ottimizzato, realizzato in modo nightly cioè senza essere testato su macchina decocder dai vari team , vedi openATV come esempio ma ce ne sono tanti altri ) , un backup image ( software installato sul decoder ottimizzato con tutte le impostazioni di cui si fa backup per installarlo su altro decoder gemello ) ed un package settings ( insieme delle operazioni e settaggi automatizzati che rendono una image base come un backup) quest'ultima soluzione l'ho invetata io anni fa per fare in modo di dare supporto ai modelli di decoder che non possiedo fisicamente e di cui non potrei mai realizzare un backup ( proprio perchè per un backup si necessita del decoder su cui lavorare su).
Spero di aver chiarito la questione, quando parlavo di leggere intendevo dire le descrizioni che trovi e puoi leggere liberamente in ogni nostro download (indipendetemente dal fatto dello scaricamento), poi che tu possa scaricare il software e/o package e/o lista canali è altro discorso ed è demandato ad un supporto che tu fai per il sostentamento del sito traendone beneficio che poi potrai scaricare quello che desideri senza limiti fino al tempo della scadenza della tua membership, ma il senso è supportare il sito che tu scarichi o meno perchè ti trovi bene e ti senti in una community e dai il tuo contributo. Tutto qui :party:
Netflix su enigma2 non esiste modo di collegare un account non esiste una applicazione netflix per enigma2. Per Youtube ci sta l'apposito plugin omonimo. Il Deyns_OS è unn sistema operativo duale ad enigma2 che si può installare parallelamente a enigma2 sugli UCLAN di questa categoria, ma non lo conosco direttamente e non saprei quantificarne i pregi.
si ok ho scaricato il file SATtekNemoxyz-PCKGskin-openATV64-CBCg-Interstellar-USTYM-4KPROcombo_01-01-2021, ho flashato l'image base OpenATV64 ma ora sono bloccato, ho il putty e filezilla
come inserisco il pacchetto IPK tramite FTP in /tmp ( /var/volatile/tmp) se il decoder non essendo configurato per la rete non ho un indirizzo IP o una porta seriale dove collegarmici?
Sinceramente pensavo si facesse tutto da chiavetta USB ed era anche molto più semplice
ma Telnet o Putty e Filezilla io ce li ho sul PC portatile, come faccio a mandare la configurazione sul decoder? Mi manca un passaggio o due mi sa
o via ethernet, o via wifi o via seriale credo. Mi puoi dare una mano grazie.
@sullivan2002 grazie per contributo per prima cosa. :party:
il decoder nel momento in cui lo colleghi con il cavo, tramite il DHCP del router, gli viene assegnato un IP di connessione. lo vedi da router, oppure puoi decidere di completare il wizard di installazione, e vederlo da decoder, in questo caso potrai anche assegnare una password per la connessione FTPclient tramite menu impostazioni password.
Le istruzioni sono chiare, file > ( tramite FTPclient in questo caso filezilla ) > posizioni file in cartella /tmp/ navigando in esse tramite filezilla loggato su decoder > dai comando tramite putty-telnet
Con queste nuove versioni di images ATV devi impostare la password per cui completa wizard e poi avrai la vita più facile. facciamo step by step insieme ti seguo no problem!
Ok fatto, non sapevo qual era lo user id, poi ho visto che era scritto prima "root".
Erano un po' di anni che non usavo il Telnet e FileZilla .
Vorrei tirar fuori però anche il portale di Youtube se possibile. E poi installare anche Denys OS.
Ora io ho fatto tutto avendo configurato la rete prima con la password, ma come mai viene scritto che non deve esser fatto prima della procedura tramite Telnet e FileZilla? Devo rifare tutto o lascio così?
PS: C'è il modo di togliere o non visualizzare a display quel numero (es. 252) prima del canale esempio: 252 Canale 5 che quando sono 4 cifre rompe non poco?
io ero abituato al Jepssen che come menù era più carino (forse)
Tra l'altro devo vedere come importare tutte le registrazioni in formato file TS dal disco che era collegato al Jepssen M3 e che collegandolo a questo decoder non le vede proprio.
C'è un modo per installare un plugin per esempio o devo per forza di cose convertire tutti i file del disco in MP4?
sullivan2002 ha scritto: 4 anni Ok fatto, non sapevo qual era lo user id, poi ho visto che era scritto prima "root".
Per questo motivo dicevo di leggere...perchè so che se certe cose non si fanno giornalmente tendono a dimenticarsi. Alcune procedure articolate le dimentico io stesso per cui figurati. Ci vuole un supporto scritto di lettura. tutto qui.
Per Youtube ti basta andare da tasto verde, plugins, di nuovo tasto verde e cerchi nelle extensions da installare il plugin apposito. Mentre per il package settings quando ho inziato a crearli anni fa, al tempo ATV non faceva l'imposizione della password, per cui visto e considerato che il package determina tutti i settaggi era inutile far continuare l'utente nel wizard di configurazione se poi era compito del package. E quindi nella descrizione dicevo in quel modo ora invece per collegarsi ad FTP ed telnete devi per forza impostare la password per cui sono leggermente cambiate le cose.
Ora io ti consiglio di installarlo di seguire le istruzioni anche se hai completato tutto perchè ti imposta alcune cose (per esempio la visualizzazione display) ed altro in modo opportuno, dovrai solo installare isettingE2 aggiornato per le liste canali lo trovi qui per il tuo modello UCLAN che ha cpu ARM:
TRIAL INSTALLER iSettingE2-start-pre ( NUOVA VERSIONE ) IPK DEB plugin ALL MIPS ARM E2 - Settings Canali
si va impostato il display da menu e bisogna installare ed impostare per bene il VFDled, come dicevo il package fa tutto in automatico ed imposta il display per risparmiare le risorse.
Mah oddio....forse più carino è un po un'eresia... :laugh: :sick: ma ognuno ha il suo gusto giusto accettarlo.
Io penso che la metrixHD lite come skin della ATV sia una delle migliori e più pulite ed ergonomiche poi ci possiamo sbizzarrire su colori e forme ed io ne ho fatte tante di skin come vedi qui sul sito ma la metrix rimane professionale.
Rispondevo proprio ieri ad un altro utente sullo stesso argomento, Il files TS ( transport stream ) li puoi leggere senza problemi con il media player nativo della image ATV oppure EMC che è installato di base sulla ATV ( ehnaced movie center ) dovrebbe poter leggere anche meglio. Sicuramente non è il formato TS il problema perchè le registrazioni anche su enigma2 come per tutti i device che fanno da recoder usano la TS , ma la formattazione di questo HDD collegato in precedenza al Jepssen M3.
Una soluzione che mi viene in mente è , prova a portarli su desktop pc, poi monti HDD su enigma2 come media/hdd/fai mount e formattazione per linux enigma2 direttamente da decoder una volta conformato l'HDD ci ripiazzi in media/hdd/movie/ i file TS salvati su desktop caricandoli via FTP filezilla.
Buongiorno, ho acquistato questo dec. (UCLAN USTYM 4K Pro Combo) ho caricato imagine originale openATV 6.4 con settings di Nemoxyz, il tutto funziona perfettamente (grazie Nemoxyz) l'unica pecca che non c'è un manuale di utilizzo, trovo molte difficoltà a configurare le registrazioni e riprodurle, ho montato una MicroSD ma rispetto al sunray4 dove cera un tasto pvr dove usciva la lista registrazioni, su questo non ho trovato una cosa simile, per chi ha questo dec. da tempo e conosce tutte le funzioni, chiedo cortesemente di darmi qualche consiglio, grazie
@Salmatrix cosa hai montato la openatv 6.4 Interstellar ? Esegui formattazione ext4 e mount cm hdd della micro sd prima di tutto. Poi il resto funziona cm qualsiasi enigma2, puoi impostare un hotkey per il pvr se desideri. Oppure andare da mediaplayer o emc4 da browser plugins e navigare nella cartella media/hdd/movies/
Si ho montato la openatv 6.4 Interstellar, se volessi dedicare un tasto per un elenco registrazioni pvr come si fa? grazie
@Salmatrix spostato sotto topic ufficiale del package settings che hai scelto di usare. Qui dobbiamo scrivere... ;-) per dedicare un stato ad una funzione come ti dicevo devi andare in menu cercare la voce "hotkey" o "tasti rapidi" e selezioni tasto ed assegni la funzione pvr voluta.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 10
